Hello greetings to all. I am writing to you this time because I own a Logitech Z5500, but suddenly the message "Mute ON Over Temperature" appeared on the POD, when I left the power button pressed if listen, but I can't do anything else. Any real solution to this problem? For what is this?
https://linustechtips.com/topic/1180236-help-logitech-z5500/
It appears some component of your sound system is overheating. To protect itself it mutes itself until it has cooled down.
Try feeling around where it might be hot and reposition that part in a way that allows it more airflow. If you can't find anything it might be false reporting
CPU: Ryzen 3700X VGA: RX 5700 8G RAM: 32GB 3200MT/s DDR4 Motherboard: B450 Aorus Pro
Storage: 2x1TB Crucial P2, 1TB Crucial MX500, 36TB NAS Cooling: Custom Loop 360mm & 280mm
PSU: Super Flower Golden Green HX 650W Case: Phanteks Enthoo Luxe
https://linustechtips.com/topic/1180236-help-logitech-z5500/#findComment-13498140
