Homebridge Config Help
Go to solution Solved by TheLawyerMan,
Solved
Can someone please help me fix this:
This is the code: https://pastebin.com/Da6maaKq
My Desktop:
CPU: Intel Core i9 9900K
CPU Cooler: Corsair iCUE H100i ELITE CAPELLIX
Motherboard: ASUS ROG Strix Z390-E Gaming (for gamers)
RAM: 4x16 GB G.Skill Trident Z RGB 3200 MHz
GPU: ASUS ROG Strix RTX 2060 Super OC
SSDs: Samsung 980 Pro (1TB), 870 Evo (1 TB), 860 Evo (1 TB), 860 Evo (500 GB)
HDD: Seagate Barracuda Compute (8 TB)
PSU: Corsair RMx 1000W w/ CableMod cables
OS: Windows 10 Pro
Case: Corsair SPEC-06 RGB
Monitors: LG 34GL750-B, Samsung CF591
Pegasus (Server):
CPU: AMD EPYC Rome 7282
CPU Cooler: Noctua NH-U12S TR4-SP3
Motherboard: SuperMicro H12SSL-CT
RAM: 4x16 GB Samsung 3200 MHz DDR4 ECC (M393A2K40DB3-CWE)
GPU: PNY NVIDIA Quadro P2200
SSDs: Samsung 970 Evo (1 TB), WD Red SA500 (1 TB), SanDisk Ultra 3D (500 GB)
HDDs: 5x Seagate IronWolf NAS 8TB
HBA:  Avago LSI 9211-8i
PSU: Athena Power AP-RRPS2K20
OS: unRAID
Chassis: Rosewill RSV-L4500
Chassis Fans: 6x Noctua F12 PWM, 2x Noctua A8 PWM
https://linustechtips.com/topic/1099042-homebridge-config-help/
By the way, don't try these accounts, I changed the info to be something fake. Same concept though.
My Desktop:
OS: Windows 10 Pro
Pegasus (Server):
OS: unRAID
https://linustechtips.com/topic/1099042-homebridge-config-help/#findComment-12851175
Solved
My Desktop:
OS: Windows 10 Pro
Pegasus (Server):
OS: unRAID
https://linustechtips.com/topic/1099042-homebridge-config-help/#findComment-12851368
