Minecraft 1.16.5 not working!! Please help
Go to solution Solved by WillowtheRainFawn,
Nevermind ^^" fixed it! I just needed to replace the current worldedit with 1.7.5 version. All is fine now ❤️ (Still lost a LOT of work, including the entire blueprint I had laid out, but at least some of the more detailed work has been able to be pasted. I didn't save another finished and polished building, but you know... I saved a few good months of work so I'll take it!!
Please excuse my ignorance in the formatting of this and if this is the wrong place to post this,(or wrong tag, phrasing, etc.) please tell me!! First post here since I needed help and found this website ^^" I'm open for any pointers!
So, I tried out 1.17.1 Minecraft (not sure if that'll matter, but just in case it does) but I needed to go back to 1.16.5 (with forge) to try to salvage months of work I had done and saved via world edit. I added the 1.16.5 installation with forge back into the Minecraft launcher (because it disappeared when 1.17.1 appeared)
It went to the main screen perfectly fine, no issue- but when I was loading into a new world to paste the work from worldedit into, it crashed right as is reached 100% on loading?? I never had this issue prior to 1.17.1 and now I'm really lost and super stressed because, again, months of work that my VAs are excited to see ;.;
(please excuse any ignorance for anything blatantly obvious in the code for what's going on. ^^" my sister's the code expert, not me in the slightest! Any and all help is very appreciated)
The crash report was this:
Quote
---- Minecraft Crash Report ----
// Why did you do that?
Time: 8/31/21 10:18 PM
Description: Exception in server tick loop
java.lang.NoClassDefFoundError: org/apache/logging/log4j/util/ReflectionUtil
    at com.sk89q.worldedit-fabric.l4j.Log4jLoggerFactory.getContext(Log4jLoggerFactory.java:42) ~[?:?] {re:classloading}
    at org.apache.logging.log4j.spi.AbstractLoggerAdapter.getLogger(AbstractLoggerAdapter.java:46) ~[log4j-api-2.11.2.jar:2.11.2] {}
    at com.sk89q.worldedit-fabric.l4j.Log4jLoggerFactory.getLogger(Log4jLoggerFactory.java:29) ~[?:?] {re:classloading}
    at com.sk89q.worldedit-fabric.slf4j.LoggerFactory.getLogger(LoggerFactory.java:363) ~[?:?] {re:classloading}
    at com.sk89q.worldedit-fabric.slf4j.LoggerFactory.getLogger(LoggerFactory.java:388) ~[?:?] {re:classloading}
    at com.sk89q.worldedit.WorldEdit.<clinit>(WorldEdit.java:113) ~[?:?] {re:classloading}
    at com.sk89q.worldedit.extension.platform.AbstractPlatform.<init>(AbstractPlatform.java:41) ~[?:?] {re:classloading}
    at com.sk89q.worldedit.forge.ForgePlatform.<init>(ForgePlatform.java:69) ~[?:?] {re:classloading}
    at com.sk89q.worldedit.forge.ForgeWorldEdit.setupPlatform(ForgeWorldEdit.java:142) ~[?:?] {re:classloading}
    at com.sk89q.worldedit.forge.ForgeWorldEdit.serverStarted(ForgeWorldEdit.java:209) ~[?:?] {re:classloading}
    at net.minecraftforge.eventbus.ASMEventHandler_10_ForgeWorldEdit_serverStarted_FMLServerStartedEvent.invoke(.dynamic) ~[?:?] {}
    at net.minecraftforge.eventbus.ASMEventHandler.invoke(ASMEventHandler.java:85) ~[eventbus-4.0.0.jar:?] {}
    at net.minecraftforge.eventbus.EventBus$$Lambda$2562/175392962.invoke(Unknown Source) ~[?:?] {}
    at net.minecraftforge.eventbus.EventBus.post(EventBus.java:302) ~[eventbus-4.0.0.jar:?] {}
    at net.minecraftforge.eventbus.EventBus.post(EventBus.java:283) ~[eventbus-4.0.0.jar:?] {}
    at net.minecraftforge.fml.server.ServerLifecycleHooks.handleServerStarted(ServerLifecycleHooks.java:107) ~[?:?] {re:classloading}
    at net.minecraft.server.MinecraftServer.func_240802_v_(MinecraftServer.java:622) [?:?] {re:classloading,pl:accesstransformer:B}
    at net.minecraft.server.MinecraftServer.func_240783_a_(MinecraftServer.java:232) [?:?] {re:classloading,pl:accesstransformer:B}
    at net.minecraft.server.MinecraftServer$$Lambda$5117/1962487060.run(Unknown Source) [?:?] {}
    at java.lang.Thread.run(Thread.java:745) [?:1.8.0_51] {}
Caused by: java.lang.ClassNotFoundException: org.apache.logging.log4j.util.ReflectionUtil
