The server started, and it seemed to function correctly for some time, but after awhile I got kicked and whenever I rejoined I either timed out or just disconnected.
Here's the log file:
[18:55:00] [main/INFO] [LaunchWrapper]: Loading tweak class name net.minecraftforge.fml.common.launcher.FMLServerTweaker
[18:55:00] [main/INFO] [LaunchWrapper]: Using primary tweak class name net.minecraftforge.fml.common.launcher.FMLServerTweaker
[18:55:00] [main/INFO] [LaunchWrapper]: Calling tweak class net.minecraftforge.fml.common.launcher.FMLServerTweaker
[18:55:00] [main/INFO] [FML]: Forge Mod Loader version 14.23.5.2838 for Minecraft 1.12.2 loading
[18:55:00] [main/INFO] [FML]: Java is Java HotSpot(TM) 64-Bit Server VM, version 1.8.0_211, running on Windows 10:amd64:10.0, installed at C:\Program Files\Java\jre1.8.0_211
[18:55:01] [main/INFO] [FML]: Searching C:\Users\carso\OneDrive\Desktop\Chadcraft 1.0 server\.\mods for mods
[18:55:01] [main/WARN] [FML]: Found FMLCorePluginContainsFMLMod marker in CTM-MC1.12.2-0.3.3.22.jar. This is not recommended, @Mods should be in a separate jar from the coremod.
[18:55:01] [main/WARN] [FML]: The coremod team.chisel.ctm.client.asm.CTMCorePlugin does not have a MCVersion annotation, it may cause issues with this version of Minecraft
[18:55:01] [main/WARN] [FML]: The coremod CTMCorePlugin (team.chisel.ctm.client.asm.CTMCorePlugin) is not signed!
[18:55:01] [main/WARN] [FML]: Found FMLCorePluginContainsFMLMod marker in cxlibrary-1.12.1-1.6.1.jar. This is not recommended, @Mods should be in a separate jar from the coremod.
[18:55:01] [main/WARN] [FML]: The coremod cubex2.cxlibrary.CoreModLoader does not have a MCVersion annotation, it may cause issues with this version of Minecraft
[18:55:01] [main/WARN] [FML]: The coremod CXLibraryCore (cubex2.cxlibrary.CoreModLoader) is not signed!
[18:55:01] [main/WARN] [FML]: Found FMLCorePluginContainsFMLMod marker in mclib-1.0.2-1.12.2.jar. This is not recommended, @Mods should be in a separate jar from the coremod.
[18:55:01] [main/WARN] [FML]: The coremod McLib core mod (mchorse.mclib.core.McLibCM) is not signed!
[18:55:01] [main/INFO] [LaunchWrapper]: Loading tweak class name net.minecraftforge.fml.common.launcher.FMLInjectionAndSortingTweaker
[18:55:01] [main/INFO] [LaunchWrapper]: Loading tweak class name net.minecraftforge.fml.common.launcher.FMLDeobfTweaker
[18:55:01] [main/INFO] [LaunchWrapper]: Calling tweak class net.minecraftforge.fml.common.launcher.FMLInjectionAndSortingTweaker
[18:55:01] [main/INFO] [LaunchWrapper]: Calling tweak class net.minecraftforge.fml.relauncher.CoreModManager$FMLPluginWrapper
[18:55:03] [main/INFO] [FML]: Found valid fingerprint for Minecraft Forge. Certificate fingerprint e3c3d50c7c986df74c645c0ac54639741c90a557
[18:55:03] [main/INFO] [LaunchWrapper]: Calling tweak class net.minecraftforge.fml.relauncher.CoreModManager$FMLPluginWrapper
[18:55:03] [main/INFO] [LaunchWrapper]: Calling tweak class net.minecraftforge.fml.common.launcher.FMLDeobfTweaker
[18:55:03] [main/INFO] [LaunchWrapper]: Loading tweak class name net.minecraftforge.fml.common.launcher.TerminalTweaker
[18:55:03] [main/INFO] [LaunchWrapper]: Calling tweak class net.minecraftforge.fml.common.launcher.TerminalTweaker
[18:55:04] [main/INFO] [EnderCore ASM]: Transforming net.minecraft.entity.player.EntityPlayer finished, added func_184613_cA() overriding EntityLivingBase
[18:55:04] [main/INFO] [LaunchWrapper]: Launching wrapped minecraft {net.minecraft.server.MinecraftServer}
[18:55:04] [main/INFO] [STDOUT]: [team.chisel.ctm.client.asm.CTMTransformer:preTransform:230]: Transforming Class [net.minecraft.block.Block], Method [getExtendedState]
[18:55:04] [main/INFO] [STDOUT]: [team.chisel.ctm.client.asm.CTMTransformer:finishTransform:242]: Transforming net.minecraft.block.Block Finished.
[18:55:06] [main/INFO] [EnderCore ASM]: Transforming Class [net.minecraft.entity.ai.EntityAICreeperSwell], Method [func_75246_d]
[18:55:06] [main/INFO] [EnderCore ASM]: Transforming net.minecraft.entity.ai.EntityAICreeperSwell Finished.
[18:55:07] [main/INFO] [EnderCore ASM]: Transforming Class [net.minecraft.inventory.ContainerFurnace], Method [func_82846_b]
[18:55:07] [main/INFO] [EnderCore ASM]: Transforming net.minecraft.inventory.ContainerFurnace Finished.
[18:55:07] [Server thread/INFO] [net.minecraft.server.dedicated.DedicatedServer]: Starting minecraft server version 1.12.2
[18:55:07] [Server thread/INFO] [FML]: MinecraftForge v14.23.5.2838 Initialized
[18:55:07] [Server thread/INFO] [FML]: Starts to replace vanilla recipe ingredients with ore ingredients.
[18:55:07] [Server thread/INFO] [FML]: Invalid recipe found with multiple oredict ingredients in the same ingredient...
[18:55:07] [Server thread/INFO] [FML]: Replaced 1227 ore ingredients
[18:55:08] [Server thread/INFO] [FML]: Searching C:\Users\carso\OneDrive\Desktop\Chadcraft 1.0 server\.\mods for mods
[18:55:08] [Server thread/WARN] [FML]: Mod codechickenlib is missing the required element 'version' and a version.properties file could not be found. Falling back to metadata version 3.2.1.351
[18:55:08] [Server thread/INFO] [FML]: Disabling mod ctm it is client side only.
[18:55:09] [Server thread/WARN] [FML]: Mod enderstorage is missing the required element 'version' and a version.properties file could not be found. Falling back to metadata version 2.4.5.135
[18:55:10] [Server thread/WARN] [FML]: Mod patchouli is missing the required element 'version' and a version.properties file could not be found. Falling back to metadata version 1.0-20
[18:55:11] [Server thread/WARN] [FML]: Mod veinminer is missing the required element 'version' and a version.properties file could not be found. Falling back to metadata version 0.38.2
[18:55:11] [Server thread/WARN] [FML]: Mod veinminermodsupport is missing the required element 'version' and a version.properties file could not be found. Falling back to metadata version 0.38.2
[18:55:11] [Server thread/INFO] [FML]: Forge Mod Loader has identified 47 mods to load
[18:55:11] [Server thread/WARN] [FML]: Missing English translation for FML: assets/fml/lang/en_us.lang
[18:55:11] [Server thread/WARN] [FML]: Mod mclib_core has been disabled through configuration
[18:55:11] [Server thread/WARN] [FML]: Missing English translation for codechickenlib: assets/codechickenlib/lang/en_us.lang
[18:55:11] [Server thread/WARN] [FML]: Missing English translation for cxlibrary: assets/cxlibrary/lang/en_us.lang
[18:55:11] [Server thread/WARN] [FML]: Missing English translation for dldungeonsjbg: assets/dldungeonsjbg/lang/en_us.lang
[18:55:11] [Server thread/WARN] [FML]: Missing English translation for enderiobase: assets/enderiobase/lang/en_us.lang
[18:55:11] [Server thread/WARN] [FML]: Missing English translation for enderioconduitsappliedenergistics: assets/enderioconduitsappliedenergistics/lang/en_us.lang
[18:55:11] [Server thread/WARN] [FML]: Missing English translation for enderioconduitsopencomputers: assets/enderioconduitsopencomputers/lang/en_us.lang
[18:55:11] [Server thread/WARN] [FML]: Missing English translation for enderioconduitsrefinedstorage: assets/enderioconduitsrefinedstorage/lang/en_us.lang
[18:55:11] [Server thread/WARN] [FML]: Missing English translation for enderioconduits: assets/enderioconduits/lang/en_us.lang
[18:55:11] [Server thread/WARN] [FML]: Missing English translation for enderiointegrationforestry: assets/enderiointegrationforestry/lang/en_us.lang
[18:55:11] [Server thread/WARN] [FML]: Missing English translation for enderiointegrationtic: assets/enderiointegrationtic/lang/en_us.lang
[18:55:11] [Server thread/WARN] [FML]: Missing English translation for enderiointegrationticlate: assets/enderiointegrationticlate/lang/en_us.lang
[18:55:11] [Server thread/WARN] [FML]: Missing English translation for enderiomachines: assets/enderiomachines/lang/en_us.lang
[18:55:11] [Server thread/WARN] [FML]: Missing English translation for enderiopowertools: assets/enderiopowertools/lang/en_us.lang
[18:55:11] [Server thread/WARN] [FML]: Missing English translation for mantle: assets/mantle/lang/en_us.lang
[18:55:11] [Server thread/WARN] [FML]: Missing English translation for radixcore: assets/radixcore/lang/en_us.lang
[18:55:11] [Server thread/WARN] [FML]: Missing English translation for roguelike: assets/roguelike/lang/en_us.lang
[18:55:11] [Server thread/WARN] [FML]: Missing English translation for ruins: assets/ruins/lang/en_us.lang
[18:55:11] [Server thread/WARN] [FML]: Missing English translation for veinminermodsupport: assets/veinminermodsupport/lang/en_us.lang
[18:55:11] [Server thread/INFO] [FML]: FML has found a non-mod file CTM-MC1.12.2-0.3.3.22.jar in your mods directory. It will now be injected into your classpath. This could severe stability issues, it should be removed if possible.
[18:55:11] [Server thread/INFO] [FML]: FML has found a non-mod file AutoSave-1.12.2-1.0.10.jar in your mods directory. It will now be injected into your classpath. This could severe stability issues, it should be removed if possible.
[18:55:11] [Server thread/INFO] [FML]: FML has found a non-mod file AutoConfig-1.12.2-1.0.2.jar in your mods directory. It will now be injected into your classpath. This could severe stability issues, it should be removed if possible.
