1. Budget & Location US, no price is too much
2. Aim
My aim is to get the 9 lian li fans all to sync up in the build, I was wondering will I need a hub or whatever is needed to get them to sync up with the rgb connector on the motherboard. (also no corsair hubs)
3.Parts Already Acquired for Build.
Thermaltake Toughpower GF1 850w
Lian-Li PC-O11 Dynamic RAZER Edition
ASRock B550 Taichi Razer Edition
GeIL 16GB Kit (2x8GB) DDR4 EVO X II x2 32Gb
Lian-Li Bora Digital RGB 120mm x3 (9 fans in total)
3090 Asus ROG Strix OC
ASUS ROG Strix LC 240mm RGB AIO The fans will be replaced with the Lian li ones.
AMD Ryzen™ 9 5900X
https://linustechtips.com/topic/1285652-razer-chroma-build/
  • 1 month later...
There should be RGB headers on the motherboard you can use. You'll need a splitter, though. The other option is the Razer RGB hub. It's only $40 but you can plug in standard ARGB stuff to it and connect it straight up to Chroma. I'm in the process of doing the same thing. I don't want 9 different RBG programs running, and I already use a Razer KB and Mouse, so I figured 'in for a penny, in for a pound.' Hopefully it doesn't seem like too much of a full kit wanker, though.
https://linustechtips.com/topic/1285652-razer-chroma-build/#findComment-14458568
