Hey I have bought G.Skill Sniper 2x8 @1600 RAMs and I use a Asus Maximus VI Impact and a Noctua NH-L12. So i want to try installing another 120mm fan but I  think (not tried it yet) that the RAMs are to high. Now i know you can remove heatsink from the RAM but how bad is it really for the temps ? will it be just 1-5C° more and will it be a problem for the RAM? Can I mount the Heatsink back? best would be if someone has this RAMs and tested it allready :D
thx for u help guys
and as allways, sorry for my bad english :D
  • CPU: Intel i7 4790K watercooled & custom IHS, Motherboard: Asus Maximus VI Impact, RAM: Kingston HyperX LP 1833, 2x8GB, GPU: Asus RTX 2070 watercooled
CasePhanteks Enthoo Evolv ITXStorage: 1x WD Black 4TB HDD, 2x WD Blue 1TB SSD in Raid 0, PSU: Seasonic 650w Gold, Cooling: all watercoold with 2x 240 slim Rads, 5 Lian-Li Unifans
https://linustechtips.com/topic/112343-remove-ram-heatsink-temp-problems/
1600 Shouldn't be a problem without a heatsink.
Andres "Bluejay" Alejandro Montefusco - The Forums Favorite Bird!!!
Top Clock: 7.889 Ghz Cooled by: Liquid Helium
#ChocolateRAM #OatmealFans #ScratchItHarder #WorstcardBestoverclocker #CrazySexStories #SchnitzelQuest TS3 SERVER
Not that bad, though I've no experience with stripped RAM's. Then 120 fan you want to put on the NH-L12 i figure is instead of the 92mm(or whatever sixe it is) one, right? There will get blown air directly on the RAM. About the temperature; I've heard that 'stripped' RAM isn't really a matter @ 1600 (or lower), though I could be wrong.
They're usually fairly stuck on. You may rip something off because of the glue that is used.
The RAM sticks may get too hot to run but you could frankenstein on a low profile heat spreader from another ram kit. (if you're keen on modding, and know how to)
EDIT: didn't see that they were 1600mhz... so should be fine with heat I think.
thx for u help guys
    CPU: 3930k  @ stock                                  RAM: 32GB RipjawsZ @ 2133Mhz       Cooling: Custom Loop
MOBO: AsRock x79 Extreme9                      SSD: 240GB Vertex 3 (OS)                     Case: HAF XB                     LG 34um95 + Ergotron MX Arm Mount - Dual Review
  GPUs: Gigabyte GTX 670 SLI                     HDD: 1TB WD Black                                PSU: Corsair AX 860                               Beyerdynamic - Custom One Pro Review
