Anti-ghosting allows you to press any number of keys on the keyboard with out it beeping or interrupting you in anyway, If you tried it on a keyboard without this feature and press 5 (I believe it is 5) keys it will begin to beep at you,
That is what Anti-Ghosting is in a nutshell,
Hope it helped
Nathan
There are 10 types of people in the world: Those who understand binary, and those who don't.
Just some helpful stuff: You're - You are, Your - Your car, They're - They are, Their - Their car, There - Over there.
Folding @ Home Install Guide and Links | My Build
https://linustechtips.com/topic/13813-what-is-anti-ghosting/#findComment-150322
When something ghosts in computers, it means that there is some kind of latency that is going on between components in a certain piece of hardware. For keyboards, as the other people who responded to this thread have articulated, is where you can press a high number of keys and all of them will register. The type of keyboards that have the best anti-ghosting technology are mechanical keyboards. I personally have the Razer BlackWidow 2013 Gaming Keyboard with  Chery MX Blue Switches.
Hope that Helps!
- winny3141 :D
System Specs: AMD Phenom II X6 1100T Six-core CPU, AMD Radeon HD 6970 2 GB GDDR5 16X PCIe Video Card, MSI 890FXA-GD70 Motherboard, Kingston Hyper-X 1600 MHz RAM, ADATA 128 GB MLC SSD, 2 TB HDD, Astec Dual 120 mm closed Liquid cooling Loop, Cooler Master 800W Silent Pro Gold (80 Plus Gold Certified) PSU, Razer Black Widow Ultimate 2013 Gaming Keyboard (Love me my Cherry MX Blue Switches), a Razer Taipan Gaming Mouse (8200 dpi 4G sensor FTW!), Windows 7 Ultimate 64-bit
https://linustechtips.com/topic/13813-what-is-anti-ghosting/#findComment-150506
The most common terms you hear are anti-ghosting and the amount of key rollover.
To sum it very easy is just.... the however amount of keys you press/hold/release are registered by the OS in correct order/released/pressed/held
When buying a keyboard make sure its "100% Anit-Ghost" and has a high rollover than 6 (which is standard on USB).
Tip: if the product pages doesn't say the amount of key rollover or NKRO, it usually means they are just using the same standard 6 that can be found on all/any USB keyboard.
https://linustechtips.com/topic/13813-what-is-anti-ghosting/#findComment-150890
How many keys does one person actually need to press at one time anyways? lol
AMD Radeon R9 290X / AMD FX-8320 / Gigabyte 990FXA-UD3 / Samsung 830 128GB / Seagate 7200RPM 3TB / Corsair HX 850W / BitFenix Shinobi XL / CPU & GPU Watercooled - Thick Triple 360 Rad
https://linustechtips.com/topic/13813-what-is-anti-ghosting/#findComment-150929
