1000 DOLLAR SETUP BUILD HELP
Go to solution Solved by Dr0idGh0sT,
47 minutes ago, BeastyB314 said:
I don't think you'll get to play Cyperpunk or gta 6 on this budget right now. Graphics cards are a big problem right now. Also, with peripherals, you'll have only about $650-700 to actually spend on your computer on the higher end. I would either wait on the peripherals or wait for a higher budget. The 5600G is way to expensive for this budget as it would be a third of your computer costs.
This is the best I could do for the computer part. Try to get a copy of windows on ebay or something for cheap.
https://pcpartpicker.com/list/DgBXj2
You haven't chosen really budget friendly options for this build, You can do better than that.
I don't really get why did you include such expensive Gen 4 drive, While 5600G doesn't even support PCIe Gen 4.
Nor case and cooler makes any sense in this price range...
PCPartPicker Part List
CPU: AMD Ryzen 5 5600G 3.9 GHz 6-Core Processor ($258.96 @ Newegg)
CPU Cooler: ID-COOLING SE-224-XT 76.16 CFM CPU Cooler ($29.99 @ Amazon)
Motherboard: Gigabyte B550M DS3H Micro ATX AM4 Motherboard ($99.99 @ Amazon)
Memory: Crucial Ballistix 16 GB (2 x 8 GB) DDR4-3600 CL16 Memory ($79.98 @ Amazon)
Storage: Kingston A2000 1 TB M.2-2280 NVME Solid State Drive ($89.99 @ Amazon)
Case: Thermaltake Versa H18 MicroATX Mini Tower Case ($54.99 @ Newegg)
Power Supply: EVGA BQ 600 W 80+ Bronze Certified Semi-modular ATX Power Supply ($49.99 @ Amazon)
Case Fan: ARCTIC P12 56.3 CFM 120 mm Fan ($9.49 @ Amazon)
Monitor: Acer VG270 Pbiip 27.0" 1920x1080 144 Hz Monitor ($195.00 @ Amazon)
Total: $877.87
Generated by PCPartPicker 2021-09-30 09:58 EDT-0400
Budget (including currency): 1000 USD
Country: BAHRAIN
Games, programs or workloads that it will be used for: PYTHON, MICROSOFT WORD, EXCEL , TEAMS, POWERPOINT,  VIDEO EDITING, LIGHT PHOTO EDITING, and some games like gta 5 , valorant, and i want to rtry cyberpunk and gta 6(when it release)
I THOUGHT OF MAKING WITH RYZEN 5 5600G
I NEED A BUILD WITH EVERYTHING INCLUDED FOR ME.
LIKE MONITOR, KEYBOARD, MOUSE, microphone and camera a little bit up and down on budget would be nice
https://linustechtips.com/topic/1377302-1000-dollar-setup-build-help/
Country: BAHRAIN
Don't sleep on sleeper PCs
Total: $877.87
Country: BAHRAIN
tbh u cant get anything rn thats will run cyberpunk at the refresh rate u expect but heres a suggestion:
https://pcpartpicker.com/list/#compatibility_notes
Total: $877.87
thank u i just need some peripherals and does this have wifi i need wifi i need mic and webcam  720p would do
That motherboard doesn't have WiFi, But this does for only 10 USD more.
https://pcpartpicker.com/product/PDsnTW/msi-b550m-pro-vdh-wifi-micro-atx-am4-motherboard-b550m-pro-vdh-wifi
19 hours ago, Dr0idGh0sT said:
Did u copy - paste my link? 🤣🤣
look closely at the link...
