So today i bought a Asus gtx 1070 from a seller. I was really happy and tried plugging in it directly. HOWEVER when i tried turning The pc on, it just shut off after few seconds. The gpu and fan was working so its not a problem with The gpu since i tested it at the seller house.. At first i thought it was using to much power. But i checked and saw it was using 500w, same as my other gpu. I got a 650w psu. If anyone got tips that would be great
https://linustechtips.com/topic/1273553-graphic-card-issue/
Your 1070 is certainly not using 500 watts, what is your exact system spec? With PSU model please.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1273553-graphic-card-issue/#findComment-14245436
Just now, Spunchkens said:
Strange. Cause it do say 500w. PSU is a fractal design 650w with a p67a g45 motherboard
A 1070 will consume about 180 watts by itself. You have the correct PCIe connectors for the card right?
You also have multiple PCIe slots on that motherboard, perhaps try the secondary slot.
Also by testing at the seller's house, did you actually load a game?
Primary PC:
PSU tier list
https://linustechtips.com/topic/1273553-graphic-card-issue/#findComment-14245480
I did use a 6+2 connector. And I can only use 1 slot since cables are in The way. The gpu is to big i marked it. And the first slot is where i use my old gpu. A gtx 970 msi
https://linustechtips.com/topic/1273553-graphic-card-issue/#findComment-14245491
And yes i tested a game
https://linustechtips.com/topic/1273553-graphic-card-issue/#findComment-14245492
