Budget (including currency): (case transfer) $139.99
Country: USA
Games, programs or workloads that it will be used for: Gaming and making videos
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): Going from a phanteks p300a to a Enthoo pro 2.
 I was unsure if it is possible to fit a 240mm crossflow radiator ( like the Alphacool NexXxoS ST30 Full Copper X-Flow 240mm radiator) on the bottom of the case while having a m-itx motherboard at the same time. Is it possible to have both at the same time?
https://linustechtips.com/topic/1298503-question-about-enthoo-pro-2/
