Budget (including currency): $1000 USD
Country: USA
Games, programs or workloads that it will be used for: Dedicated PC VR build on a Valve Index (goal - 120 [hopefully 144hz] at high fidelity)
Hey guys. I'm currently running a valve index and I want to be able to run 144hz comfortably at least on high. Currently bottlenecked at the CPU, so I would like some advice.
Current-
Asrock X370 Killer SLI/AC (32GB ram 2666mhz)
Ryzen 5 2600x
GB Gaming OC RTX 3070
Gammmax deepcool GTE CPU cooler
Corsair 750w +80 bronze ATX psu
I was looking at the following upgrades....
Ryzen 5 5600x
X570 variant (still trying to research which one will best suit my needs).
Any advice and direction is greatly appreciate. I am willing to spend up to $1,000 USD (to account for scalper pricing for CPUs) for this upgrade.
Thank you guys.
https://linustechtips.com/topic/1297975-dedicated-pc-vr-build-advice/
Country: USA
Current-
Ryzen 5 2600x
Ryzen 5 5600x
Thank you guys.
A 5600/5800 would be a great upgrade. Note that if you do the latter then you need a aftermarket cooler
geometry is hard
b550 > x570