    at java.lang.ClassLoader.findClass(ClassLoader.java:530) ~[?:1.8.0_51] {}
    at java.lang.ClassLoader.loadClass(ClassLoader.java:424) ~[?:1.8.0_51] {}
    at cpw.mods.modlauncher.TransformingClassLoader.loadClass(TransformingClassLoader.java:94) ~[modlauncher-8.0.9.jar:?] {re:classloading}
    at java.lang.ClassLoader.loadClass(ClassLoader.java:357) ~[?:1.8.0_51] {}
    ... 20 more
A detailed walkthrough of the error, its code path and all known details is as follows:
-- System Details --
Details:
    Minecraft Version: 1.16.5
    Minecraft Version ID: 1.16.5
    Operating System: Windows 10 (amd64) version 10.0
    Java Version: 1.8.0_51, Oracle Corporation
    Java VM Version: Java HotSpot(TM) 64-Bit Server VM (mixed mode), Oracle Corporation
    Memory: 540560888 bytes (515 MB) / 2147483648 bytes (2048 MB) up to 2147483648 bytes (2048 MB)
    CPUs: 6
    JVM Flags: 9 total; -XX:HeapDumpPath=MojangTricksIntelDriversForPerformance_javaw.exe_minecraft.exe.heapdump -Xss1M -Xmx2G -XX:+UnlockExperimentalVMOptions -XX:+UseG1GC -XX:G1NewSizePercent=20 -XX:G1ReservePercent=20 -XX:MaxGCPauseMillis=50 -XX:G1HeapRegionSize=32M
    ModLauncher: 8.0.9+86+master.3cf110c
    ModLauncher launch target: fmlclient
    ModLauncher naming: srg
    ModLauncher services:
        /mixin-0.8.2.jar mixin PLUGINSERVICE
        /eventbus-4.0.0.jar eventbus PLUGINSERVICE
        /forge-1.16.5-36.1.4.jar object_holder_definalize PLUGINSERVICE
        /forge-1.16.5-36.1.4.jar runtime_enum_extender PLUGINSERVICE
        /accesstransformers-3.0.1.jar accesstransformer PLUGINSERVICE
        /forge-1.16.5-36.1.4.jar capability_inject_definalize PLUGINSERVICE
        /forge-1.16.5-36.1.4.jar runtimedistcleaner PLUGINSERVICE
        /mixin-0.8.2.jar mixin TRANSFORMATIONSERVICE
        /forge-1.16.5-36.1.4.jar fml TRANSFORMATIONSERVICE
    FML: 36.1
    Forge: net.minecraftforge:36.1.4
    FML Language Providers:
        javafml@36.1
        minecraft@1
    Mod List:
        forge-1.16.5-36.1.4-client.jar                    |Minecraft                     |minecraft                     |1.16.5              |DONE      |NOSIGNATURE
        forge-1.16.5-36.1.4-universal.jar                 |Forge                         |forge                         |36.1.4              |DONE      |22:af:21:d8:19:82:7f:93:94:fe:2b:ac:b7:e4:41:57:68:39:87:b1:a7:5c:c6:44:f9:25:74:21:14:f5:0d:90
        goprone-1.16.4-1.3.5.jar                          |GoProne                       |goprone                       |1.16.4-1.3.5        |DONE      |NOSIGNATURE
        worldedit-mod-7.2.4.jar                           |WorldEdit                     |worldedit                     |7.2.4+5723-e3bfc64  |DONE      |NOSIGNATURE
        RapidLeafDecay-1.16.5-1.0.0.jar                   |Rapid Leaf Decay              |rapid_leaf_decay              |1.0.0               |DONE      |NOSIGNATURE
    Crash Report UUID: 1a422bdc-8eda-4922-b79d-32411b417eda
    Player Count: 0 / 8; []
    Data Packs: vanilla, mod:forge, mod:goprone, mod:worldedit (incompatible), mod:rapid_leaf_decay
    Type: Integrated Server (map_client.txt)
    Is Modded: Definitely; Client brand changed to 'forge'
EDIT:
After coming back to this, I decided to install a vanilla version of 1.16.5 in the launcher, but the same thing happened when I tried to open the new minecraft world.
Here's the new crash report:
Quote
// You should try our sister game, Minceraft!
Time: 9/1/21 2:40 PM
    at net.minecraftforge.eventbus.ASMEventHandler_4_ForgeWorldEdit_serverStarted_FMLServerStartedEvent.invoke(.dynamic) ~[?:?] {}
    at net.minecraftforge.eventbus.EventBus$$Lambda$2552/1193120490.invoke(Unknown Source) ~[?:?] {}
    at net.minecraft.server.MinecraftServer$$Lambda$5102/1954484020.run(Unknown Source) [?:?] {}
    ... 20 more
Details:
    Memory: 1489398552 bytes (1420 MB) / 2147483648 bytes (2048 MB) up to 2147483648 bytes (2048 MB)
    CPUs: 6
    FML: 36.1
        javafml@36.1
        minecraft@1
    Mod List:
    Crash Report UUID: 5ffec8f2-6e3a-46bc-8e80-b36663a82cd7
Edited by WillowtheRainFawn
https://linustechtips.com/topic/1369781-minecraft-1165-not-working-please-help/
