OK, the yellow light is stuck on DRAM having a posting issue memory related.
So to start, you want to be sure the 2 memory sticks are in slots A2 and B2 and seated all the way in firmly when you hear the clicks, your in.
And resetting the cmos.
Page 22 in the manual
https://dlcdnets.asus.com/pub/ASUS/mb/LGA1151/TUF_Z390-PLUS_GAMING/E15523_TUF_Z390-PLUS_GAMING_UM_v3_web.pdf
https://linustechtips.com/topic/1147452-yellow-dram-led/#findComment-13232779
Just now, ShrimpBrime said:
Yes. If the PC doesn't post to display an image the monitor just informs the user there is no input signal.
Welcome
Ok this gives me hope. Thank you so much. My frustration level is going to have me chuck this thing out my apartment window lol
https://linustechtips.com/topic/1147452-yellow-dram-led/#findComment-13232820
I've been there..... many many times lol. And some things have flown, been smashed..... I even warped a motherboard with LN2 once or twice. Shh that's between me and you lol.
Hope it fires up for you.
https://linustechtips.com/topic/1147452-yellow-dram-led/#findComment-13232830
Ah I think I have found the issue.
Core i5-9600 (3.1GHz, 65W, L3:9M, 6C rev.U0) ALL 0805
Core i5-9600K (3.7GHz, 65W, L3:9M, 8C, rev.R0)  ALL 2203
In order to run the 9600 (K) model cpu, the bios needs to be updated to 2203.
That means you would have to purchase an i3 8100 or g4900 processor to upgrade the bios to support the 9600K model processor.
https://linustechtips.com/topic/1147452-yellow-dram-led/#findComment-13232925
In bios you want to go to boot tab. Find boot over ride select the DVD drive.
When prompted from disk, hit any key to continue. Quickly you only get 5 seconds.
The start setting up windows!
Glad it fired up. I was worried about the bios revision the board was shipped with. Looks like you're all good.
https://linustechtips.com/topic/1147452-yellow-dram-led/#findComment-13232951
Omg thanks for all your help!!! Much appreciated. Why is it working on Mini DisplayPort setting on monitor when I don’t have Mini DisplayPort cable plugged in but the regular one?
https://linustechtips.com/topic/1147452-yellow-dram-led/#findComment-13232975
Not sure thats a good question. You'll have to find the manual for the monitor to better under stand how it works.
I only Know processors motherboard Ram and some video card stuff :P
Glad I was able to help! Welcome!
https://linustechtips.com/topic/1147452-yellow-dram-led/#findComment-13232982
