What's the price difference like? Your current RAM is bottlenecking the hell out of that CPU.
IMO, go with the 3000MHz set. 2nd gen Ryzen is tested at a max of 2933MHz so anything above that is technically an "overclock". I'm using 16GB of Vengeance 3000Mhz on my 2600X and it's running great.
PC Interest - Thriving | Wallet Status - Near Empty
Ryzen 9 5900X, ASUS TUF RTX 4080
Corsair Vengeance LPX (2 x 16GB) 3600MHz, ROG Crosshair VIII Dark Hero
https://linustechtips.com/topic/1094842-need-help-to-pick-ram/#findComment-12814751
Theres not much  difference in price really depends on what ram i go for and i been looking at 3000mhz vengeance pro with rgb my pc started has a low buget and now its slowly getting there and thank you for a reply i upgrading them to a 16gb 3000hmz
https://linustechtips.com/topic/1094842-need-help-to-pick-ram/#findComment-12815254
