So recently when i'm playing games like apex legends, league of legends, fortnite, etc.. i've only been able to play for about 10 mins before I blue screen and get this error. Naturally i went to google followed a bunch of tutorials concerning the memory diagnostic check thingy and every time I've run it, it hasn't detected an issue with my ram but I've been crashing every time I play any type of game. I would really appreciate some help here to find a solution for this as its quite bothersome.
Edit I've also gotten a Kernel Heap Corruption Error Code too that probably has something to do with it
https://linustechtips.com/topic/1095921-memory-management-bsod-fix/
Full System Specs?
Community Standards
"Beast Mode"
Dedicated Streaming Rig
12 minutes ago, QuateyThaQt said:
Asus Rog Strix 2080ti 11gb
Amd Ryzen 7 3700x
32gb corsair vengeance lpx (2x16gb)
1tb Samsung 970 evo m.2 ssd
1tb Samsung 850 evo ssd
Corsair rmx750 psu
Memory management issues are usually from not enough voltage with the DRAM or SOC voltages. Try manually setting your SOC voltage to 1.15v. You are safe to up this voltage level until 1.2v for 24/7 usage.
Community Standards
"Beast Mode"
How does one go about doing that. never mind figured it out
in your BIOS.
Community Standards
"Beast Mode"
This AMD/RAM compatibility will never end.......
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
i had this exact issue before have you tampered with the ram physically? i only ask as i was putting rgb heatsinks on my vengeance ram and in the process damaged one of the chips removing the heatsink the pads glue was so strong it nearly ripped the memory module off
i would remove 1 stick at a time then boot and game for a while if it happens with 1 stick swap them out n try again if it happens again its a really low chance both sticks are bad or an underlying fault on the mobo as im guessing the bios is stock as you dont have a clue how to set voltages in the bios
oh and dl ryzen master (dont change anything though) and post a screenshot that would tell us your voltage n so on
