I have a budget of around 550$ or upto 40000inr.
For the Gpu I have decided to go for Gtx 1660 (Galax 1 click-OC) FOR 16,500 inr 230$.(I can consider another option )
The CPU I am not sure which to pair it with likely a r5 2600 or the r5 3500. Suggestions are needed..
Price: around 13500 INR and 11500 INR respectively.
The motherboard I am not sure which to take!.?Please help.
I don't think I would overclock but it would be a good feature to have.
For ram thinking of going with Adata 8gbx2 stick of 3000mhz for around 5600inr or 80$.
I don't have any option for PSU,CABINET,STORAGE.
Really need help.
Also if there are any other recommendations would be really glad.
I would use the PC for gaming like 70% and 30% productivity.
https://linustechtips.com/topic/1127020-help-for-550-build/
I would strongly recommend this GPU.  It will be notably faster in games, and WAY better for HEDT work.
https://www.ebay.com/itm/MSI-Radeon-RX-Vega-56-DirectX-12-Air-Boost-8G-OC-8GB-Graphics-Card/184047738226?epid=10028679558&hash=item2ada199d72:g:V8gAAOSwTg5d2EII
This CPU will also give you what you need for gaming at this price point, while still having enough cores to hold its own in creative work.
https://www.ebay.com/itm/AMD-YD1600BBAEBOX-Ryzen-5-1600-32GHz-6-Core-AM4-Processor-with-Wraith-Spire/163958657398?hash=item262cb29176%3Ag%3ACw4AAOSwwY5dVB6D&LH_BIN=1
If you can find a 2600 locally for less get it, but otherwise this is your best bet to stay on target with your budget.
I edit the shit out of my posts.  Refresh before you respond.
https://linustechtips.com/topic/1127020-help-for-550-build/#findComment-13073067
I think for my purpose and after watching 100s of reviews, benchmarks I think 1660 is the one I want to go with.
Also I can extend my budget like to 45000k INR, so any CPU which would satisfy.
Also help for other components too☹️
https://linustechtips.com/topic/1127020-help-for-550-build/#findComment-13073172
Alright, you're leaving a lot of performance to be desired with that GPU, but here's what I'd go with.
https://pcpartpicker.com/user/spitty84/saved/#view=6c6Gcf
https://linustechtips.com/topic/1127020-help-for-550-build/#findComment-13073175
Often the RX 580 is less expensive. They perform neck and neck. You could save a fair amount and get the same or better performance. You could likely find a 590 in that price range which is closer to a 1660Ti.
https://linustechtips.com/topic/1127020-help-for-550-build/#findComment-13073210
I know its a tough pill to swallow, but unless your are getting a titan rtx or 2080ti,  AMD has nVidia beat by a notable margin at nearly every price point.  A lot of YouTube reviewers won't admit it it, but:
-At $100 (very common on eBay), the rx 480/570/580 reigns supreme.
-At $200, the vega 56 flashed witha  64 bios is your best bet, (you might find a 1070 on eBay this price point, but is notably slower in non-nVidia optimized titles)
-At $300, its the 5700, again with the ability to deliver XT performance through a VERY simple bios flash.
-At $400, you can geta  5700Xt with a good 3rd party radiator.
As it sits right now, the 5700xt (and the flashed 5700) can outperform the 2080 in certain titles, and is slightly behind it in others.  DX12 and Vulkan seem to be the key here.  (In world war z the vega 64 beats the 2080ti).
https://linustechtips.com/topic/1127020-help-for-550-build/#findComment-13073243
I live in India so the prices are really really high here.
https://mdcomputers.in/index.php?category_id=0&search=rx+580&submit_search=&route=product%2Fsearch
check this out the same damn price..
https://linustechtips.com/topic/1127020-help-for-550-build/#findComment-13073261
That sapphire Pulse cooled RX 580 8GB for 14,999inr has more Vram, comparable/better performance, better cooler, and you save about $30.
At $550 budget, cut where you can!
https://linustechtips.com/topic/1127020-help-for-550-build/#findComment-13073354
