Building my first Pc
Solved by GeorgeMKane,
42 minutes ago, Afonso Smith said:the seconds built you sent me is like 103€ extra i think its fine, but is that 103€ plus really worth it like it will make a huge difference or its ok?
becasue after like 1 or 2 years i can allways update for one of the newest graphics lets just hope the price aon the graphics com down xd
The GTX 1660 will serve you pretty well in games. The RX 6600 will just do it a lot better, especially with the 8GB of VRAM. If you can get the RX 6600 gpu, I would highly recommend going for it.
