Help with external GPU for VR
Solved by Ominousdrake,
i would say that is an awful idea, you are going to waste 900 dollars on the core and rtx 2070 to have one of the biggest bottlenecks in history with that cpu. That is a Dual core wtih 3,5 ghz turbo boost . That CPU is half as powerful as the minimum recommended cpu for vr, minimum being lowest settings possible ( AMD Ryzen 3 3200G)
Doctah ·
Posted in Peripherals0 -
2
michaelb198 ·
Posted in Peripherals1 -
errorcode123_dindin1 ·
Posted in Graphics Cards2 -
Packhunter ·
Posted in Graphics Cards3 -
12
6
VirusDumb ·
Posted in Programming0 -
Jayraj ·
Posted in Power Supplies4
play_circle_filled
Latest From Linus Tech Tips:
play_circle_filled
Latest From ShortCircuit:
