I've just finished my new rig and always check if anything goes wrong, first the ram (already fixed) then the ssd (also already fixed). after all that my PC still wont post or even displaying anything but all parts is brand new my cable also brand new. If anyone can help please notify me
Specs:
Asus ROG strix z390-I
Intel Core I7 9700K 9th gen
2x8 3000mhz trident Z rgb
Corsair mp500 210gb
Seagate Barracuda 2tb 7200rpm
Asus ROG strix RTX 2060 super
Corsair H100I RGB
Corsair HX750
Corsair Crystal 280X rgb
https://linustechtips.com/topic/1138791-help-pc-wont-boot/
did you try taking it ALL apart and reassembling it? surprisingly solves 80% of the issues.
the other 19% is motherboard incompatibility.
CPU: Intel core i7-8086K Case: CORSAIR Crystal 570X RGB CPU Cooler: Corsair Hydro Series H150i PRO RGB Storage: Samsung 980 Pro - 2TB NVMe SSD PSU: EVGA 1000 GQ, 80+ GOLD 1000W, Semi Modular GPU: MSI Radeon RX 580 GAMING X 8G RAM: Corsair Dominator Platinum 64GB (4 x 16GB) DDR4 3200mhz Motherboard: Asus ROG STRIX Z370-E Gaming
https://linustechtips.com/topic/1138791-help-pc-wont-boot/#findComment-13163225
Thanks i reasembled my pc, it work now i think the pcie slot sort of not working sometimes
https://linustechtips.com/topic/1138791-help-pc-wont-boot/#findComment-13166574
