Budget (including currency):800 us dollars
Country: USA
Games, programs or workloads that it will be used for:
Other details: streaming gaming and some basic editing. i need advice on my new build i was thinking of getting a ryzen 5 3600 instead but didn't wanna go over budget also i haven't figured out what GPU to use i was thing a 1660 or 5500 xt. any advice would be help full 🙂
https://linustechtips.com/topic/1325398-new-build-need-help/
Hi there. You have a decent list and although I could defiantly reccommend some upgrades on some of your components you need to ensure you get a GPU. A 1660 super costs about 300 dollars ish, a retail price of a 3060ti costs 400 dollars. I really reccommend you wait until the shortage is over, not only will you have a bigger budget but you will be able to get cheaper and more advanced components.
https://linustechtips.com/topic/1325398-new-build-need-help/#findComment-14638332
