Budget (including currency): $500 US
Country: United States
Games, programs or workloads that it will be used for: Halo Infinite, Space Engineers, Minecraft
Motherboard: Aorus X570 Elite Wifi
GPU: Nvidia RTX 3070
CPU: Ryzen 5 3600
CPU Cooler: Cooler Master Hyper 212
RAM: Corsair Vengeance 32GB 3200
Power Supply: Powerspec 650W 80plus bronze
Storage: 1TB HDD, 500GB M.2 SSD
Case: NZXT H510
I am having some mild temp issues with my CPU idling temps (about 50 - 55C while idle with no apps running). I am not sure if this is an actual issue, but have had some friends express that it seems a bit warm for idle which also seems to be the case from some light research online. Also slightly concerned about power supply, have been told by one friend it seems to be on the low end, but a usage calculator says it was more than enough. I have not seen any issues that I know can be attributed to the power supply. I am fairly new when it comes to computers was hoping to upgrade a part or two on my build to help increase system health (performs well more worried about temps and possible power issues), any advice on what would be best to solve one of the problems (i.e. power supply suggestions) would be very much appreciated.
https://linustechtips.com/topic/1395553-existing-system-upgrade/
Yeah, the reason you're getting high idle temmps is cuz of the shitty case. Its literallly an oven.
I recommend getting aa new case,which is kinda all you need.
However, if you've got sppme cash, then buy a new psu and cooler.
For the psu, maybe get the corsair rmx750, and the cooler, corsaiir elite capellix h150i.
Not sure about the case, thats kinda personal preference.
Hope i hellped!
Inspiron 15 5510
(i7-11390h/Iris Xe/16gb)
  • 2 months later...
  • 3 weeks later...
On 3/5/2022 at 4:25 AM, Mr-G-Man said:
I'm just wondering if you eventually did the upgrades. Did you?
Didn't get a chance. Was given a new case (fractal meshify 2xl) as a gift with the intention of improving airflow and allowing more room to expand the system. The first time I tried to boot a game in the new case, a component of my motherboard burst into flames.🙃 Actually making a post to seek advice regarding what could have caused/ how to address that issue. Dont want to fork out the money for a new mother board just for the same thing to occur.
