Help with nvfbc on linux OBS
Go to solution Solved by Soulsrep,
i havent been getting the nvfbc source for obs
ive done all the commands in the terminal, pasted the plugin into obs files and yet the source nvfbc doesnt show up for me
system is pop os
  • 2 months later...
On 7/28/2021 at 2:01 PM, Soulsrep said:
turns out there is 2 versions of obs in pop shop, install the ubuntu version and it will work just fine
Hoping you can help me. I had originally installed the flatpak and after realizing it saved things very differently I uninstalled it and installed the Ubuntu version instead. Now I do find the directory above and I add a plugins folder. But when I place the nvbfc.so file I generated earlier it doesn't pick it up ( I don't see the nvfbc option as a source. I've tried placing it in plugins, plugines/nvfbc, plugins/nvfbc/64bit (as per another tutorial).
09:13:26 PM.786: CPU Name: AMD Ryzen 7 3700X 8-Core Processor
09:13:26 PM.786: CPU Speed: 2200.000MHz
09:13:26 PM.787: Physical Cores: 8, Logical Cores: 16
09:13:26 PM.787: Physical Memory: 15945MB Total, 9956MB Free
09:13:26 PM.787: Kernel Version: Linux 5.13.0-7614-generic
09:13:26 PM.787: Distribution: "Pop!_OS" "21.04"
09:13:26 PM.787: Session Type: x11
09:13:26 PM.787: Window System: X11.0, Vendor: The X.Org Foundation, Version: 1.20.11
09:13:26 PM.797: Portable mode: false
09:13:26 PM.835: OBS 27.1.3 (linux)
09:13:26 PM.835: ---------------------------------
09:13:26 PM.835: audio settings reset:
09:13:26 PM.835: 	samples per sec: 48000
09:13:26 PM.835: 	speakers:        2
09:13:26 PM.840: ---------------------------------
09:13:26 PM.840: Initializing OpenGL...
09:13:26 PM.945: Loading up OpenGL on adapter NVIDIA Corporation NVIDIA GeForce RTX 2060/PCIe/SSE2
09:13:26 PM.945: OpenGL loaded successfully, version 3.3.0 NVIDIA 470.63.01, shading language 3.30 NVIDIA via Cg compiler
09:13:26 PM.957: ---------------------------------
09:13:26 PM.957: video settings reset:
09:13:26 PM.957: 	base resolution:   2560x1440
09:13:26 PM.957: 	output resolution: 1920x1080
09:13:26 PM.957: 	downscale filter:  Bicubic
09:13:26 PM.957: 	fps:               60/1
09:13:26 PM.957: 	format:            NV12
09:13:26 PM.957: 	YUV mode:          709/Partial
09:13:26 PM.957: NV12 texture support not available
09:13:26 PM.957: Audio monitoring device:
09:13:26 PM.957: 	name: Default
09:13:26 PM.957: 	id: default
09:13:26 PM.958: Failed to load 'en-US' text for module: 'decklink-captions.so'
09:13:26 PM.959: Failed to load 'en-US' text for module: 'decklink-ouput-ui.so'
09:13:27 PM.033: A DeckLink iterator could not be created.  The DeckLink drivers may not be installed
09:13:27 PM.033: No blackmagic support
09:13:27 PM.036: [obs-browser]: Version 2.16.3
09:13:27 PM.036: [obs-browser]: CEF Version 87.1.12+g03f9336+chromium-87.0.4280.88
09:13:27 PM.051: NVENC supported
09:13:27 PM.051: FFMPEG VAAPI supported
09:13:27 PM.060: VLC found, VLC video source enabled
09:13:27 PM.060: ---------------------------------
09:13:27 PM.060:   Loaded Modules:
09:13:27 PM.060:     vlc-video.so
09:13:27 PM.060:     text-freetype2.so
09:13:27 PM.060:     rtmp-services.so
09:13:27 PM.060:     obs-x264.so
09:13:27 PM.060:     obs-vst.so
09:13:27 PM.060:     obs-transitions.so
09:13:27 PM.060:     obs-outputs.so
09:13:27 PM.060:     obs-libfdk.so
09:13:27 PM.060:     obs-filters.so
09:13:27 PM.060:     obs-ffmpeg.so
09:13:27 PM.060:     obs-browser.so
09:13:27 PM.060:     linux-v4l2.so
09:13:27 PM.060:     linux-pulseaudio.so
09:13:27 PM.060:     linux-jack.so
09:13:27 PM.060:     linux-decklink.so
09:13:27 PM.060:     linux-capture.so
09:13:27 PM.060:     linux-alsa.so
09:13:27 PM.060:     image-source.so
09:13:27 PM.060:     frontend-tools.so
09:13:27 PM.060:     decklink-ouput-ui.so
09:13:27 PM.060:     decklink-captions.so
09:13:27 PM.060: ==== Startup complete ===============================================
09:13:27 PM.062: All scene data cleared
09:13:27 PM.062: ------------------------------------------------
09:13:27 PM.066: pulse-input: Server name: 'pulseaudio 14.2'
09:13:27 PM.066: pulse-input: Audio format: s16le, 44100 Hz, 2 channels
09:13:27 PM.066: pulse-input: Started recording from 'alsa_output.platform-snd_aloop.0.analog-stereo.monitor'
09:13:27 PM.066: [Loaded global audio device]: 'Desktop Audio'
09:13:27 PM.067: pulse-input: Server name: 'pulseaudio 14.2'
09:13:27 PM.067: pulse-input: Audio format: s16le, 44100 Hz, 2 channels
09:13:27 PM.067: pulse-input: Started recording from 'alsa_input.platform-snd_aloop.0.analog-stereo'
09:13:27 PM.067: [Loaded global audio device]: 'Mic/Aux'
09:13:27 PM.067: Switched to scene 'Scene'
09:13:27 PM.067: ------------------------------------------------
09:13:27 PM.067: Loaded scenes:
09:13:27 PM.067: - scene 'Scene':
09:13:27 PM.594: adding 42 milliseconds of audio buffering, total audio buffering is now 42 milliseconds (source: Mic/Aux)
09:13:27 PM.594:
09:13:27 PM.594:
Figured it out after installing another plugin (streamfx). I created an nvfbc folder in plugins and then a bin folder inside of that and then a 64bit folder at the end. Popped the .so file into that folder and then it worked.
