So i bought the Logitech X Pro gaming last week and i'm having some issue with the sound quality overall when using the USB DAC or the 3.5mm audio jack
When using the USB DAC there's a background sound that goes away if i put down the sound wheel on the in line cable but after that all sounds are kinda muted and sound distant
When using the audio jack, the sound is not present with the wheel being at 100% but the overall quality is bad
Step taken to resolve the issue
Uninstall Ghub and all Logitech drivers
Reboot, plug in DAC, updating drivers via Ghub then reboot
Same issue
Tried different games and different combinaison with audio jack or the USB DAC but the issue and sound quality is still bad
Wondering if thats a known issue or if a RMA is required here
Can't find anything online and running out of option here.
Thanks
CPU : i7-8700k  Mobo : Asus Prime z370-a RAM : G.Skill RipJaws V 16gb (2x8gb) Storage : 1tb Samsung 850 EVO
GPU : EVGA 1080 ti SC2 Cooling : Corsair H100i V2 PSU : Corsair Rm850x
https://linustechtips.com/topic/1163315-logitech-x-pro-gaming-issue/
