I got a new i7-10700k CPU and a new ROG STRIX Z490E motherboard with it, and after installing everything my cat6 cable just won't work nor get detected. I installed there armory crate and there are no drivers in there for me to download, and I have also downloaded the LAN drivers off of the website and it doesn't work. I updated my BIOS and any ideas or ways to fix this would be greatly appreciated.
https://linustechtips.com/topic/1270453-ethernet-cable-not-working/
Have you tried a different cable? is there a blinking light on either the computer port or router port while its connected?
If you pull up device manager on your computer, does it properly show a network card?
CPU: AMD Ryzen 7 5800x
Motherboard: Asus ROG Strix X570-F Gaming
RAM: G.Skill Trident Z RGB 32 GB (4 x 8 GB) DDR4-3600 CL16
Graphics: Zotac GAMING Trinity OC GeForce RTX 3090(Flashed with Gigabyte 390W BIOS)
SSD: Samsung 970 EVO NVMe 1TBx1, Samsung 970 EVO NVMe 512GBx1, Samsung 860 Pro 256GBx2 RAID0
PSU: Corsair RM1000x 80+ Gold Case: NZXT H710 (custom panels)
Monitor:  Alienware AW3420DW Curved 34" WQHD 3440 X 1440 120Hz Ultrawide, Pixio PX329 32" WQHD 165Hz,
Keyboard: Logitech G915 TKL
Mouse: Razer Basilisk Ultimate Wireless
Cooling:
EK-Quantum Vector Trinity RTX 3080/3090 D-RGB
EK-CoolStream SE 360 (Slim Triple) x2
EK-Quantum Kinetic TBE 200 D5 PWM D-RGB
EK-Quantum Momentum ROG Strix X570-E Mono Block
12/16mm Tubing
when i look at the cable one blinking light is green while the other is orange, and i plan on trying out my old cat 5 cable tomorrow, I just need to find it.
update: I tried plugging in my old cat5 cable and the computer lights on the ethernet port wouldn't even light up, most likely because the old cable is kinda messed up.
That would indicate that its detecting a physical connection at least. Have you checked device manager?
Cooling:
12/16mm Tubing
yes, i've been trying to work with it for like 7 hours today and my ethernet controller has the yellow exclamation mark and won't work, so what I think the problem is is that my LAN driver isn't downloading correctly and whenever I do download it I get "Cannot install drivers. No Intel(R) Adapters are present in this computer."
