15 minutes ago, Rudra Ponkshe said:
I would like to open a program when I log on
To do that through task manager you would need to try and find the event ID of a 'logon' in event viewer.
Try this - https://www.onmsft.com/how-to/how-to-automatically-launch-an-app-when-you-login-to-windows-10
You can put a shortcut to the program in the start up folder and windows should launch it when you log in :)
RIG SPECS: Corsair 800D case, MSI Z77 Big Bang Motherboard, i7 3770K @ 4.5Ghz with a H100i cooling it, 2x MSI NVIDIA GTX 970, 16GB PC3-14400 Ballistix Tracer, Corsair AX850 power supply, 3x 2TB WD HDD's, HyperX 120GB SSD. Monitor: 1x 27" ASUS Swift PG278Q & 2 x illyama prolite 24"
7 hours ago, Rudra Ponkshe said:
Hey Dr.J
Unfortunately I don't follow the solution. Can you please help with running this using Task Scheduler for Windows 10?
It'd help
What program are you trying to open when you log in?
