Issue with dual monitors
Solved by KingDonkus,
So after a lot of searching and updating all sorts of drivers I believe I have figured out my problem. I only write this in hope one day someone with the same problem will see this and it'll help them. So I updated my nvidia drivers right before I started having the problem and rather the drivers had a bug or I some how downloaded the notebook version of the drivers. So my system would work but after using a program or I'm assuming any real graphical processing it would lock up which ever screen was not currently active. I rolled my drivers back to a couple generations, did a clean install (deleting all old versions) and all my problems have gone away, everything seems to be back to normal and working very well again.
