also known as MACHINE_CHECK_EXCEPTION BSOD error
srt trail is a critical system malfunction that sends you into the BSOD mode even before you reboot your computer. This error may unexpectedly interrupt your work when the system is already loaded and running
This appears when
Corrupt system files
Corrupted software
Hardware issues (corrupt or incompatible hardware installed)
Corruption in Windows Registry
How to fix Srttrail.txt BSOD error on Windows 10?
Run SFC Scan
Perform System Restore
Run Command Prompt
Repair Corrupt Windows Registry
Verify Device Partition
Reset the PC
Perform a Clean Install
This may work
heres A cute picture of Linus no homo
https://linustechtips.com/topic/1325558-srttrailtxt-fix/#findComment-14639702
This appears when
Corrupted software
Run SFC Scan
Run Command Prompt
Reset the PC
This may work
Thank you i will try it:)
https://linustechtips.com/topic/1325558-srttrailtxt-fix/#findComment-14639712
This appears when
Corrupted software
Run SFC Scan
Run Command Prompt
Reset the PC
This may work
Hey i got a quick question because when i went to "reset this pc" to reset windows it says "there was a problem while resetting your pc."
https://linustechtips.com/topic/1325558-srttrailtxt-fix/#findComment-14639717
This appears when
Corrupted software
Run SFC Scan
Run Command Prompt
Reset the PC
This may work
And same thing happens when i go into "Uninstall updates" i just doesnt want to restart.
https://linustechtips.com/topic/1325558-srttrailtxt-fix/#findComment-14639727