[18:55:12] [Server thread/INFO] [FML]: Attempting connection with missing mods [minecraft, mcp, FML, forge, baubles, bewitchment, botania, chancecubes, chisel, codechickenlib, cxlibrary, dldungeonsjbg, endercore, enderio, enderiobase, enderioconduitsappliedenergistics, enderioconduitsopencomputers, enderioconduitsrefinedstorage, enderioconduits, enderiointegrationforestry, enderiointegrationtic, enderiointegrationticlate, enderiomachines, enderiopowertools, enderstorage, fluidcows, grapplemod, hats, ichunutil, jei, journeymap, mantle, mca, mclib, morefurnaces, patchouli, projecte, radixcore, rafradek_tf2_weapons, roguelike, ruins, tconstruct, thaumcraft, veinminer, veinminermodsupport, llibrary] at CLIENT
[18:55:12] [Server thread/INFO] [FML]: Attempting connection with missing mods [minecraft, mcp, FML, forge, baubles, bewitchment, botania, chancecubes, chisel, codechickenlib, cxlibrary, dldungeonsjbg, endercore, enderio, enderiobase, enderioconduitsappliedenergistics, enderioconduitsopencomputers, enderioconduitsrefinedstorage, enderioconduits, enderiointegrationforestry, enderiointegrationtic, enderiointegrationticlate, enderiomachines, enderiopowertools, enderstorage, fluidcows, grapplemod, hats, ichunutil, jei, journeymap, mantle, mca, mclib, morefurnaces, patchouli, projecte, radixcore, rafradek_tf2_weapons, roguelike, ruins, tconstruct, thaumcraft, veinminer, veinminermodsupport, llibrary] at SERVER
[18:55:12] [Server thread/ERROR] [FML]: The mod bewitchment is expecting signature @FINGERPRINT@ for source Bewitchment-1.12.2-0.0.19.48-indev.jar, however there is no signature matching that description
[18:55:12] [Server thread/WARN] [Bewitchment]: !! WARNING: The mod Bewitchment has an invalid signature, this is likely due to someone messing with the jar without permission!
[18:55:14] [Server thread/INFO] [EnderCore Mixins]: Found annotation mixin: crazypants.enderio.base.paint.MobilityFlagForPaintedBlocksMixin
[18:55:14] [Server thread/INFO] [EnderCore Mixins]: Registered mixin.
[18:55:14] [Server thread/INFO] [EnderCore Mixins]: Found annotation mixin: crazypants.enderio.base.item.darksteel.upgrade.DarkSteelUpgradeMixin
[18:55:14] [Server thread/INFO] [EnderCore Mixins]: Found annotation mixin: crazypants.enderio.base.power.forge.item.InternalPoweredItemMixin
[18:55:14] [Server thread/INFO] [EnderCore Mixins]: Found annotation mixin: crazypants.enderio.base.integration.thaumcraft.ThaumcraftArmorMixin
[18:55:14] [Server thread/INFO] [EnderCore Mixins]: Found mixin source class data for crazypants.enderio.base.paint.MobilityFlagForPaintedBlocksMixin.
[18:55:14] [Server thread/INFO] [EnderCore Mixins]: Found mixin source class data for crazypants.enderio.base.item.darksteel.upgrade.DarkSteelUpgradeMixin.
[18:55:14] [Server thread/INFO] [EnderCore Mixins]: Found interface target crazypants.enderio.api.upgrades.IDarkSteelItem
[18:55:14] [Server thread/INFO] [EnderCore Mixins]: Found mixin source class data for crazypants.enderio.base.power.forge.item.InternalPoweredItemMixin.
[18:55:14] [Server thread/INFO] [EnderCore Mixins]: Found interface target crazypants.enderio.base.power.forge.item.IInternalPoweredItem
[18:55:14] [Server thread/INFO] [EnderCore Mixins]: Found mixin source class data for crazypants.enderio.base.integration.thaumcraft.ThaumcraftArmorMixin.
[18:55:14] [Server thread/INFO] [EnderCore Mixins]: Found interface target crazypants.enderio.base.paint.IPaintable$ISolidBlockPaintableBlock
[18:55:14] [Server thread/INFO] [EnderCore Mixins]: Found interface target crazypants.enderio.base.paint.IPaintable$IBlockPaintableBlock
[18:55:14] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.base.item.darksteel.ItemDarkSteelArmor from implemented interfaces: [crazypants/enderio/api/upgrades/IDarkSteelItem]
[18:55:14] [Server thread/INFO] [EnderCore Mixins]: Patching 2 mixins onto class crazypants.enderio.base.item.darksteel.ItemDarkSteelArmor
[18:55:14] [Server thread/INFO] [EnderCore Mixins]: Added 3 new interfaces: [thaumcraft/api/items/IVisDiscountGear, thaumcraft/api/items/IGoggles, thaumcraft/api/items/IRevealer]
[18:55:14] [Server thread/INFO] [EnderCore Mixins]: Added 3 new methods: [showNodes(Lnet/minecraft/item/ItemStack;Lnet/minecraft/entity/EntityLivingBase;)Z, showIngamePopups(Lnet/minecraft/item/ItemStack;Lnet/minecraft/entity/EntityLivingBase;)Z, getVisDiscount(Lnet/minecraft/item/ItemStack;Lnet/minecraft/entity/player/EntityPlayer;)I]
[18:55:14] [Server thread/INFO] [EnderCore Mixins]: Added 3 new methods: [initCapabilities(Lnet/minecraft/item/ItemStack;Lnet/minecraft/nbt/NBTTagCompound;)Lnet/minecraftforge/common/capabilities/ICapabilityProvider;, addCommonEntries(Lnet/minecraft/item/ItemStack;Lnet/minecraft/entity/player/EntityPlayer;Ljava/util/List;Z)V, addBasicEntries(Lnet/minecraft/item/ItemStack;Lnet/minecraft/entity/player/EntityPlayer;Ljava/util/List;Z)V]
[18:55:14] [Server thread/INFO] [EnderCore Mixins]: Successfully patched.
[18:55:14] [Server thread/INFO] [EnderCore Mixins]: Found interface target crazypants.enderio.base.paint.IPaintable$ITexturePaintableBlock
[18:55:14] [Server thread/INFO] [EnderCore Mixins]: Found interface target crazypants.enderio.base.paint.IPaintable$INonSolidBlockPaintableBlock
[18:55:14] [Server thread/WARN] [FML]: The declared version check handler method checkModLists on network mod id enderio is not accessible
java.lang.NoSuchMethodException: crazypants.enderio.base.EnderIO.checkModLists(java.util.Map, net.minecraftforge.fml.relauncher.Side)
    at java.lang.Class.getDeclaredMethod(Unknown Source) ~[?:1.8.0_211]
    at net.minecraftforge.fml.common.network.internal.NetworkModHolder.<init>(NetworkModHolder.java:246) [NetworkModHolder.class:?]
    at net.minecraftforge.fml.common.network.NetworkRegistry.register(NetworkRegistry.java:299) [NetworkRegistry.class:?]
    at net.minecraftforge.fml.common.FMLModContainer.constructMod(FMLModContainer.java:606) [FMLModContainer.class:?]
    at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0_211]
    at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) ~[?:1.8.0_211]
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) ~[?:1.8.0_211]
    at java.lang.reflect.Method.invoke(Unknown Source) ~[?:1.8.0_211]
    at com.google.common.eventbus.Subscriber.invokeSubscriberMethod(Subscriber.java:91) [minecraft_server.1.12.2.jar:?]
    at com.google.common.eventbus.Subscriber$SynchronizedSubscriber.invokeSubscriberMethod(Subscriber.java:150) [minecraft_server.1.12.2.jar:?]
    at com.google.common.eventbus.Subscriber$1.run(Subscriber.java:76) [minecraft_server.1.12.2.jar:?]
    at com.google.common.util.concurrent.MoreExecutors$DirectExecutor.execute(MoreExecutors.java:399) [minecraft_server.1.12.2.jar:?]
    at com.google.common.eventbus.Subscriber.dispatchEvent(Subscriber.java:71) [minecraft_server.1.12.2.jar:?]
    at com.google.common.eventbus.Dispatcher$PerThreadQueuedDispatcher.dispatch(Dispatcher.java:116) [minecraft_server.1.12.2.jar:?]
    at com.google.common.eventbus.EventBus.post(EventBus.java:217) [minecraft_server.1.12.2.jar:?]
    at net.minecraftforge.fml.common.LoadController.sendEventToModContainer(LoadController.java:219) [LoadController.class:?]
    at net.minecraftforge.fml.common.LoadController.propogateStateMessage(LoadController.java:197) [LoadController.class:?]
    at net.minecraftforge.fml.common.LoadController.distributeStateMessage(LoadController.java:136) [LoadController.class:?]
    at net.minecraftforge.fml.common.Loader.loadMods(Loader.java:593) [Loader.class:?]
    at net.minecraftforge.fml.server.FMLServerHandler.beginServerLoading(FMLServerHandler.java:98) [FMLServerHandler.class:?]
    at net.minecraftforge.fml.common.FMLCommonHandler.onServerStart(FMLCommonHandler.java:333) [FMLCommonHandler.class:?]
    at net.minecraft.server.dedicated.DedicatedServer.func_71197_b(DedicatedServer.java:125) [nz.class:?]
    at net.minecraft.server.MinecraftServer.run(MinecraftServer.java:486) [MinecraftServer.class:?]
    at java.lang.Thread.run(Unknown Source) [?:1.8.0_211]
[18:55:14] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.base.item.darksteel.ItemInventoryCharger from implemented interfaces: [crazypants/enderio/api/upgrades/IDarkSteelItem]
[18:55:14] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.base.item.darksteel.ItemInventoryCharger
[18:55:14] [Server thread/INFO] [EnderCore Mixins]: Added 2 new methods: [initCapabilities(Lnet/minecraft/item/ItemStack;Lnet/minecraft/nbt/NBTTagCompound;)Lnet/minecraftforge/common/capabilities/ICapabilityProvider;, getAttributeModifiers(Lnet/minecraft/inventory/EntityEquipmentSlot;Lnet/minecraft/item/ItemStack;)Lcom/google/common/collect/Multimap;]
[18:55:15] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.base.item.darksteel.ItemDarkSteelCrook from implemented interfaces: [crazypants/enderio/api/upgrades/IDarkSteelItem]
[18:55:15] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.base.item.darksteel.ItemDarkSteelCrook
[18:55:15] [Server thread/INFO] [EnderCore Mixins]: Added 2 new methods: [initCapabilities(Lnet/minecraft/item/ItemStack;Lnet/minecraft/nbt/NBTTagCompound;)Lnet/minecraftforge/common/capabilities/ICapabilityProvider;, getAttributeModifiers(Lnet/minecraft/inventory/EntityEquipmentSlot;Lnet/minecraft/item/ItemStack;)Lcom/google/common/collect/Multimap;]
[18:55:15] [Server thread/INFO] [EnderCore Mixins]: Successfully patched.
