Posted March 11, 2020 hello guys,first let me apology for my English. i have a problem with my hyper-v, when i am trying to connect to a vm i see the connection screen for a couple of seconds and then it crush with no errors. now ofc the virtualization is on on my bios and when i am using vmware workstation everything works perfectly. ill be happy to hear any idea and lead you have,thanks in advance my current home setup:cpu:amd ryzen 2700 // cpu cooler :aigo 120mm aio // mobo:gigabyte ab350-gaming 3 // ram:crosair vengance 8*4 // gpu:amd rx 5700 // tower:antec p8 // psu:antec HCG 650w. my current work setup: cpu:intel xeon x5675 // cpu cooler :generic 6 copper pipe // mobo: x58 lga 1366 chines motherboard // ram: 32GB ecc // gpu:amd r7 260x // psu:antec 550w. my current home server setup:cpu:intel xeon x5690 // cpu cooler :aigo 120mm aio // mobo: x58 lga 1366 chines motherboard // ram:crucial 8*2 // gpu:amd rx 580 // tower:antec p110 silent // psu:antec HCG 850w. Link to comment https://linustechtips.com/topic/1164047-hyper-v-problem/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 12, 2020 does this happens in both generation 1 and generation 2 VMs? Link to comment https://linustechtips.com/topic/1164047-hyper-v-problem/#findComment-13366862 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 12, 2020 Author 2 hours ago, BloodKnight7 said: does this happens in both generation 1 and generation 2 VMs? yep,they seem to be running in the background just with no option to connect to them. if ill give it a dozen tries ill end up being able to connect to one,but it would be temporary . my current home setup:cpu:amd ryzen 2700 // cpu cooler :aigo 120mm aio // mobo:gigabyte ab350-gaming 3 // ram:crosair vengance 8*4 // gpu:amd rx 5700 // tower:antec p8 // psu:antec HCG 650w. my current work setup: cpu:intel xeon x5675 // cpu cooler :generic 6 copper pipe // mobo: x58 lga 1366 chines motherboard // ram: 32GB ecc // gpu:amd r7 260x // psu:antec 550w. my current home server setup:cpu:intel xeon x5690 // cpu cooler :aigo 120mm aio // mobo: x58 lga 1366 chines motherboard // ram:crucial 8*2 // gpu:amd rx 580 // tower:antec p110 silent // psu:antec HCG 850w. Link to comment https://linustechtips.com/topic/1164047-hyper-v-problem/#findComment-13367041 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 12, 2020 It seems like a Hyper-V Manager problem. I would only recommend some obvious things like reinstalling Remote Server Administration Tools. As an alternative, you could try Windows Admin Center https://docs.microsoft.com/en-us/windows-server/manage/windows-admin-center/overview. It works via a web browser and offers similar functionality as other "thick" tools do. Link to comment https://linustechtips.com/topic/1164047-hyper-v-problem/#findComment-13367757 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 17, 2020 If you have another computer try installing Remote Server Administrator and add your hyper-v host to manage remotely, try connecting to a VM that way, that should clear it out. Link to comment https://linustechtips.com/topic/1164047-hyper-v-problem/#findComment-13378864 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted March 18, 2020 Author On 3/12/2020 at 3:27 PM, Net Runner said: It seems like a Hyper-V Manager problem. I would only recommend some obvious things like reinstalling Remote Server Administration Tools. As an alternative, you could try Windows Admin Center https://docs.microsoft.com/en-us/windows-server/manage/windows-admin-center/overview. It works via a web browser and offers similar functionality as other "thick" tools do. On 3/17/2020 at 8:12 AM, BloodKnight7 said: If you have another computer try installing Remote Server Administrator and add your hyper-v host to manage remotely, try connecting to a VM that way, that should clear it out. it seems like reinstalling windows solved the issue,thank you very much for the help my current home setup:cpu:amd ryzen 2700 // cpu cooler :aigo 120mm aio // mobo:gigabyte ab350-gaming 3 // ram:crosair vengance 8*4 // gpu:amd rx 5700 // tower:antec p8 // psu:antec HCG 650w. my current work setup: cpu:intel xeon x5675 // cpu cooler :generic 6 copper pipe // mobo: x58 lga 1366 chines motherboard // ram: 32GB ecc // gpu:amd r7 260x // psu:antec 550w. my current home server setup:cpu:intel xeon x5690 // cpu cooler :aigo 120mm aio // mobo: x58 lga 1366 chines motherboard // ram:crucial 8*2 // gpu:amd rx 580 // tower:antec p110 silent // psu:antec HCG 850w. Link to comment https://linustechtips.com/topic/1164047-hyper-v-problem/#findComment-13382999 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
