Hi, so I bought Hyperx Cloud Alpha S headset to replace my old headset and randomly every couple hours I would get static, popping sound, I contacted hyperx and well I tried everything they said, reinstalled audio driver, updated usb sound card driver, plugged it into a different USB port, reinstalled gpu drivers, disabled special enchantments, nothing worked and the noise started to happen more often and for a longer time, I got the usb sound card replaced, it didn’t fix the issue, it happened less often and for a shorter time but still happened, I researched about it and some people said changing pcie lanes from auto to gen 3-4 helped them, I changed mine to gen 4 and I thought it fixed the issue but today I started getting it again, now it seems to only happen for a couple seconds every so often, what could it be, is it pc? driver? Or the headset/cable?
Specs:
Asus ROG strix x570 gaming f
Ryzen 7 5800x
Msi 2070 super gaming x trio
Gskill 32gb ram 3600mhz