[18:55:15] [Server thread/WARN] [FML]: The declared version check handler method checkModLists on network mod id enderiointegrationtic is not accessible
java.lang.NoSuchMethodException: crazypants.enderio.integration.tic.EnderIOIntegrationTic.checkModLists(java.util.Map, net.minecraftforge.fml.relauncher.Side)
[18:55:15] [Server thread/WARN] [FML]: The declared version check handler method checkModLists on network mod id enderioconduits is not accessible
java.lang.NoSuchMethodException: crazypants.enderio.conduits.EnderIOConduits.checkModLists(java.util.Map, net.minecraftforge.fml.relauncher.Side)
    at sun.reflect.GeneratedMethodAccessor10.invoke(Unknown Source) ~[?:?]
[18:55:15] [Server thread/INFO] [EnderCore Mixins]: Found annotation mixin: crazypants.enderio.conduit.me.conduit.MEMixin
[18:55:15] [Server thread/INFO] [EnderCore Mixins]: Skipping mixin due to missing dependencies: [appliedenergistics2|API]
[18:55:15] [Server thread/WARN] [FML]: The declared version check handler method checkModLists on network mod id enderioconduitsappliedenergistics is not accessible
java.lang.NoSuchMethodException: crazypants.enderio.conduit.me.EnderIOConduitsAppliedEnergistics.checkModLists(java.util.Map, net.minecraftforge.fml.relauncher.Side)
[18:55:15] [Server thread/INFO] [EnderCore Mixins]: Found annotation mixin: crazypants.enderio.conduit.oc.conduit.OCMixin
[18:55:15] [Server thread/INFO] [EnderCore Mixins]: Skipping mixin due to missing dependencies: [opencomputersapi|network]
[18:55:15] [Server thread/WARN] [FML]: The declared version check handler method checkModLists on network mod id enderioconduitsopencomputers is not accessible
java.lang.NoSuchMethodException: crazypants.enderio.conduit.oc.EnderIOConduitsOpenComputers.checkModLists(java.util.Map, net.minecraftforge.fml.relauncher.Side)
[18:55:15] [Server thread/WARN] [FML]: The declared version check handler method checkModLists on network mod id enderioconduitsrefinedstorage is not accessible
java.lang.NoSuchMethodException: crazypants.enderio.conduit.refinedstorage.EnderIOConduitsRefinedStorage.checkModLists(java.util.Map, net.minecraftforge.fml.relauncher.Side)
[18:55:15] [Server thread/INFO] [EnderCore Mixins]: Found annotation mixin: crazypants.enderio.integration.forestry.upgrades.ArmorMixin
[18:55:15] [Server thread/INFO] [EnderCore Mixins]: Skipping mixin due to missing dependencies: [forestry]
[18:55:15] [Server thread/WARN] [FML]: The declared version check handler method checkModLists on network mod id enderiointegrationforestry is not accessible
java.lang.NoSuchMethodException: crazypants.enderio.integration.forestry.EnderIOIntegrationForestry.checkModLists(java.util.Map, net.minecraftforge.fml.relauncher.Side)
[18:55:16] [Server thread/INFO] [Pulsar-tconstruct]: Skipping Pulse chiselsandbitsIntegration; missing dependency: chiselsandbits
[18:55:16] [Server thread/INFO] [Pulsar-tconstruct]: Skipping Pulse craftingtweaksIntegration; missing dependency: craftingtweaks
[18:55:16] [Server thread/INFO] [Pulsar-tconstruct]: Skipping Pulse wailaIntegration; missing dependency: waila
[18:55:16] [Server thread/INFO] [Pulsar-tconstruct]: Skipping Pulse theoneprobeIntegration; missing dependency: theoneprobe
[18:55:16] [Server thread/INFO] [tconstruct]: Preparing to take over the world
[18:55:16] [Server thread/WARN] [FML]: The declared version check handler method checkModLists on network mod id enderiointegrationticlate is not accessible
java.lang.NoSuchMethodException: crazypants.enderio.integration.tic.EnderIOIntegrationTicLate.checkModLists(java.util.Map, net.minecraftforge.fml.relauncher.Side)
[18:55:16] [Server thread/WARN] [FML]: The declared version check handler method checkModLists on network mod id enderiomachines is not accessible
java.lang.NoSuchMethodException: crazypants.enderio.machines.EnderIOMachines.checkModLists(java.util.Map, net.minecraftforge.fml.relauncher.Side)
[18:55:16] [Server thread/WARN] [FML]: The declared version check handler method checkModLists on network mod id enderiopowertools is not accessible
java.lang.NoSuchMethodException: crazypants.enderio.powertools.EnderIOPowerTools.checkModLists(java.util.Map, net.minecraftforge.fml.relauncher.Side)
[18:55:17] [Server thread/INFO] [FML]: Processing ObjectHolder annotations
[18:55:17] [Server thread/INFO] [FML]: Found 1504 ObjectHolder annotations
[18:55:17] [Server thread/INFO] [FML]: Identifying ItemStackHolder annotations
[18:55:17] [Server thread/INFO] [FML]: Found 8 ItemStackHolder annotations
[18:55:17] [Server thread/INFO] [FML]: Configured a dormant chunk cache size of 0
[18:55:17] [Forge Version Check/INFO] [forge.VersionCheck]: [mclib] Starting version check at https://raw.githubusercontent.com/mchorse/mclib/master/version.json
[18:55:18] [Server thread/INFO] [Bewitchment]: Remember when I told you how my
[18:55:18] [Server thread/INFO] [Bewitchment]: Kin is different in some ways?
[18:55:18] [Forge Version Check/INFO] [forge.VersionCheck]: [mclib] Found status: UP_TO_DATE Target: null
[18:55:18] [Forge Version Check/INFO] [forge.VersionCheck]: [codechickenlib] Starting version check at http://chickenbones.net/Files/notification/version.php?query=forge&version=1.12&file=CodeChickenLib
[18:55:19] [Forge Version Check/INFO] [forge.VersionCheck]: [codechickenlib] Found status: BETA Target: null
[18:55:19] [Forge Version Check/INFO] [forge.VersionCheck]: [projecte] Starting version check at https://raw.githubusercontent.com/sinkillerj/ProjectE/mc1.12.x/update.json
[18:55:19] [Server thread/INFO] [FML]: Applying holder lookups
[18:55:19] [Server thread/INFO] [FML]: Holder lookups applied
[18:55:19] [Forge Version Check/INFO] [forge.VersionCheck]: [projecte] Found status: UP_TO_DATE Target: null
[18:55:19] [Forge Version Check/INFO] [forge.VersionCheck]: [llibrary] Starting version check at https://gist.githubusercontent.com/gegy1000/a6639456aeb8edd92cbf7cbfcf9d65d9/raw/llibrary_updates.json
[18:55:19] [Server thread/INFO] [STDOUT]: [jaredbgreat.dldungeons.DoomlikeDungeons:preInit:45]: Doomlike Dungeons is in preInit, should now load config.
[18:55:19] [Server thread/INFO] [STDOUT]: [jaredbgreat.dldungeons.themes.ThemeReader:setConfigDir:71]: [DLDUNGEONS] themesdir is C:\Users\carso\OneDrive\Desktop\Chadcraft 1.0 server\config\DLDungeonsJBG
[18:55:19] [Server thread/INFO] [STDOUT]: [jaredbgreat.dldungeons.GenerationHandler:setFrequency:116]: freqScale = 8
[18:55:19] [Server thread/INFO] [STDOUT]: [jaredbgreat.dldungeons.GenerationHandler:setFrequency:118]: factor = 32
[18:55:19] [Server thread/INFO] [STDOUT]: [jaredbgreat.dldungeons.ConfigHandler:init:124]: [DLDUNGEONS] Frequency Scaling Factor Set To: 8
[18:55:19] [Server thread/INFO] [STDOUT]: [jaredbgreat.dldungeons.ConfigHandler:init:131]: [DLDUNGEONS] Minimum X Factor Set To: 16
[18:55:19] [Server thread/INFO] [STDOUT]: [jaredbgreat.dldungeons.ConfigHandler:init:138]: [DLDUNGEONS] Difficulty set to: Normal difficulty.
[18:55:19] [Server thread/INFO] [STDOUT]: [jaredbgreat.dldungeons.ConfigHandler:init:151]: [DLDUNGEONS] Will spawn dungeons in with world generation? true
[18:55:19] [Server thread/INFO] [STDOUT]: [jaredbgreat.dldungeons.ConfigHandler:init:157]: [DLDUNGEONS] Will spawn dungeons even with structures disabled? false
[18:55:19] [Server thread/INFO] [STDOUT]: [jaredbgreat.dldungeons.ConfigHandler:init:172]: [DLDUNGEONS] Will export item, block, and mob lists? false
[18:55:19] [Server thread/INFO] [STDOUT]: [jaredbgreat.dldungeons.ConfigHandler:init:177]: [DLDUNGEONS] Will announce use of OP/cheat commands? true
[18:55:19] [Server thread/INFO] [STDOUT]: [jaredbgreat.dldungeons.ConfigHandler:init:182]: [DLDUNGEONS] Will dungeons be easy to find? false
[18:55:19] [Server thread/INFO] [STDOUT]: [jaredbgreat.dldungeons.ConfigHandler:init:187]: [DLDUNGEONS] Will themes be automatically install if themes folder is empty? true
[18:55:19] [Server thread/INFO] [STDOUT]: [jaredbgreat.dldungeons.ConfigHandler:init:193]: [DLDUNGEONS] Can themes be (re)installed by command? true
[18:55:19] [Server thread/INFO] [STDOUT]: [jaredbgreat.dldungeons.ConfigHandler:processBiomeExclusions:514]: [DLDUNGEONS] adding END to excusion list
[18:55:19] [Server thread/INFO] [STDOUT]: [jaredbgreat.dldungeons.ConfigHandler:init:211]: [DLDUNGEONS] Will use API? true
[18:55:19] [Server thread/INFO] [STDOUT]: [jaredbgreat.dldungeons.ConfigHandler:init:217]: [DLDUNGEONS] Will allow API base mob change? true
[18:55:19] [Server thread/INFO] [STDOUT]: [jaredbgreat.dldungeons.ConfigHandler:init:240]: [DLDUNGEONS] Will self-profile? false
[18:55:19] [Server thread/INFO] [STDOUT]: [jaredbgreat.dldungeons.ConfigHandler:openThemesDir:424]: [DLDUNGEONS] themesdir will be set to C:\Users\carso\OneDrive\Desktop\Chadcraft 1.0 server\config\DLDungeonsJBG\themes\
[18:55:19] [Server thread/INFO] [STDOUT]: [jaredbgreat.dldungeons.ConfigHandler:openThemesDir:426]: [DLDUNGEONS] themesdir File is be set to C:\Users\carso\OneDrive\Desktop\Chadcraft 1.0 server\config\DLDungeonsJBG\themes
[18:55:19] [Server thread/INFO] [STDOUT]: [jaredbgreat.dldungeons.themes.ThemeReader:setThemesDir:58]: [DLDUNGEONS] themesdir is C:\Users\carso\OneDrive\Desktop\Chadcraft 1.0 server\config\DLDungeonsJBG\themes
[18:55:19] [Server thread/INFO] [STDOUT]: [jaredbgreat.dldungeons.setup.Externalizer:makeChestCfg:151]: [DLDUNGEONS] Installing files C:\Users\carso\OneDrive\Desktop\Chadcraft 1.0 server\config\DLDungeonsJBG\chests.cfg
[18:55:19] [Server thread/INFO] [STDOUT]: [jaredbgreat.dldungeons.DoomlikeDungeons:preInit:48]: [DLDUNGEONS] Config should now be loaded.
