I have linked two photos of what is going on with my connection. Not sure what I was supposed to block out but I just did what I thought for it. It is very odd that my internet on my pc has been acting strange lately. I didn't do anything new to it or add any new programs around when this started. I have a 1gb internet speed and i usually get 200-300mbps for my wireless connection to my pc on speed test. However, I've been getting close to 0 mbps randomly then it goes to 20mbps then 10 then 40 etc. Most of the time a website will take 10+ seconds to load or not even load at all because it just completely kills my connection. Ive tried plugging the usbs into both the motherboard from the back, and from the front top of the case and both cause issues. As you can see in the photos my task manager shows how unstable the connection is. Ive tried two different bluetooth modules that work perfect on my other pc yet for this one it has issues. Not sure if my specs are needed. Just wondering what it could be? Note again, I haven't done anything new recently and my pc has been sitting without any changes. I actually reinstalled windows a few weeks ago and barely have anything downloaded besides some games and rgb control. This issue just randomly started happening, everything was fine for the past month or so. My wifi connection on my phone is as it should be.
https://linustechtips.com/topic/1410214-weird-wifi-issues/
So your computer is the only one having the issue, your phone and other devices are acting ok?
Go to device manager, uninstall the GbE and WiFi drivers, make sure to click "delete software for device"
Then go to the manufacturer website and download the newest drivers
If that fails try using a cable if you can, helps narrow down if the WiFi capabilities or the entire network card is failing.
Lastly you can upgrade your UEFI BIOS to see if that helps. The Ethernet controller is controlled by your UEFI code in part
https://linustechtips.com/topic/1410214-weird-wifi-issues/#findComment-15250558
I cant do ethernet as my setup is on the second floor and wifi setup is in the garage. and yes its only this pc and my other devices get 300+ mbps but this pc can barely pass 5 mbps. and you mean go to manufacturer website as in my motherboards website or the usb website or what?
https://linustechtips.com/topic/1410214-weird-wifi-issues/#findComment-15251837
Maybe I missed it but if your MB website, if you are also using like a wireless dongle then you can go to their website too. Basically anything internet device related get their drivers haha
https://linustechtips.com/topic/1410214-weird-wifi-issues/#findComment-15252462
