So hundred percent all on the table I am a Mac guy coming over to light side as one may say. I decided to build my first gaming PC and everything has gone relativelI well  until tonight when I tried to install windows 10. I've been trying without any success for the last few hours to bring my PC to life for the first time and have been having zero luck. For whatever reason I can not boot windows 10 from the included thumb drive directly from Microsoft.  I haven't had time to reach out to them since all this is coming into play right now and they are closed. So I am turning to anyone for some help I have taken a screenshot of what the computer does when it gets to the windows logo.     what happens is when I try and upload the os I get to the screen in the pitcher it gets to the loading circle and it just stops and just sits there and will not go forward. I have no experience in this so I have no idea but that's part of the fun. listed below is the hardware I have feel free to ask any questions.
 any help will be really welcomed thanks
list of my hardware
gtx 1660 ti - Intel i7 - CORSAIR Vengeance RGB PRO 16GB (2PK 8GB - sandisk 240 gig ssd - CORSAIR - Hydro Series H100i RGB Platinum 120mm Processor Liquid Cooling System - msi MPG Z390 GAMING EDGE AC - Thermaltake V200 Tempered Glass RGB Edition 12V MB Sync
80def373ad768442ce775c8d660a7c6aaa3b2caf.rtfd.zip
https://linustechtips.com/topic/1111114-my-pc-first-build/
Oh we're definitely the dark side
Did you use the live chat? I find that one to be most effective.
As for a windows installer, you could try to make a new one, do you have access to a windows PC, like a laptop or friend's desktop?
Also to share your specs
It's real easy to use pcpartpicker.com
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1111114-my-pc-first-build/#findComment-12945843