[18:55:19] [Forge Version Check/INFO] [forge.VersionCheck]: [llibrary] Found status: AHEAD Target: null
[18:55:19] [Forge Version Check/INFO] [forge.VersionCheck]: [enderstorage] Starting version check at http://chickenbones.net/Files/notification/version.php?query=forge&version=1.12&file=EnderStorage
[18:55:19] [Forge Version Check/INFO] [forge.VersionCheck]: [enderstorage] Found status: BETA Target: null
[18:55:19] [Forge Version Check/INFO] [forge.VersionCheck]: [forge] Starting version check at http://files.minecraftforge.net/maven/net/minecraftforge/forge/promotions_slim.json
[18:55:19] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.base.block.painted.BlockPaintedFence from implemented interfaces: [crazypants/enderio/base/paint/IPaintable$ITexturePaintableBlock]
[18:55:19] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.base.block.painted.BlockPaintedFence
[18:55:19] [Server thread/INFO] [EnderCore Mixins]: Added 1 new method: [func_149656_h(Lnet/minecraft/block/state/IBlockState;)Lnet/minecraft/block/material/EnumPushReaction;]
[18:55:19] [Server thread/INFO] [EnderCore Mixins]: Successfully patched.
[18:55:19] [Forge Version Check/INFO] [forge.VersionCheck]: [forge] Found status: AHEAD Target: null
[18:55:19] [Forge Version Check/INFO] [forge.VersionCheck]: [rafradek_tf2_weapons] Starting version check at https://rafradek.github.io/tf2stuffmod.json
[18:55:19] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.base.block.painted.BlockPaintedFenceGate from implemented interfaces: [crazypants/enderio/base/paint/IPaintable$ITexturePaintableBlock]
[18:55:19] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.base.block.painted.BlockPaintedFenceGate
[18:55:19] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.base.block.painted.BlockPaintedWall from implemented interfaces: [crazypants/enderio/base/paint/IPaintable$ITexturePaintableBlock]
[18:55:19] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.base.block.painted.BlockPaintedWall
[18:55:19] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.base.block.painted.BlockPaintedStairs from implemented interfaces: [crazypants/enderio/base/paint/IPaintable$ITexturePaintableBlock]
[18:55:19] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.base.block.painted.BlockPaintedStairs
[18:55:19] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.base.block.painted.BlockPaintedSlab from implemented interfaces: [crazypants/enderio/base/paint/IPaintable$ITexturePaintableBlock]
[18:55:19] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.base.block.painted.BlockPaintedSlab
[18:55:19] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.base.block.painted.BlockPaintedGlowstone from implemented interfaces: [crazypants/enderio/base/paint/IPaintable$IBlockPaintableBlock]
[18:55:19] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.base.block.painted.BlockPaintedGlowstone
[18:55:19] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.base.block.painted.BlockPaintedGlowstone$BlockPaintedGlowstoneNonSolid from implemented interfaces: [crazypants/enderio/base/paint/IPaintable$INonSolidBlockPaintableBlock]
[18:55:19] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.base.block.painted.BlockPaintedGlowstone$BlockPaintedGlowstoneNonSolid
[18:55:19] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.base.block.painted.BlockPaintedGlowstone$BlockPaintedGlowstoneSolid from implemented interfaces: [crazypants/enderio/base/paint/IPaintable$ISolidBlockPaintableBlock]
[18:55:19] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.base.block.painted.BlockPaintedGlowstone$BlockPaintedGlowstoneSolid
[18:55:19] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.base.block.painted.BlockPaintedCarpet from implemented interfaces: [crazypants/enderio/base/paint/IPaintable$ITexturePaintableBlock]
[18:55:19] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.base.block.painted.BlockPaintedCarpet
[18:55:19] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.base.block.painted.BlockPaintedPressurePlate from implemented interfaces: [crazypants/enderio/base/paint/IPaintable$ITexturePaintableBlock]
[18:55:19] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.base.block.painted.BlockPaintedPressurePlate
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.base.block.painted.BlockPaintedRedstone from implemented interfaces: [crazypants/enderio/base/paint/IPaintable$IBlockPaintableBlock]
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.base.block.painted.BlockPaintedRedstone
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Added 1 new method: [func_149656_h(Lnet/minecraft/block/state/IBlockState;)Lnet/minecraft/block/material/EnumPushReaction;]
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Successfully patched.
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.base.block.painted.BlockPaintedRedstone$BlockPaintedRedstoneNonSolid from implemented interfaces: [crazypants/enderio/base/paint/IPaintable$INonSolidBlockPaintableBlock]
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.base.block.painted.BlockPaintedRedstone$BlockPaintedRedstoneNonSolid
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.base.block.painted.BlockPaintedRedstone$BlockPaintedRedstoneSolid from implemented interfaces: [crazypants/enderio/base/paint/IPaintable$ISolidBlockPaintableBlock]
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.base.block.painted.BlockPaintedRedstone$BlockPaintedRedstoneSolid
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.base.block.painted.BlockPaintedStone from implemented interfaces: [crazypants/enderio/base/paint/IPaintable$ISolidBlockPaintableBlock]
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.base.block.painted.BlockPaintedStone
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.base.block.painted.BlockPaintedTrapDoor from implemented interfaces: [crazypants/enderio/base/paint/IPaintable$ITexturePaintableBlock]
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.base.block.painted.BlockPaintedTrapDoor
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.base.block.painted.BlockPaintedDoor from implemented interfaces: [crazypants/enderio/base/paint/IPaintable$ITexturePaintableBlock]
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.base.block.painted.BlockPaintedDoor
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.base.block.painted.BlockPaintedWorkbench from implemented interfaces: [crazypants/enderio/base/paint/IPaintable$ISolidBlockPaintableBlock]
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.base.block.painted.BlockPaintedWorkbench
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.base.block.painted.BlockPaintedReinforcedObsidian from implemented interfaces: [crazypants/enderio/base/paint/IPaintable$ISolidBlockPaintableBlock]
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.base.block.painted.BlockPaintedReinforcedObsidian
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.base.item.travelstaff.ItemTravelStaff from implemented interfaces: [crazypants/enderio/api/upgrades/IDarkSteelItem]
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.base.item.travelstaff.ItemTravelStaff
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Added 2 new methods: [initCapabilities(Lnet/minecraft/item/ItemStack;Lnet/minecraft/nbt/NBTTagCompound;)Lnet/minecraftforge/common/capabilities/ICapabilityProvider;, getAttributeModifiers(Lnet/minecraft/inventory/EntityEquipmentSlot;Lnet/minecraft/item/ItemStack;)Lcom/google/common/collect/Multimap;]
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.base.power.forge.item.AbstractPoweredItem from implemented interfaces: [crazypants/enderio/base/power/forge/item/IInternalPoweredItem]
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.base.power.forge.item.AbstractPoweredItem
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Added 1 new method: [initCapabilities(Lnet/minecraft/item/ItemStack;Lnet/minecraft/nbt/NBTTagCompound;)Lnet/minecraftforge/common/capabilities/ICapabilityProvider;]
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.base.material.glass.BlockPaintedFusedQuartz from implemented interfaces: [crazypants/enderio/base/paint/IPaintable$IBlockPaintableBlock]
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.base.material.glass.BlockPaintedFusedQuartz
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.base.block.detector.BlockDetector from implemented interfaces: [crazypants/enderio/base/paint/IPaintable$ISolidBlockPaintableBlock]
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.base.block.detector.BlockDetector
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.base.item.darksteel.ItemDarkSteelSword from implemented interfaces: [crazypants/enderio/api/upgrades/IDarkSteelItem]
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.base.item.darksteel.ItemDarkSteelSword
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.base.item.darksteel.ItemDarkSteelPickaxe from implemented interfaces: [crazypants/enderio/api/upgrades/IDarkSteelItem]
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.base.item.darksteel.ItemDarkSteelPickaxe
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Added 4 new methods: [initCapabilities(Lnet/minecraft/item/ItemStack;Lnet/minecraft/nbt/NBTTagCompound;)Lnet/minecraftforge/common/capabilities/ICapabilityProvider;, getAttributeModifiers(Lnet/minecraft/inventory/EntityEquipmentSlot;Lnet/minecraft/item/ItemStack;)Lcom/google/common/collect/Multimap;, addCommonEntries(Lnet/minecraft/item/ItemStack;Lnet/minecraft/entity/player/EntityPlayer;Ljava/util/List;Z)V, addBasicEntries(Lnet/minecraft/item/ItemStack;Lnet/minecraft/entity/player/EntityPlayer;Ljava/util/List;Z)V]
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.base.item.darksteel.ItemDarkSteelAxe from implemented interfaces: [crazypants/enderio/api/upgrades/IDarkSteelItem]
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.base.item.darksteel.ItemDarkSteelAxe
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.base.item.darksteel.ItemDarkSteelBow from implemented interfaces: [crazypants/enderio/api/upgrades/IDarkSteelItem]
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.base.item.darksteel.ItemDarkSteelBow
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.base.item.darksteel.ItemDarkSteelShears from implemented interfaces: [crazypants/enderio/api/upgrades/IDarkSteelItem]
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.base.item.darksteel.ItemDarkSteelShears
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.base.item.darksteel.ItemDarkSteelTreetap from implemented interfaces: [crazypants/enderio/api/upgrades/IDarkSteelItem]
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.base.item.darksteel.ItemDarkSteelTreetap
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.base.item.darksteel.ItemDarkSteelHand from implemented interfaces: [crazypants/enderio/api/upgrades/IDarkSteelItem]
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.base.item.darksteel.ItemDarkSteelHand
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.base.item.staffoflevity.ItemStaffOfLevity from implemented interfaces: [crazypants/enderio/api/upgrades/IDarkSteelItem]
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.base.item.staffoflevity.ItemStaffOfLevity
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.conduits.conduit.BlockConduitBundle from implemented interfaces: [crazypants/enderio/base/paint/IPaintable$IBlockPaintableBlock]
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.conduits.conduit.BlockConduitBundle
[18:55:20] [Server thread/INFO] [com.enderio.core.common.transform.NoClassloadClassWriter]: Class 2 super was object or null
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.machines.machine.alloy.BlockAlloySmelter from implemented interfaces: [crazypants/enderio/base/paint/IPaintable$ISolidBlockPaintableBlock]
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.machines.machine.alloy.BlockAlloySmelter
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.base.power.forge.item.PoweredBlockItem from implemented interfaces: [crazypants/enderio/base/power/forge/item/IInternalPoweredItem]
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.base.power.forge.item.PoweredBlockItem
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.machines.machine.buffer.BlockBuffer from implemented interfaces: [crazypants/enderio/base/paint/IPaintable$ISolidBlockPaintableBlock]
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.machines.machine.buffer.BlockBuffer
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.machines.machine.farm.BlockFarmStation from implemented interfaces: [crazypants/enderio/base/paint/IPaintable$INonSolidBlockPaintableBlock]
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.machines.machine.farm.BlockFarmStation
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.machines.machine.generator.combustion.BlockCombustionGenerator from implemented interfaces: [crazypants/enderio/base/paint/IPaintable$INonSolidBlockPaintableBlock]
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.machines.machine.generator.combustion.BlockCombustionGenerator
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.machines.machine.generator.stirling.BlockStirlingGenerator from implemented interfaces: [crazypants/enderio/base/paint/IPaintable$ISolidBlockPaintableBlock]
[18:55:20] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.machines.machine.generator.stirling.BlockStirlingGenerator
[18:55:21] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.machines.machine.generator.lava.BlockLavaGenerator from implemented interfaces: [crazypants/enderio/base/paint/IPaintable$ISolidBlockPaintableBlock]
[18:55:21] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.machines.machine.generator.lava.BlockLavaGenerator
[18:55:21] [Server thread/INFO] [EnderCore Mixins]: Added 1 new method: [func_149656_h(Lnet/minecraft/block/state/IBlockState;)Lnet/minecraft/block/material/EnumPushReaction;]
[18:55:21] [Server thread/INFO] [EnderCore Mixins]: Successfully patched.
