Hi Forum,
I have recently updated my PC hardware to the following spec.
motherboard Asrock B365M Phantom Gaming 4, BIOS v4.30
CPU i7-9700k
RAM 16GB DDR4 2400Mhz
GPU RTX 2060
PSU 500W Gold +
when I boot the PC I'm am not getting a post. The Post Status Checker shows a solid red light at DRAM and a flashing red light at CPU.
Troubleshooting
Re settled CPU
Tried re seating RAM in different sequences
Tried onboard GPU and GPU
Tried resetting CMOS
Tried RAM in different system
- works fine
Tried different PSU
Removed Motherboard from case and tested.
Anyone any ideas before I send it back as faulty
Thanks
Thomas
https://linustechtips.com/topic/1335737-help-new-build-not-posting/
Yeah, sounds like a dead CPU. But before you RMA:
1. Are you sure CPU power is plugged in?
2. Got any other LGA 1151 3xx series chipset board you can use?
3. Do you hear any POST beeps from the system?
4. Try touching the CPU bare, does it make any heat?
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
1, Yes CPU plugged in correctly
2, No other 3 series chipset
3, No speaker on the motherboard
4, yes gives of heat
Thank you
