Measure computer computation power
Solved by YoungBlade,
3 hours ago, Fasauceome said:I believe OP is actually referring to stress testing and performance, as opposed to literal power, and would like suggestions compatible with Unix (I think) in addition to Mac or windows.
In that case, you'd need to pick cross-platform benchmark applications that are representative of the types of workload being done. My first thought would be 7-Zip and doing the benchmark with all cores and then limiting it to one thread.
