cron job help
Go to solution Solved by Skiiwee29,
18 minutes ago, vorticalbox said:
that is a shame :/
you should be able to use the ceon i posted and then poi t it to a sh script
https://www.geeksforgeeks.org/how-to-setup-cron-jobs-in-ubuntu/
so after searching more and doing more and more research, I was able to find a way to get a KRON job up on the Cisco device that should do the trick I need.
Hey guys, In a pickle here and I am very lost... need to create a cron job on a linux server to SSH over to a different device and run a certain command on a 4hr timer. I have the timer written.. I think? But I honestly have no clue how to write the bash script to execute it. This is in a CentOS based linux server.
Here is the cron job I came up with based on quick research.
30 0,4,8,12,16,20 * * * /root/bash script file
From my understanding, this should tell the server that at 30 minutes past every 4hrs it should execute correct?
Its simple, its needs to SSH over to the device and run a single command and thats it. Any help would be greatly appreciated.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1089856-cron-job-help/
Why not run the corn job of the other device and avoid remote shells?
0 */4 * * * should run every 4 hours
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
https://linustechtips.com/topic/1089856-cron-job-help/#findComment-12774764
Its a cisco ASR1K router, which to my knowledge has no support for scripting jobs.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/1089856-cron-job-help/#findComment-12774774
that is a shame :/
https://linustechtips.com/topic/1089856-cron-job-help/#findComment-12774794
2 minutes ago, vorticalbox said:
that is a shame :/
Right, but I dont know how to write/format the sh script.. thats the part I need help with mostly.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/1089856-cron-job-help/#findComment-12774800
that is a shame :/
Community Standards
"Beast Mode"
https://linustechtips.com/topic/1089856-cron-job-help/#findComment-12774843
