Need help with First build.
Go to solution Solved by Fasauceome,
19 minutes ago, IbrahimYunusErgul said:
550w +80 plus  is enough for psu
Yes, If it's a quality unit. Have you checked out the PSU tier list?
You can find units in your store and check them here.
Budget (₺):4000
Country: Turkey
Games, programs or workloads that it will be used for:Game and MS Office
Other details:I have used my i7 4790k 12gb ddr3 ram 1600mhz 1tb wd hdd gtx 750 ti gpu for 4 years then i sold it for good price now im an university student so i need an pc for doing homeworks or doing projects on microsoft office
I just want an pc with 10th gen intel cpu,a motherboard with m2 nvme ,hdmi slot the last one 16gb 3000mhz ram
I will buy gtx 1650 super in 1 year so
https://linustechtips.com/topic/1253648-need-help-with-first-build/
Primary PC:
PSU tier list
How many watts do I need?
