Help with GeForce overlay
Solved by 0vercast,
Never mind! I figured it out!
If anyone else runs in to this problem I have a fix!
Open GeForce Experience, then go to Settings.
Once in the GeForce Experience Settings, there should be an option that says 'IN-GAME OVERLAY'
Under that, it should show something like this (see attached image) where Alt+Shift+` is your keybind.
