Possibly no Thermal Compound..
46 minutes ago, 8tg said:That’s a 3900x on a 120mm AIO, water cooling is not inherently better, at that point it’s slightly better than the stock cooler, maybe.
A 120mm aio seeing sub 70c temps on a 3900x is pretty good.
1 hour ago, dynamix1862 said:It was at idle. I was just sitting at my home screen with the dashboard and Windows Edge. I'm not sure what the temp is when it's under load or when I'm gaming. I also have two 120mm fans in the front of the case and one 120mm in the back, attached to the AIO and my room is freezing. Just trying to dump as much info as possible to help you helping me. Thanks again though!
Ouch yeah, that's a really bad pairing if its a 120mm AIO, its almost certainly holding the performance of that CPU back.
The only good reason to use a 120mm AIO is if you don't have space for a bigger one or a chunky air cooler like the Deepcool AS500 or Noctua NH-D15.
