It is possible to use 4 pin fan splitters to add extra fans.
Please note that only one of the fans should be connected to the sense pin on the MB header in case you are making your own, similarly avoid this (notice it has 4 pins to each fan from the header):
http://www.amazon.co.uk/gp/product/B009XA2TZM/ref=pd_lpo_sbs_dp_ss_2/275-3840794-1096054?pf_rd_m=A3P5ROKL5A1OLE&pf_rd_s=lpo-top-stripe&pf_rd_r=1YQYXMVFXNM0DZKM99Q3&pf_rd_t=201&pf_rd_p=479289247&pf_rd_i=B005G3010U
Something like this should be fine:
http://www.amazon.co.uk/Akasa-AK-CBFA04-15-Splitter-Cable-Fans/dp/B005FWXWPS/ref=sr_1_1?s=computers&ie=UTF8&qid=1396993300&sr=1-1&keywords=4+pin+fan+splitter
Hope that helps, if it doesn't make sense please say :)
"PSU brands are meaningless, look up the OEM."
https://linustechtips.com/topic/137313-2-4-pin-fan-splitters/#findComment-1824701
