Hi,
first of all my Hardware
i7 11700k
MSI MPG Z590 Gaming Force
CPU water cooling ( Corsair iCUE H150i
MSI 2080 Super Shark (water cooling)
32 GB Gskill DDR4 3200 CL16
SSD MP600 Corsair 1TB (main for Games)
Samsung 840 EVO 250 GB (Main for Windows)
Corsair HX1000i for Power
Here my Problem,
After an total damage of my old Water cooling (i7 8700k) and an MSI Motherboard i had Problems with FPS in every Game.. Like 40-50 in Call of Duty Warzone. Before it was 120-140.
I try´d everthing but i decided to buy a new Motherboard and CPU. (because there was a little bit Water on the old Motherboard)
After this i thought the Problem was gone, but NO!
New Hardware and new Windows.
i testet other RAM, nothing.
I testet the 2080S in Benchmark, everthing is ok.
I try´d the Game on a other Harddisk. nothing
Temperature is fine, CPU and GPU..
In CSS i have 90- 100 FPS with this hardware..
Can anyone Help me? im frustradet
Thx
Alex
https://linustechtips.com/topic/1345951-fps-too-low-need-help/
6 minutes ago, tryME_1337 said:
Hi,
i7 11700k
Here my Problem,
Thx
Alex
Did you try monitoring tools? You can use an OSD in MSI AfterBurner for example, to see your gpu frequency, usage, memory,...
If your gpu is running at a good frequency and used 100%, cpu not used for 100%, then you might want to check the game settings. Maybe there's some upsampling active?
https://linustechtips.com/topic/1345951-fps-too-low-need-help/#findComment-14792639