[18:55:21] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.machines.machine.painter.BlockPainter from implemented interfaces: [crazypants/enderio/base/paint/IPaintable$ISolidBlockPaintableBlock]
[18:55:21] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.machines.machine.painter.BlockPainter
[18:55:21] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.machines.machine.sagmill.BlockSagMill from implemented interfaces: [crazypants/enderio/base/paint/IPaintable$ISolidBlockPaintableBlock]
[18:55:21] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.machines.machine.sagmill.BlockSagMill
[18:55:21] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.machines.machine.slicensplice.BlockSliceAndSplice from implemented interfaces: [crazypants/enderio/base/paint/IPaintable$ISolidBlockPaintableBlock]
[18:55:21] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.machines.machine.slicensplice.BlockSliceAndSplice
[18:55:21] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.machines.machine.soul.BlockSoulBinder from implemented interfaces: [crazypants/enderio/base/paint/IPaintable$INonSolidBlockPaintableBlock]
[18:55:21] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.machines.machine.soul.BlockSoulBinder
[18:55:21] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.machines.machine.spawner.BlockPoweredSpawner from implemented interfaces: [crazypants/enderio/base/paint/IPaintable$INonSolidBlockPaintableBlock]
[18:55:21] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.machines.machine.spawner.BlockPoweredSpawner
[18:55:21] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.machines.machine.vat.BlockVat from implemented interfaces: [crazypants/enderio/base/paint/IPaintable$INonSolidBlockPaintableBlock]
[18:55:21] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.machines.machine.vat.BlockVat
[18:55:21] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.machines.machine.wired.BlockWiredCharger from implemented interfaces: [crazypants/enderio/base/paint/IPaintable$ISolidBlockPaintableBlock]
[18:55:21] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.machines.machine.wired.BlockWiredCharger
[18:55:21] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.machines.machine.wireless.BlockWirelessCharger from implemented interfaces: [crazypants/enderio/base/paint/IPaintable$IBlockPaintableBlock]
[18:55:21] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.machines.machine.wireless.BlockWirelessCharger
[18:55:21] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.machines.machine.tank.BlockTank from implemented interfaces: [crazypants/enderio/base/paint/IPaintable$INonSolidBlockPaintableBlock]
[18:55:21] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.machines.machine.tank.BlockTank
[18:55:21] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.machines.machine.transceiver.BlockTransceiver from implemented interfaces: [crazypants/enderio/base/paint/IPaintable$INonSolidBlockPaintableBlock]
[18:55:21] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.machines.machine.transceiver.BlockTransceiver
[18:55:21] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.machines.machine.vacuum.chest.BlockVacuumChest from implemented interfaces: [crazypants/enderio/base/paint/IPaintable$IBlockPaintableBlock]
[18:55:21] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.machines.machine.vacuum.chest.BlockVacuumChest
[18:55:21] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.machines.machine.vacuum.xp.BlockXPVacuum from implemented interfaces: [crazypants/enderio/base/paint/IPaintable$IBlockPaintableBlock]
[18:55:21] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.machines.machine.vacuum.xp.BlockXPVacuum
[18:55:21] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.machines.machine.teleport.anchor.BlockTravelAnchor from implemented interfaces: [crazypants/enderio/base/paint/IPaintable$IBlockPaintableBlock]
[18:55:21] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.machines.machine.teleport.anchor.BlockTravelAnchor
[18:55:21] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.machines.machine.teleport.telepad.BlockTelePad from implemented interfaces: [crazypants/enderio/base/paint/IPaintable$ISolidBlockPaintableBlock]
[18:55:21] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.machines.machine.teleport.telepad.BlockTelePad
[18:55:21] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.machines.machine.crafter.BlockCrafter from implemented interfaces: [crazypants/enderio/base/paint/IPaintable$ISolidBlockPaintableBlock]
[18:55:21] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.machines.machine.crafter.BlockCrafter
[18:55:21] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.machines.machine.spawner.creative.BlockCreativeSpawner from implemented interfaces: [crazypants/enderio/base/paint/IPaintable$ISolidBlockPaintableBlock]
[18:55:21] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.machines.machine.spawner.creative.BlockCreativeSpawner
[18:55:21] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.powertools.machine.capbank.BlockCapBank from implemented interfaces: [crazypants/enderio/base/paint/IPaintable$ISolidBlockPaintableBlock]
[18:55:21] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.powertools.machine.capbank.BlockCapBank
[18:55:21] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.powertools.machine.capbank.BlockItemCapBank from implemented interfaces: [crazypants/enderio/base/power/forge/item/IInternalPoweredItem]
[18:55:21] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.powertools.machine.capbank.BlockItemCapBank
[18:55:21] [Server thread/INFO] [EnderCore Mixins]: Added 1 new method: [initCapabilities(Lnet/minecraft/item/ItemStack;Lnet/minecraft/nbt/NBTTagCompound;)Lnet/minecraftforge/common/capabilities/ICapabilityProvider;]
[18:55:21] [Server thread/INFO] [EnderCore Mixins]: Found 1 patch to apply to class crazypants.enderio.powertools.machine.monitor.BlockPowerMonitor from implemented interfaces: [crazypants/enderio/base/paint/IPaintable$ISolidBlockPaintableBlock]
[18:55:21] [Server thread/INFO] [EnderCore Mixins]: Patching 1 mixins onto class crazypants.enderio.powertools.machine.monitor.BlockPowerMonitor
[18:55:21] [Server thread/WARN] [enderio]: TConstruct, you fail again, muhaha! The world is mine, mine!
[18:55:21] [Server thread/WARN] [enderio]: Applied Energistics conduits NOT loaded. Applied Energistics is not installed
[18:55:21] [Server thread/WARN] [enderio]: OpenComputers conduits NOT loaded. OpenComputers is not installed
[18:55:21] [Server thread/WARN] [enderio]: Refined Storage conduits NOT loaded. Refined Storage is not installed
[18:55:21] [Server thread/WARN] [enderio]: Forestry integration NOT loaded. Forestry is not installed
[18:55:22] [Server thread/WARN] [FML]: Potentially Dangerous alternative prefix `minecraft` for name `ender chest`, expected `enderstorage`. This could be a intended override, but in most cases indicates a broken mod.
[18:55:22] [Server thread/WARN] [FML]: Potentially Dangerous alternative prefix `minecraft` for name `ender tank`, expected `enderstorage`. This could be a intended override, but in most cases indicates a broken mod.
[18:55:22] [Server thread/WARN] [FML]: Potentially Dangerous alternative prefix `minecraft` for name `tile_entity_grapple_modifier`, expected `grapplemod`. This could be a intended override, but in most cases indicates a broken mod.
[18:55:23] [Server thread/WARN] [mca]: MCA is running on a dedicated server and will default to using English as its language.
[18:55:23] [Server thread/WARN] [mca]: This may cause issues with some phrases being translated while others are not.
[18:55:23] [Server thread/WARN] [mca]: **** To change your server's language in MCA, change the `serverLanguageId` option in MCA's configuration. ****
[18:55:23] [Server thread/INFO] [mca]: Loaded language en_us
[18:55:23] [Hats Mod Mob Support Thread/INFO] [Hats]: [7.0.0] Registered thaumcraft.common.entities.monster.EntityPech with hat mod mappings.
[18:55:23] [Server thread/INFO] [TF2 Stuff Mod]: Initializing config files
[18:55:23] [Server thread/INFO] [TF2 Stuff Mod]: Initializing attributes
[18:55:23] [Server thread/INFO] [TF2 Stuff Mod]: Registering
[18:55:23] [Server thread/WARN] [FML]: Potentially Dangerous alternative prefix `minecraft` for name `upgradestation`, expected `rafradek_tf2_weapons`. This could be a intended override, but in most cases indicates a broken mod.
[18:55:23] [Server thread/WARN] [FML]: Potentially Dangerous alternative prefix `minecraft` for name `ammofurnace`, expected `rafradek_tf2_weapons`. This could be a intended override, but in most cases indicates a broken mod.
[18:55:24] [Server thread/INFO] [TF2 Stuff Mod]: Parsing weapon files
[18:55:24] [Server thread/INFO] [TF2 Stuff Mod]: Registering models
[18:55:24] [Server thread/INFO] [TF2 Stuff Mod]: Pre init done
[18:55:25] [Server thread/WARN] [FML]: Potentially Dangerous alternative prefix `minecraft` for name `stall_te`, expected `fluidcows`. This could be a intended override, but in most cases indicates a broken mod.
[18:55:25] [Server thread/WARN] [FML]: Potentially Dangerous alternative prefix `minecraft` for name `accelerator_te`, expected `fluidcows`. This could be a intended override, but in most cases indicates a broken mod.
[18:55:25] [Server thread/WARN] [FML]: Potentially Dangerous alternative prefix `minecraft` for name `feeder_te`, expected `fluidcows`. This could be a intended override, but in most cases indicates a broken mod.
[18:55:25] [Server thread/WARN] [FML]: Potentially Dangerous alternative prefix `minecraft` for name `sorter_te`, expected `fluidcows`. This could be a intended override, but in most cases indicates a broken mod.
[18:55:26] [Server thread/INFO] [Chisel]: Loading blocks...
[18:55:26] [Server thread/INFO] [Chisel]: Skipping feature bloodMagic as its required mod bloodmagic was missing.
[18:55:26] [Server thread/INFO] [Chisel]: 71 Feature's blocks loaded.
