Will A GTX 780 work?
Hey guys! I was wondering if a GTX 780 Lightning would work with an EVGA GTX 780 Superclocked? From my knowledge there should be no problem. Also will there be heat problems with one of the cards? Also what do you guys think of a lighting on top and a reference on the bottom, personally I think it would cool! Thanks for the help! :)
https://linustechtips.com/topic/110028-will-a-gtx-780-work/
Yes, just make sure they are at the same clock speed, etc.
My PC:
CPU: Xeon E3 1230 V3(Haswell) @ 3.7GHz Motherboard: AsRock B85M-ITX RAM: 8GB Corsair Vengeance LP Blue @ 1600MHz Storage: Intel 520 Series 120(Boot), Seagate Barracuda 500GB @ 7200RPM, Western Digital Caviar Green 1TB @ 5400RPM GPU: ZOTAC GTX 970 @ 1.4GHz Case: Node 304 Power Supply: CX430
https://linustechtips.com/topic/110028-will-a-gtx-780-work/#findComment-1469973
I assume they do that automatically?
Depends. Just make sure to check it in your BIOS/UEFI.
My PC:
https://linustechtips.com/topic/110028-will-a-gtx-780-work/#findComment-1469985
It always sets itself to lowest card
Hope I could help!
Specs: CPU: AMD FX-8320 @4.0ghz GPU: ASUS DCUII GTX 770 PSU: EVGA Supernova 750g CASE: Fractal Define R4 RAM: 8 Gigabytes ADATA 1333 Mhz MOBO: GIGABYTE GA-990FXA-UD3
https://linustechtips.com/topic/110028-will-a-gtx-780-work/#findComment-1470050
