Simple I'm running an RTX 2080 Super with a 9900k. Currently driving 4x LG 4K monitors. Looking to get a 5th 1080p monitor but the 2080S only supports 4 outputs.
I can get an output by enabling the iGPU or putting in a spare GTX 1050 I have lying around. But once wallpaper engine starts up GPU Usage soars. Usually what i expect is somewhere between 15-20% GPU Usage when I have all 4 wallpapers going.
And I'm pretty much able to get that when I enable the iGPU or with the 1050 with displays only plugged into the 2080S.
But once i try to plug in a 5th display to the iGPU or the GTX 1050, this happens.
GPU Usage for BOTH GPUs soar to about 50% even though there isn't anything extra running and the 5th monitor doesn't even have a wallpaper. Along with that my whole system turns into a choppy mess and is basically unusable until i pause/quit wallpaper engine or unplug the display connected to the iGPU/GTX 1050. The same sorta graph happens with the iGPU just that it reaches about 70% instead.
The GTX 1050 doesn't need to compute anything for me, it just needs to act as a display output.
Wallpaper Engine is also already set up in both display settings and NVIDIA control panel to use the RTX 2080SUPER
If I can get it working properly I'll probably head out and buy a 1650 super to throw in there. (the palit gtx 1050 gets really loud even at idle)
Any help will be appreciated was running on NVIDIA drivers from April this year (don't remember the number) and already updated it to 451.67 07/09/2020 with no improvements.
Main Rig: CPU: AMD Ryzen™ 9 3950X Processor (Stock, -0.1V offset)  /// Motherboard: Asus Pro WS X570-Ace /// CPU Cooler: Deepcool GamerStorm Castle 360 RGB V2 /// GPU: Gigabyte AORUS GeForce® RTX 2080 SUPER™ 8G /// RAM: G.SKILL Ripjaws V 128GB (4x32GB) 3200Mhz CL16 /// Chassis: Fractal Design Define R6 USB-C Blackout TG /// PSU: Corsair RM850i /// Storage: 500GB Samsung 970 EVO Plus NVMe (boot) + 1TB WD Black SN750 NVMe (Working Drive) + 2x 1TB Samsung 850 EVO 2.5" SATA SSD RAID0 (Game Library) + 2TB Seagate BarraCuda (Backup) /// OS: Windows 10 Pro
Peripherals (Main Rig): Mouse: Logitech MX Master 3 + Logitech G903 Lightspeed /// Keyboard: Keychron Q1 ANSI - JWK Lavender Linear Switches (TX Switch Film, Krytox 205g0), Durock V2 Stabilisers, Polycarbonate Plate, Tape Mod, GMK Blue Samurai + Keychron K4 V2 Hotswap RGB Aluminum Frame - Gateron Milky Black (Deskeys Switch Film, Krytox 205g0), Foam Mod, Tape Mod, GMK Rainy Day PBT Clones /// Tablet: Wacom Intuos M BT /// Monitor: 4x LG 27UL500-W (4K IPS Freesync) /// DAC: Focusrite Scarlett 2i2 /// Speakers: Logitech Z625 /// Mic: Focusrite CM25 MkII /// Headphones: Audio-Technica ATH-M50x, ATH-LS70iS IEMs /// Racing Wheel: Logitech G920 Driving Force with Shifter /// Eye Tracker: Steelseries Sentry  /// External Drives: 500GB Samsung T5 SSD (Working Drive)
Home Server - NASty: CPU: AMD Ryzen™ 7 2700x Processor /// Motherboard: Asus PRIME X470-Pro  /// CPU Cooler: be quiet! Dark Rock Pro 4 /// GPU: Gigabyte GeForce® GT 1030 OC 2G /// RAM: G.SKILL TridentZ RGB 64GB (4x16GB) 3200Mhz CL16 /// Chassis: Fractal Design Define R5 Window /// PSU: Corsair RM750x /// Storage: LSI SAS 9211-8i (IT Mode) + 10x 4TB Seagate Exos Enterprise Drive /// OS: UNRaid
Tester Rig: CPU: AMD Athlon™ 200GE Processor /// Motherboard: Asus ROG Crosshair VI Hero WIFI  /// CPU Cooler: AMD Wraith Prism RGB /// GPU: Palit GeForce® GTX 1050 2GB StromX /// RAM: Klevv Bolt 8GB (1x8GB) 3000Mhz CL15 /// Chassis: The AMAZING $30 "Computer Case"! /// PSU: Seasonic Focus GX-750 /// Storage: 1TB Samsung 860 EVO 2.5" SATA SSD + 240GB Transcend SSD220S 2.5" SATA SSD /// OS: Windows 10 Pro
