i have an old rosewill blackhawk ultra case and i want to replace the 3pin 230mm fans in the case, as well as the 3pin 140mm fans
i think i have space for 3 140mm on top, 2 on the front, 2 on the hdd cage, and 1 on the back, so 8 140mm's, correct me if im wrong
i want to have rpm control, and full unicorn barf option (though i'll generally set it for steady while im using it)
what are my options for fans and i assume i'll need fan power blocks and rgb block
current specs: MSI gaming edge wifi b550, R5 3600X, gtx 1070
https://linustechtips.com/topic/1262793-case-fan-upgrades/
https://www.tomshardware.com/reviews/elite-atx-case-inwin-tou-silverstone-ft04,3812-9.html
3x140mm top or 1x140mm top if psu mounted at top, 3x140mm bottom or 1x140mm bottom if psu mounted at bottom, 2x140mm front, 1x140mm rear
and 9x120mm on side mesh if you are insane
looks like 7x140mm to me.
your motherboard has 2x 4pin 12v RGB and 2x 3pin ARGB headers so you have options. and 6x4pin PWM fan headers
cheaper option: 58$ for 3pack of 140mm pwm ARGB controlled fans. 2 sets of these should give you front, top and rear and can be chained together so all your RGB is on one header.
https://www.amazon.com/Thermaltake-Motherboard-Controller-Addressable-CL-F080-PL14SW/dp/B07MVZDFBV/ref=sr_1_6?dchild=1&keywords=140mm+pwm+rgb&qid=1603922070&sr=8-6
or
60$ for 3pack, same same but different look for the fans (I prefer these)
https://www.amazon.com/anidees-Aureola-Compatible-addressable-AI-AR-DUO14/dp/B07X6Q138G/ref=sr_1_8?dchild=1&keywords=140mm+pwm+rgb&qid=1603922070&sr=8-8
and the expensive option $90 for a 2 pack of the same same as above but corsair controller and probably a slightly quieter fan (which won't be a problem because they are all PWM controlled)
https://www.amazon.com/Corsair-LL140-140mm-Light-Lighting/dp/B075VGRL8Z/ref=sr_1_5?dchild=1&keywords=140mm+pwm+rgb&qid=1603922070&sr=8-5
The best gaming PC is the PC you like to game on, how you like to game on it
https://linustechtips.com/topic/1262793-case-fan-upgrades/#findComment-14160077
  • 1 month later...
3x140mm on top
2x140mm in front of the HDD cage, 2x140mm behind HDD cage, push-pull
1x140mm rear
would be 8x140mm without any on the bottom which im not gonna do bottom ones because im planning on making my own PSU shroud to hide the wires
https://linustechtips.com/topic/1262793-case-fan-upgrades/#findComment-14316915
5 minutes ago, redbeard23 said:
3x140mm on top
1x140mm rear
I would do 6, push pull for the hdd cage is totally unnecessary if you want the look it could work but it won't increase airflow by a measurable amount
https://linustechtips.com/topic/1262793-case-fan-upgrades/#findComment-14316934
