48 minutes ago, HabadaTM said:
 trying to split one PSU across two motherboards 🙂
If you don't use the "quote" function, I can't tell when you reply.
You don't need the Phanteks device to do what you're doing.  I've opened one of those up and there's nothing special inside.  It just splits everything up into two cables.  The same thing can be accomplished with a 24-pin splitter cable:  https://www.ebay.com/itm/274313516363
ok thanks
can i do the same with the other cables?