[18:55:26] [Server thread/INFO] [Chisel]: Loading Tile Entities...
[18:55:26] [Server thread/INFO] [Chisel]: Tile Entities loaded.
[18:55:29] [Server thread/WARN] [FML]: Potentially Dangerous alternative prefix `minecraft` for name `tconstruct.table`, expected `tconstruct`. This could be a intended override, but in most cases indicates a broken mod.
[18:55:29] [Server thread/WARN] [FML]: Potentially Dangerous alternative prefix `minecraft` for name `tconstruct.craftingstation`, expected `tconstruct`. This could be a intended override, but in most cases indicates a broken mod.
[18:55:29] [Server thread/WARN] [FML]: Potentially Dangerous alternative prefix `minecraft` for name `tconstruct.stenciltable`, expected `tconstruct`. This could be a intended override, but in most cases indicates a broken mod.
[18:55:29] [Server thread/WARN] [FML]: Potentially Dangerous alternative prefix `minecraft` for name `tconstruct.partbuilder`, expected `tconstruct`. This could be a intended override, but in most cases indicates a broken mod.
[18:55:29] [Server thread/WARN] [FML]: Potentially Dangerous alternative prefix `minecraft` for name `tconstruct.patternchest`, expected `tconstruct`. This could be a intended override, but in most cases indicates a broken mod.
[18:55:29] [Server thread/WARN] [FML]: Potentially Dangerous alternative prefix `minecraft` for name `tconstruct.partchest`, expected `tconstruct`. This could be a intended override, but in most cases indicates a broken mod.
[18:55:29] [Server thread/WARN] [FML]: Potentially Dangerous alternative prefix `minecraft` for name `tconstruct.toolstation`, expected `tconstruct`. This could be a intended override, but in most cases indicates a broken mod.
[18:55:29] [Server thread/WARN] [FML]: Potentially Dangerous alternative prefix `minecraft` for name `tconstruct.toolforge`, expected `tconstruct`. This could be a intended override, but in most cases indicates a broken mod.
[18:55:29] [Server thread/WARN] [FML]: Potentially Dangerous alternative prefix `minecraft` for name `tconstruct.smeltery_controller`, expected `tconstruct`. This could be a intended override, but in most cases indicates a broken mod.
[18:55:29] [Server thread/WARN] [FML]: Potentially Dangerous alternative prefix `minecraft` for name `tconstruct.smeltery_component`, expected `tconstruct`. This could be a intended override, but in most cases indicates a broken mod.
[18:55:29] [Server thread/WARN] [FML]: Potentially Dangerous alternative prefix `minecraft` for name `tconstruct.tank`, expected `tconstruct`. This could be a intended override, but in most cases indicates a broken mod.
[18:55:29] [Server thread/WARN] [FML]: Potentially Dangerous alternative prefix `minecraft` for name `tconstruct.faucet`, expected `tconstruct`. This could be a intended override, but in most cases indicates a broken mod.
[18:55:29] [Server thread/WARN] [FML]: Potentially Dangerous alternative prefix `minecraft` for name `tconstruct.channel`, expected `tconstruct`. This could be a intended override, but in most cases indicates a broken mod.
[18:55:29] [Server thread/WARN] [FML]: Potentially Dangerous alternative prefix `minecraft` for name `tconstruct.casting_table`, expected `tconstruct`. This could be a intended override, but in most cases indicates a broken mod.
[18:55:29] [Server thread/WARN] [FML]: Potentially Dangerous alternative prefix `minecraft` for name `tconstruct.casting_basin`, expected `tconstruct`. This could be a intended override, but in most cases indicates a broken mod.
[18:55:29] [Server thread/WARN] [FML]: Potentially Dangerous alternative prefix `minecraft` for name `tconstruct.smeltery_drain`, expected `tconstruct`. This could be a intended override, but in most cases indicates a broken mod.
[18:55:29] [Server thread/WARN] [FML]: Potentially Dangerous alternative prefix `minecraft` for name `tconstruct.seared_furnace`, expected `tconstruct`. This could be a intended override, but in most cases indicates a broken mod.
[18:55:29] [Server thread/WARN] [FML]: Potentially Dangerous alternative prefix `minecraft` for name `tconstruct.tinker_tank`, expected `tconstruct`. This could be a intended override, but in most cases indicates a broken mod.
[18:55:29] [Server thread/WARN] [FML]: Potentially Dangerous alternative prefix `minecraft` for name `tconstruct.item_rack`, expected `tconstruct`. This could be a intended override, but in most cases indicates a broken mod.
[18:55:29] [Server thread/WARN] [FML]: Potentially Dangerous alternative prefix `minecraft` for name `tconstruct.drying_rack`, expected `tconstruct`. This could be a intended override, but in most cases indicates a broken mod.
[18:55:29] [Server thread/WARN] [FML]: Potentially Dangerous alternative prefix `minecraft` for name `tconstruct.wooden_hopper`, expected `tconstruct`. This could be a intended override, but in most cases indicates a broken mod.
[18:55:29] [Server thread/WARN] [FML]: Potentially Dangerous alternative prefix `minecraft` for name `tconstruct.slime_channel`, expected `tconstruct`. This could be a intended override, but in most cases indicates a broken mod.
[18:55:30] [Server thread/INFO] [FML]: Applying holder lookups
[18:55:30] [Server thread/INFO] [FML]: Holder lookups applied
[18:55:30] [Server thread/INFO] [Chisel]: Loading items...
[18:55:30] [Server thread/INFO] [Chisel]: Skipping feature bloodMagic as its required mod bloodmagic was missing.
[18:55:30] [Server thread/INFO] [Chisel]: 71 Feature's items loaded.
[18:55:31] [Server thread/INFO] [FML]: Applying holder lookups
[18:55:31] [Server thread/INFO] [FML]: Holder lookups applied
[18:55:31] [Server thread/INFO] [enderio]: Farming Station: IC2 classic integration not loaded
[18:55:31] [Server thread/INFO] [enderio]: Farming Station: IC2 integration not loaded
[18:55:31] [Server thread/INFO] [enderio]: Farming Station: TechReborn integration not loaded
[18:55:31] [Server thread/INFO] [enderio]: Farming Station: Immersive Engineering integration not loaded
[18:55:31] [Server thread/INFO] [enderio]: Farming Station: Natura integration not loaded
[18:55:31] [Server thread/INFO] [enderio]: Farming Station: Extra Utilities 2 integration not loaded
[18:55:31] [Server thread/INFO] [enderio]: Farming Station: MFR integration not loaded
[18:55:31] [Server thread/WARN] [FML]: Potentially Dangerous alternative prefix `botania` for name `petals`, expected `enderio`. This could be a intended override, but in most cases indicates a broken mod.
[18:55:31] [Server thread/INFO] [enderio]: Farming Station: Botania integration for farming fully loaded
[18:55:31] [Server thread/WARN] [FML]: Potentially Dangerous alternative prefix `minecraft` for name `dye`, expected `enderio`. This could be a intended override, but in most cases indicates a broken mod.
[18:55:31] [Server thread/INFO] [enderio]: Farming Station: Actually Additions integration not loaded
[18:55:31] [Server thread/INFO] [enderio]: Farming Station: Metallurgy integration not loaded
[18:55:31] [Server thread/INFO] [enderio]: Farming Station: Gardencore integration not loaded
[18:55:31] [Server thread/INFO] [enderio]: Farming Station: Magicalcrops integration not loaded
[18:55:31] [Server thread/WARN] [FML]: Potentially Dangerous alternative prefix `botania` for name `fertilizer`, expected `enderio`. This could be a intended override, but in most cases indicates a broken mod.
[18:55:31] [Server thread/INFO] [enderio]: Farming Station: Botania integration for fertilizing fully loaded
[18:55:31] [Server thread/INFO] [enderio]: Dark Steel Upgrades: Thaumcraft integration loaded
[18:55:31] [Server thread/INFO] [FML]: Injecting itemstacks
[18:55:31] [Server thread/INFO] [FML]: Itemstack injection complete
[18:55:31] [Server thread/INFO] [net.minecraft.server.dedicated.DedicatedServer]: Loading properties
[18:55:31] [Server thread/INFO] [net.minecraft.server.dedicated.DedicatedServer]: Default game type: SURVIVAL
[18:55:31] [Server thread/INFO] [net.minecraft.server.dedicated.DedicatedServer]: Generating keypair
[18:55:31] [Server thread/INFO] [net.minecraft.server.dedicated.DedicatedServer]: Starting Minecraft server on 25.17.37.187:25565
[18:55:31] [Server thread/INFO] [net.minecraft.network.NetworkSystem]: Using default channel type
[18:55:32] [Hats Download/Read Hats Thread/INFO] [Hats]: [7.0.0] Loaded 198 hats. 68 are contributor hats.
[18:55:32] [Server thread/WARN] [net.minecraft.server.dedicated.DedicatedServer]: **** SERVER IS RUNNING IN OFFLINE/INSECURE MODE!
[18:55:32] [Server thread/WARN] [net.minecraft.server.dedicated.DedicatedServer]: The server will make no attempt to authenticate usernames. Beware.
[18:55:32] [Server thread/WARN] [net.minecraft.server.dedicated.DedicatedServer]: While this makes the game possible to play without internet access, it also opens up the ability for hackers to connect with any username they choose.
[18:55:32] [Server thread/WARN] [net.minecraft.server.dedicated.DedicatedServer]: To change this, set "online-mode" to "true" in the server.properties file.
[18:55:32] [Server thread/INFO] [THAUMCRAFT]: Checking for mod & oredict compatibilities
[18:55:32] [Server thread/INFO] [THAUMCRAFT]: Adding entities to MFR safari net blacklist.
[18:55:32] [Server thread/INFO] [Chisel]: Loading recipes...
[18:55:32] [Server thread/INFO] [Chisel]: Skipping feature bloodMagic as its required mod bloodmagic was missing.
[18:55:32] [Server thread/INFO] [Chisel]: 71 Feature's recipes loaded.
[18:55:32] [Server thread/WARN] [FML]: Potentially Dangerous alternative prefix `enderio` for name `capbank_basic2normal`, expected `enderiopowertools`. This could be a intended override, but in most cases indicates a broken mod.
[18:55:33] [Server thread/WARN] [FML]: Potentially Dangerous alternative prefix `enderio` for name `capbank_normal2vibrant`, expected `enderiopowertools`. This could be a intended override, but in most cases indicates a broken mod.
[18:55:33] [Server thread/INFO] [FML]: Applying holder lookups
[18:55:33] [Server thread/INFO] [FML]: Holder lookups applied
[18:55:33] [Server thread/WARN] [Bewitchment]: Couldn't find the correct default duration for effect.blindness
[18:55:33] [Server thread/WARN] [Bewitchment]: Couldn't find the correct default duration for effect.digSpeed
[18:55:33] [Server thread/WARN] [Bewitchment]: Couldn't find the correct default duration for effect.glowing
[18:55:33] [Server thread/WARN] [Bewitchment]: Couldn't find the correct default duration for effect.unluck
[18:55:33] [Server thread/INFO] [Bewitchment]: It's a fact, she is exactly that!
