Budget (including currency): > RM 4000
Country: Malaysia
Games, programs or workloads that it will be used for: Valorant, Apex Legends, Dota, LoL, maybe some AAA titles. Solidworks, photoshop, MATLAB
WTA - Building New Budget PC
CPU - Ryzen 5 5600x RM 1890 ( with mobo )
CPU Fan - ID- COOLING SE-224 XT RM 84
GPU - GTX 970 TI RM0 (Owned)
Mobo - MSI B550M MORTAR
RAM - HyperX Fury 3200MHZ 8GB x 2 RM 390
Case - Silverstone Fara H1M RM 188
PSU - CM MWE GOLD V2 80+ RM360
Monitor - VX2718-PC-MHD RM 775
SSD or HDD - Owned
I'm building a new pc and looking for some advice, I plan to use the PC for 4 - 6 years, might upgrade my graphics card in the future when the price drops, plan to do some overclocking depending on performance. Might use for streaming.
https://linustechtips.com/topic/1382026-new-pc-build-help/
I like the list a lot. Good idea saving for the GPU. The cooler is completely fine, but an AIO may be a bit better for Overclocking (But the cooler listed is still an ok option).
Just make sure to put it into PcPartPicker to double check it is all compatible and at the price range for you.
Don't sleep on sleeper PCs
https://linustechtips.com/topic/1382026-new-pc-build-help/#findComment-15053300
Thanks, ye ive checked for the compatibility Mobo fits, CPU cooler fits, Power supply fits, ending up looking for fans deciding on the Arctic P12 PWM and realized i gotta get a fan splitter cause the mobo only got 3 fan ports
https://linustechtips.com/topic/1382026-new-pc-build-help/#findComment-15053602
If he wants little overclocking headroom, Something like Scythe Fuma 2 will be absolutely enough, No need for AIO.
The list looks perfectly fine, Nothing to change there.
https://linustechtips.com/topic/1382026-new-pc-build-help/#findComment-15053975
