Minecraft RTX beta not working?
Solved by VerTTi,
1 minute ago, Skiiwee29 said:if you're in the beta, go into your windows store and make sure your Minecraft is up to date. You may also need to uninstall and re-install it.
Restarted my pc and it downloaded the update had to wait about 20 mins in total dont know if the restart triggered the update but yeah.
Vibora ·
Posted in New Builds and Planning3 -
4
3
Doctah ·
Posted in Peripherals2 -
6
michaelb198 ·
errorcode123_dindin1 ·
Posted in Graphics Cards5 -
Packhunter ·
Posted in Graphics Cards6