[18:55:33] [Server thread/INFO] [Bewitchment]: A harbinger of death from the world of witchcraft,
[18:55:33] [Server thread/INFO] [Bewitchment]: And she's feeding them cakes and her ale to this innocent boy,
[18:55:33] [Server thread/INFO] [Bewitchment]: And her magic brings dismay!
[18:55:33] [Server thread/INFO] [Bewitchment]: I hear her in the wind, the bane of our town
[18:55:33] [Server thread/INFO] [Bewitchment]: Come with me, father, I'm to expose a heathen
[18:55:33] [Server thread/INFO] [EnderCore]: [Handlers] Skipping class com.enderio.core.client.handlers.OreDictTooltipHandler, it is not loaded on this side.
[18:55:33] [Server thread/INFO] [EnderCore]: [Handlers] Skipping class com.enderio.core.client.handlers.ClientHandler, it is not loaded on this side.
[18:55:33] [Server thread/INFO] [EnderCore]: [Handlers] Skipping class com.enderio.core.client.handlers.FluidVisualsHandler, it is not loaded on this side.
[18:55:33] [Server thread/INFO] [EnderCore]: [Handlers] Skipping class com.enderio.core.client.handlers.EnchantTooltipHandler, it is not loaded on this side.
[18:55:33] [Server thread/INFO] [EnderCore]: [Handlers] Skipping class com.enderio.core.client.handlers.SpecialTooltipHandler, it is not loaded on this side.
[18:55:33] [Server thread/INFO] [EnderCore]: [Handlers] Registering handler Scheduler to busses: [FORGE]
[18:55:33] [Server thread/INFO] [EnderCore]: [Handlers] Registering handler RightClickCropHandler to busses: [FORGE]
[18:55:33] [Server thread/INFO] [EnderCore]: [Handlers] Registering handler FireworkHandler to busses: [FORGE]
[18:55:33] [Server thread/INFO] [EnderCore]: [Handlers] Registering handler AutoSmeltHandler to busses: [FORGE]
[18:55:33] [Server thread/INFO] [EnderCore]: [Handlers] Registering handler JoinMessageHandler to busses: [FORGE]
[18:55:33] [Server thread/INFO] [EnderCore]: [Handlers] Registering handler FluidSpawnHandler to busses: [FORGE]
[18:55:33] [Server thread/INFO] [EnderCore]: [Handlers] Registering handler XPBoostHandler to busses: [FORGE]
[18:55:33] [Server thread/INFO] [EnderCore]: Sending dummy event to all mods
[18:55:33] [Server thread/INFO] [EnderCore]: Reloading ingame configs for modid: endercore
[18:55:33] [Server thread/INFO] [enderio]: Reloading config file...
[18:55:33] [Server thread/INFO] [enderio]: Config reload finished
[18:55:33] [Server thread/WARN] [enderio]: @Devs: See github for dev env setup; set INDEV if needed.
[18:55:33] [Server thread/INFO] [enderio]: Sending whitelist message to Chisel and Bits for block blockDecoration1
[18:55:33] [Server thread/INFO] [enderio]: Sending whitelist message to Chisel and Bits for block blockDecoration2
[18:55:33] [Server thread/INFO] [enderio]: Sending whitelist message to Chisel and Bits for block blockDecoration3
[18:55:33] [Server thread/INFO] [enderio]: Registered permission enderio.gui.block_dark_steel_anvil
[18:55:33] [Server thread/INFO] [enderio]: Registered permission enderio.gui.item_basic_item_filter
[18:55:33] [Server thread/INFO] [enderio]: Registered permission enderio.gui.item_advanced_item_filter
[18:55:33] [Server thread/INFO] [enderio]: Registered permission enderio.gui.item_limited_item_filter
[18:55:33] [Server thread/INFO] [enderio]: Registered permission enderio.gui.item_big_item_filter
[18:55:33] [Server thread/INFO] [enderio]: Registered permission enderio.gui.item_big_advanced_item_filter
[18:55:33] [Server thread/INFO] [enderio]: Registered permission enderio.gui.item_existing_item_filter
[18:55:33] [Server thread/INFO] [enderio]: Registered permission enderio.gui.item_mod_item_filter
[18:55:33] [Server thread/INFO] [enderio]: Registered permission enderio.gui.item_power_item_filter
[18:55:33] [Server thread/INFO] [enderio]: Registered permission enderio.gui.item_soul_filter_normal
[18:55:33] [Server thread/INFO] [enderio]: Registered permission enderio.gui.item_soul_filter_big
[18:55:33] [Server thread/INFO] [enderio]: Registered permission enderio.gui.item_enchantment_filter_normal
[18:55:33] [Server thread/INFO] [enderio]: Registered permission enderio.gui.item_enchantment_filter_big
[18:55:33] [Server thread/INFO] [enderio]: Registered permission enderio.gui.item_fluid_filter
[18:55:33] [Server thread/INFO] [enderio]: Registered permission enderio.gui.item_redstone_not_filter
[18:55:33] [Server thread/INFO] [enderio]: Registered permission enderio.gui.item_redstone_or_filter
[18:55:33] [Server thread/INFO] [enderio]: Registered permission enderio.gui.item_redstone_and_filter
[18:55:33] [Server thread/INFO] [enderio]: Registered permission enderio.gui.item_redstone_nor_filter
[18:55:33] [Server thread/INFO] [enderio]: Registered permission enderio.gui.item_redstone_nand_filter
[18:55:33] [Server thread/INFO] [enderio]: Registered permission enderio.gui.item_redstone_xor_filter
[18:55:33] [Server thread/INFO] [enderio]: Registered permission enderio.gui.item_redstone_xnor_filter
[18:55:33] [Server thread/INFO] [enderio]: Registered permission enderio.gui.item_redstone_toggle_filter
[18:55:33] [Server thread/INFO] [enderio]: Registered permission enderio.gui.item_redstone_counting_filter
[18:55:33] [Server thread/INFO] [enderio]: Registered permission enderio.gui.item_redstone_sensor_filter
[18:55:33] [Server thread/INFO] [enderio]: Registered permission enderio.gui.item_redstone_timer_filter
[18:55:33] [Server thread/INFO] [enderio]: Registered permission enderio.gui.item_dark_steel_helmet
[18:55:33] [Server thread/INFO] [enderio]: Registered permission enderio.gui.item_dark_steel_chestplate
[18:55:33] [Server thread/INFO] [enderio]: Registered permission enderio.gui.item_dark_steel_leggings
[18:55:33] [Server thread/INFO] [enderio]: Registered permission enderio.gui.item_dark_steel_boots
[18:55:33] [Server thread/INFO] [enderio]: Registered permission enderio.gui.item_end_steel_helmet
[18:55:33] [Server thread/INFO] [enderio]: Registered permission enderio.gui.item_end_steel_chestplate
[18:55:33] [Server thread/INFO] [enderio]: Registered permission enderio.gui.item_end_steel_leggings
[18:55:33] [Server thread/INFO] [enderio]: Registered permission enderio.gui.item_end_steel_boots
[18:55:33] [Server thread/INFO] [enderio]: Registered permission enderio.gui.block_conduit_bundle
[18:55:33] [Server thread/INFO] [enderio]: Registered permission enderio.gui.block_simple_furnace
[18:55:33] [Server thread/INFO] [enderio]: Registered permission enderio.gui.block_simple_alloy_smelter
[18:55:33] [Server thread/INFO] [enderio]: Registered permission enderio.gui.block_alloy_smelter
[18:55:33] [Server thread/INFO] [enderio]: Registered permission enderio.gui.block_enhanced_alloy_smelter
[18:55:33] [Server thread/INFO] [enderio]: Registered permission enderio.gui.block_buffer
[18:55:33] [Server thread/INFO] [enderio]: Registered permission enderio.gui.block_enchanter
[18:55:33] [Server thread/INFO] [enderio]: Registered permission enderio.gui.block_farm_station
[18:55:33] [Server thread/INFO] [enderio]: Registered permission enderio.gui.block_combustion_generator
[18:55:33] [Server thread/INFO] [enderio]: Registered permission enderio.gui.block_enhanced_combustion_generator
[18:55:33] [Server thread/INFO] [enderio]: Registered permission enderio.gui.block_simple_stirling_generator
[18:55:33] [Server thread/INFO] [enderio]: Registered permission enderio.gui.block_stirling_generator
[18:55:33] [Server thread/INFO] [enderio]: Registered permission enderio.gui.block_zombie_generator
[18:55:33] [Server thread/INFO] [enderio]: Registered permission enderio.gui.block_franken_zombie_generator
[18:55:33] [Server thread/INFO] [enderio]: Registered permission enderio.gui.block_ender_generator
[18:55:33] [Server thread/INFO] [enderio]: Registered permission enderio.gui.block_lava_generator
[18:55:33] [Server thread/INFO] [enderio]: Registered permission enderio.gui.block_killer_joe
[18:55:33] [Server thread/INFO] [enderio]: Registered permission enderio.gui.block_attractor_obelisk
[18:55:33] [Server thread/INFO] [enderio]: Registered permission enderio.gui.block_aversion_obelisk
[18:55:34] [Server thread/INFO] [enderio]: Registered permission enderio.gui.block_inhibitor_obelisk
[18:55:34] [Server thread/INFO] [enderio]: Registered permission enderio.gui.block_relocator_obelisk
[18:55:34] [Server thread/INFO] [enderio]: Registered permission enderio.gui.block_weather_obelisk
[18:55:34] [Server thread/INFO] [enderio]: Registered permission enderio.gui.block_experience_obelisk
[18:55:34] [Server thread/INFO] [enderio]: Registered permission enderio.gui.block_painter
[18:55:34] [Server thread/INFO] [enderio]: Registered permission enderio.gui.block_simple_sag_mill
[18:55:34] [Server thread/INFO] [enderio]: Registered permission enderio.gui.block_sag_mill
[18:55:34] [Server thread/INFO] [enderio]: Registered permission enderio.gui.block_enhanced_sag_mill
[18:55:34] [Server thread/INFO] [enderio]: Registered permission enderio.gui.block_slice_and_splice
[18:55:34] [Server thread/INFO] [enderio]: Registered permission enderio.gui.block_soul_binder
[18:55:34] [Server thread/INFO] [enderio]: Registered permission enderio.gui.block_powered_spawner
[18:55:34] [Server thread/INFO] [enderio]: Registered permission enderio.gui.block_vat
[18:55:34] [Server thread/INFO] [enderio]: Registered permission enderio.gui.block_enhanced_vat
[18:55:34] [Server thread/INFO] [enderio]: Registered permission enderio.gui.block_simple_wired_charger
[18:55:34] [Server thread/INFO] [enderio]: Registered permission enderio.gui.block_wired_charger
[18:55:34] [Server thread/INFO] [enderio]: Registered permission enderio.gui.block_enhanced_wired_charger
[18:55:34] [Server thread/INFO] [enderio]: Registered permission enderio.gui.block_tank
[18:55:34] [Server thread/INFO] [enderio]: Registered permission enderio.gui.block_transceiver
[18:55:34] [Server thread/INFO] [enderio]: Registered permission enderio.gui.block_vacuum_chest
[18:55:34] [Server thread/INFO] [enderio]: Registered permission enderio.gui.block_xp_vacuum
[18:55:34] [Server thread/INFO] [enderio]: Registered permission enderio.gui.block_travel_anchor
[18:55:34] [Server thread/INFO] [enderio]: Registered permission enderio.gui.block_tele_pad
[18:55:34] [Server thread/INFO] [enderio]: Registered permission enderio.gui.block_dialing_device
[18:55:34] [Server thread/INFO] [enderio]: Registered permission enderio.gui.block_impulse_hopper
[18:55:34] [Server thread/INFO] [enderio]: Registered permission enderio.gui.block_simple_crafter
[18:55:34] [Server thread/INFO] [enderio]: Registered permission enderio.gui.block_crafter
[18:55:34] [Server thread/INFO] [enderio]: Registered permission enderio.gui.block_creative_spawner
[18:55:34] [Server thread/INFO] [enderio]: Registered permission enderio.gui.block_cap_bank
[18:55:34] [Server thread/INFO] [enderio]: Registered permission enderio.gui.block_power_monitor
[18:55:34] [Server thread/INFO] [enderio]: Registered permission enderio.gui.block_advanced_power_monitor
[18:55:34] [Server thread/INFO] [mca]: MCA has successfully loaded 259 skins.
