Hi guys,
So one day it worked fine, and the next (after a windows 10 update), it didn't.
My pc does not seem to be detecting our home wifi, plus a few more. I tried restarting the pc and the router, reinstalling the adaptor driver, and using an external usb wifi dongle. Non of which worked.
All other devices work fine.
Does anyone know what is happening?
Thanks
https://linustechtips.com/topic/1214508-pc-not-detecting-wifi/
28 minutes ago, Tiberiusmoon said:
Heya,
Go to section 3 of my guide and follow the windows update not working or OS issues.
https://tiberiusmoon.github.io/Tibs-Guide-to-Troubleshooting/
Then reinstall the driver, if the scans fail let me know. :)
Hey,
thanks for the reply.
The scan appears to be complete but I'm confused
after the first scan, it just got stuck at 100%, and I still can't type anything else in cmd.
I opened another instance of cmd and did the "sfc /scannow" command and it appears to have frozen too.
https://linustechtips.com/topic/1214508-pc-not-detecting-wifi/#findComment-13759237
