Hey everyone,
I'm looking at building a home server and I'm pretty lost at what I actually should be looking at for what I want it to do. I'm looking for it to run a local apache server for multiple computers in the house and light storage backups.
I have an old i5-4690k  sitting around doing nothing with lots of ram, is it worth re-using that chip for the server or buy server grade equipment?
Any help on this would be greatly appreciated.
https://linustechtips.com/topic/1133032-building-first-server-questions/
I would start off with any hardware you already have. Gain some knowledge and expand from there. My first "server" was a core2duo with a gig of ram and a couple random hard drives I had. Now i have a couple IBM x3650 M3's and a server I build from mostly old consumer parts. Expand to your needs.
i agree, that i5 of yours is probably faster than my main rig so it should be plenty fast enough for a simple apache server and some storage.
money making servers or mission critical machines tend to have ecc memory but in your case configuring your storage propperly so you dont loose all your data when a drive dies is way more important.
On 12/10/2019 at 10:49 AM, Ancestral said:
Hey everyone,
Very doable and much better option for light loads over an enterprise server, I have both but my home built rig is around my old pre built I7 6700 and it rocks I have not thrown anything at it that it could not handle currently running unRAID with 28TB of storage, running plex, sonarr, radarr, lidarr, jacket and Hassio to list a few
My daily driver: The Wrath of Red: OS Windows 10 home edition / CPU Ryzen TR4 1950x 3.85GHz / Cooler Master MasterAir MA621P Twin-Tower RGB CPU Air Cooler / PSU Thermaltake Toughpower 750watt / ASRock x399 Taichi / Gskill Flare X 32GB DDR4 3200Mhz / HP 10GB Single Port Mellanox Connectx-2 PCI-E 10GBe NIC / Samsung 512GB 970 pro M.2 / ASUS GeForce GTX 1080 STRIX 8GB / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor x3
My technology Rig: The wizard: OS Windows 10 home edition / CPU Ryzen R7 1800x 3.95MHz / Corsair H110i / PSU Thermaltake Toughpower 750watt / ASUS CH 6 / Gskill Flare X 32GB DDR4 3200Mhz / HP 10GB Single Port Mellanox Connectx-2 PCI-E 10GBe NIC / 512GB 960 pro M.2 / ASUS GeForce GTX 1080 STRIX 8GB / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor HP Monitor
My I don't use RigOS Windows 10 home edition / CPU Ryzen 1600x 3.85GHz / Cooler Master MasterAir MA620P Twin-Tower RGB CPU Air Cooler / PSU Thermaltake Toughpower 750watt / MSI x370 Gaming Pro Carbon / Gskill Flare X 32GB DDR4 3200Mhz / Samsung PM961 256GB M.2 PCIe Internal SSDEVGA GeForce GTX 1050 Ti SSC GAMING / Acer - H236HLbid 23.0" 1920x1080 60Hz Monitor
My NAS: The storage miser: OS unRAID v. 6.9.0-beta25 / CPU Intel i7 6700 / Cooler Master MasterWatt Lite 500 Watt 80 Plus / ASUS Maximus viii Hero / 32GB Gskill RipJaw DDR4 3200Mhz / HP Mellanox ConnectX-2 10 GbE PCI-e G2 Dual SFP+ Ported Ethernet HCA NIC / 9 Drives total 29TB - 1 4TB seagate parity - 7 4TB WD Red data - 1 1TB laptop drive data - and 2 240GB Sandisk SSD's cache / Headless
Why did I buy this server: OS unRAID v. 6.9.0-beta25 / Dell R710 enterprise server with dual xeon E5530 / 48GB ecc ddr3 / Dell H310 6Gbps SAS HBA w/ LSI 9211-8i P20 IT / 4 450GB sas drives / headless
Just another server: OS Proxmox VE / Dell poweredge R410