Laptop (Asus UX430UN): CPU: Intel® Core™ i7-8550U Processor  /// GPU: NVIDIA GeForce MX150 /// RAM: 16GB 2133Mhz /// Storage: 512GB SanDisk SD8SN8U512G1002 (boot) /// OS: Windows 10 Home
Other Tech: Console: Xbox One S 1TB, Apple TV 4K /// Printer: Canon imageCLASS MF635Cx /// Phone: Apple iPhone 12 Pro Max 256GB Graphite (Daily Driver)  /// Tablet: Apple iPad 9.7-inch Wi-Fi (2018) 32GB + Apple Pencil (1st Generation) /// Headphones: Apple Airpods Pro, Sony WF-1000XM3, Sony WH-1000XM3 /// Smartwatch: Apple Watch Series 6 GPS Space Grey
Cameras: Bodies: Canon EOS-1D X Mark II, Canon EOS 5D Mark IV,  Sony A6000 /// Lenses: Canon EF 24-70mm F/2.8L USM, Canon EF 16-35mm F/2.8L II USM, Canon EF 70-200mm F/2.8L IS II USM, Tamron SP 150-600mm F/5-6.3 Di VC USD G2 (Canon), Sony SEL-P1650 E 16-50mm F3.5-5.6 PZ OSS /// Lighting: 2x Godox SL60-W Continuous LED, 2x Canon Speedlite 580EXII /// Tripods: Leofoto LS-324C Carbon Fiber Tripod + Leofoto LH-40 Ballhead, Leofoto MC-80 Multipurpose Clamp, Triopo DG-3 Gimbal Head /// Yes, I am a Canon Fanboy, deal with it
https://linustechtips.com/topic/1233649-using-a-second-gpu-for-display-outputs/
5 minutes ago, Not Wills said:
I would suggest putting open gl gpu to the 1050 and maybe put the the pisx gpu to the 1050 as well, not a expert.
tried that, no difference at all. still watching a very fast slideshow with both GPU usage about 50+%
Just now, Not Wills said:
very strange.
thing is its only occurring once i plug a display into the GTX 1050, once i unplug it i get RTX2080S usage at low 10s and 1050 at 0%
1 minute ago, AntiHero said:
Strange indeed, I'm doing roughly the same thing as you yet I don't have that issue, could it be a PSU or power management settings issue? just spit balling ideas but maybe try setting power mode to "prefer maximum performance"?
On windows side it has always been set to high performance and no sleep settings etc. I frequently do long renders on this pc (This is my main workstation) so I already had to make sure it won't try to save power etc since long ago.
PSU is a Corsair RM850i, I checked it out in iCUE and the power draw with only the RTX2080S is is 148W in 133W out, with the second gpu it was only about 30w higher? Don't exactly remember. I just pulled the card out for now as I can only really test at night and will have to continue with my work tomorrow morning (its 4am already lol).
So if anyone has any more ideas I'll try it tomorrow night to see if it works.
Also may I know what setup you are running?
huh, I haven't the faintest idea then.... and its not 4 4k monitors ill say that lol, just one asus 2k and 1k to make work easier but same cpu and ram, though i have the older 1070ti card for my main display, however i also use a 1050 to display the image on my second monitor.
Do you also happen to run wallpaper engine? As I tried launching a couple games just now (ATS and RIDE3) and they actually still run fine. Could even still have a YT chrome tab running with no stutters. So I have a slight suspicion it has something to do with the way Wallpaper Engine renders videos which makes windows and NVIDIA very unhappy.
I do not, so you maybe on to something there.
If wallpaper engine really is the culprit i guess i gotta make the decision between my wallpapers or a 5th monitor just to keep my whatsapp/discord/spotify up.
1 hour ago, AntiHero said:
well... there's always alt+tab lol
alt+tab isnt very useful when i have about 50 different windows of programs and references open, but well guess i’ll have to make do
