Problem with Graphic card:
Go to solution Solved by Fasauceome,
Fans, being the only mechanical part of a graphics card, degrade over time like all mechanisms. Doesn't necessarily mean dust is in there, could be a bum bearing. If the GPU is still in warranty, you could send it it, or look for a replacement fan on eBay.
Hi, I have an NVIDIA Geforce GTX 1080 Graphic driver, that makes a loud fan noise. There are two fans, but only one of them is making noise. I have tried to clean every single dust out with a compressor, but it didn't work. It gets hot, the speed of the fan raises, and it begin to make noise. Even after shutting the computer down, waiting hours it starts making noise at 4% GPU usage when i turn it on again. It's like it brakes itself, the fan gets really hot right in the middle. I am not able to replace the driver, but if there's an alternative, please tell me.
Sound stops if I brake fan with my finger.
https://linustechtips.com/topic/1151868-problem-with-graphic-card/
Primary PC:
PSU tier list
How many watts do I need?
Could be a cable under the gpu case hanging into the fan or a bad motor. You can buy those for like 10 bucks on amazon, also you could just take the fan of an old gpu (check it has the same voltage and less or same amps first) and solder on the cable of the old fan, then simply use tape to tape it to the old fans "socket". I ran my GTX 1060 with an XFX 7970GHZ fan for a year now, no problems.
I am NOT a native english speaker and use translate a lot, please do not take it literally and bear with me.
Alternatively you can always go the whole "takin' off the fan shroud and zip tying case fans to the heatsink" route
"TV Gaming" PC: Ryzen 5 5600 :: 32GB DDR4-3200 :: RTX 2070 Super :: 500GB PCIe 3.0 SSD :: 1.5TB of SATA SSDs :: Windows 11
"Desk Gaming" PC: i5-4690K :: 16GB DDR3-1600 :: RX 560D 4GB :: 500GB SATA SSD :: Linux Mint 22
Office PC: Dell Pro 14 :: Ultra 7 268V :: 32GB DDR5-8533 :: 512GB PCIe 4.0 NVMe :: 6TB HDD :: Windows 11
Laptop: Dell Latitude 15.6" :: i5-4200U :: 8GB DDR3-1600 :: 500GB SATA SSD :: Linux Mint 22
Primary NAS: i5-7500 :: 16GB DDR4-2133 :: 250GB SSD :: 8TB HDD :: TrueNAS Scale 24.10
Web Server/Backup NAS: Raspberry Pi 4 Model B :: 2GB RAM :: 64GB microSD card :: 8TB HDD :: Raspberry Pi OS
Other tech stuff: iPad Pro M4 13" :: Samsung Galaxy A15 4GB :: 2022 Kindle Fire HD 7 :: PS4 Slim w/ 1TB SSD :: OG Nintendo Switch