[18:55:34] [Server thread/WARN] [FML]: Potentially Dangerous alternative prefix `minecraft` for name `tiletombstone`, expected `mca`. This could be a intended override, but in most cases indicates a broken mod.
[18:55:34] [Server thread/WARN] [FML]: Potentially Dangerous alternative prefix `minecraft` for name `tilememorial`, expected `mca`. This could be a intended override, but in most cases indicates a broken mod.
[18:55:34] [Server thread/WARN] [FML]: Potentially Dangerous alternative prefix `minecraft` for name `cubex2 iron furnace`, expected `morefurnaces`. This could be a intended override, but in most cases indicates a broken mod.
[18:55:34] [Server thread/WARN] [FML]: Potentially Dangerous alternative prefix `minecraft` for name `cubex2 gold furnace`, expected `morefurnaces`. This could be a intended override, but in most cases indicates a broken mod.
[18:55:34] [Server thread/WARN] [FML]: Potentially Dangerous alternative prefix `minecraft` for name `cubex2 diamond furnace`, expected `morefurnaces`. This could be a intended override, but in most cases indicates a broken mod.
[18:55:34] [Server thread/WARN] [FML]: Potentially Dangerous alternative prefix `minecraft` for name `cubex2 obsidian furnace`, expected `morefurnaces`. This could be a intended override, but in most cases indicates a broken mod.
[18:55:34] [Server thread/WARN] [FML]: Potentially Dangerous alternative prefix `minecraft` for name `cubex2 netherrack furnace`, expected `morefurnaces`. This could be a intended override, but in most cases indicates a broken mod.
[18:55:34] [Server thread/WARN] [FML]: Potentially Dangerous alternative prefix `minecraft` for name `cubex2 copper furnace`, expected `morefurnaces`. This could be a intended override, but in most cases indicates a broken mod.
[18:55:34] [Server thread/WARN] [FML]: Potentially Dangerous alternative prefix `minecraft` for name `cubex2 silver furnace`, expected `morefurnaces`. This could be a intended override, but in most cases indicates a broken mod.
[18:55:34] [Server thread/WARN] [Chisel]: Mod bewitchment is using deprecated IMC variation:add! This IMC type may be removed soon, please notify the author of this mod.
[18:55:34] [Server thread/ERROR] [Chisel]: Could not handle data nethersteel|bewitchment:nethersteel_chisel|11 for IMC type ADD_VARIATION. This was sent from mod bewitchment.
!! This is a bug in that mod !!
Swallowing error and continuing...
[18:55:34] [Server thread/INFO] [STDERR]: [team.chisel.common.integration.imc.IMCHandler:handle:148]: java.lang.ArrayIndexOutOfBoundsException: 11
[18:55:34] [Server thread/INFO] [STDERR]: [team.chisel.common.integration.imc.IMCHandler:handle:148]:     at com.bewitchment.common.integration.chisel.BlockNetherSteelChiseled.func_176203_a(BlockNetherSteelChiseled.java:32)
[18:55:34] [Server thread/INFO] [STDERR]: [team.chisel.common.integration.imc.IMCHandler:handle:148]:     at team.chisel.common.integration.imc.IMCHandler.handle(IMCHandler.java:91)
[18:55:34] [Server thread/INFO] [STDERR]: [team.chisel.common.integration.imc.IMCHandler:handle:148]:     at team.chisel.common.integration.imc.IMCHandler.handleMessage(IMCHandler.java:42)
[18:55:34] [Server thread/INFO] [STDERR]: [team.chisel.common.integration.imc.IMCHandler:handle:148]:     at team.chisel.Chisel.onIMC(Chisel.java:217)
[18:55:34] [Server thread/INFO] [STDERR]: [team.chisel.common.integration.imc.IMCHandler:handle:148]:     at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
[18:55:34] [Server thread/INFO] [STDERR]: [team.chisel.common.integration.imc.IMCHandler:handle:148]:     at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
[18:55:34] [Server thread/INFO] [STDERR]: [team.chisel.common.integration.imc.IMCHandler:handle:148]:     at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
[18:55:34] [Server thread/INFO] [STDERR]: [team.chisel.common.integration.imc.IMCHandler:handle:148]:     at java.lang.reflect.Method.invoke(Unknown Source)
[18:55:34] [Server thread/INFO] [STDERR]: [team.chisel.common.integration.imc.IMCHandler:handle:148]:     at net.minecraftforge.fml.common.FMLModContainer.handleModStateEvent(FMLModContainer.java:637)
[18:55:34] [Server thread/INFO] [STDERR]: [team.chisel.common.integration.imc.IMCHandler:handle:148]:     at sun.reflect.GeneratedMethodAccessor9.invoke(Unknown Source)
[18:55:34] [Server thread/INFO] [STDERR]: [team.chisel.common.integration.imc.IMCHandler:handle:148]:     at com.google.common.eventbus.Subscriber.invokeSubscriberMethod(Subscriber.java:91)
[18:55:34] [Server thread/INFO] [STDERR]: [team.chisel.common.integration.imc.IMCHandler:handle:148]:     at com.google.common.eventbus.Subscriber$SynchronizedSubscriber.invokeSubscriberMethod(Subscriber.java:150)
[18:55:34] [Server thread/INFO] [STDERR]: [team.chisel.common.integration.imc.IMCHandler:handle:148]:     at com.google.common.eventbus.Subscriber$1.run(Subscriber.java:76)
[18:55:34] [Server thread/INFO] [STDERR]: [team.chisel.common.integration.imc.IMCHandler:handle:148]:     at com.google.common.util.concurrent.MoreExecutors$DirectExecutor.execute(MoreExecutors.java:399)
[18:55:34] [Server thread/INFO] [STDERR]: [team.chisel.common.integration.imc.IMCHandler:handle:148]:     at com.google.common.eventbus.Subscriber.dispatchEvent(Subscriber.java:71)
[18:55:34] [Server thread/INFO] [STDERR]: [team.chisel.common.integration.imc.IMCHandler:handle:148]:     at com.google.common.eventbus.Dispatcher$PerThreadQueuedDispatcher.dispatch(Dispatcher.java:116)
[18:55:34] [Server thread/INFO] [STDERR]: [team.chisel.common.integration.imc.IMCHandler:handle:148]:     at com.google.common.eventbus.EventBus.post(EventBus.java:217)
[18:55:34] [Server thread/INFO] [STDERR]: [team.chisel.common.integration.imc.IMCHandler:handle:148]:     at net.minecraftforge.fml.common.LoadController.sendEventToModContainer(LoadController.java:219)
[18:55:34] [Server thread/INFO] [STDERR]: [team.chisel.common.integration.imc.IMCHandler:handle:148]:     at net.minecraftforge.fml.common.LoadController.propogateStateMessage(LoadController.java:197)
[18:55:34] [Server thread/INFO] [STDERR]: [team.chisel.common.integration.imc.IMCHandler:handle:148]:     at net.minecraftforge.fml.common.LoadController.distributeStateMessage(LoadController.java:320)
[18:55:34] [Server thread/INFO] [STDERR]: [team.chisel.common.integration.imc.IMCHandler:handle:148]:     at net.minecraftforge.fml.common.Loader.initializeMods(Loader.java:747)
[18:55:34] [Server thread/INFO] [STDERR]: [team.chisel.common.integration.imc.IMCHandler:handle:148]:     at net.minecraftforge.fml.server.FMLServerHandler.finishServerLoading(FMLServerHandler.java:108)
[18:55:34] [Server thread/INFO] [STDERR]: [team.chisel.common.integration.imc.IMCHandler:handle:148]:     at net.minecraftforge.fml.common.FMLCommonHandler.onServerStarted(FMLCommonHandler.java:338)
[18:55:34] [Server thread/INFO] [STDERR]: [team.chisel.common.integration.imc.IMCHandler:handle:148]:     at net.minecraft.server.dedicated.DedicatedServer.func_71197_b(DedicatedServer.java:219)
[18:55:34] [Server thread/INFO] [STDERR]: [team.chisel.common.integration.imc.IMCHandler:handle:148]:     at net.minecraft.server.MinecraftServer.run(MinecraftServer.java:486)
[18:55:34] [Server thread/INFO] [STDERR]: [team.chisel.common.integration.imc.IMCHandler:handle:148]:     at java.lang.Thread.run(Unknown Source)
[18:55:34] [Server thread/INFO] [Chisel]: Received 36 IMC messages from mod bewitchment.
[18:55:34] [Server thread/INFO] [Chisel]: Received 22 IMC messages from mod tconstruct.
[18:55:34] [Server thread/INFO] [enderio]: Processing IMC message recipe:xml from endercore
[18:55:35] [Server thread/INFO] [enderio]: Reading user recipe file user_recipes.xml
[18:55:35] [Server thread/INFO] [enderio]: Valid IMC recipes to be processed:
[18:55:35] [Server thread/INFO] [enderio]:  * Enchanter: endercore:xpboost from IMC from mod 'endercore'
[18:55:35] [Server thread/INFO] [enderio]:  * Enchanter: endercore:autosmelt from IMC from mod 'endercore'
[18:55:35] [Server thread/WARN] [enderio]: The supplied recipe BasicManyToOneRecipe [output=3xitem.item_alloy_ingot@9, recipe=Recipe [input=[RecipeInput [input=1xitem.tf2item@0, useMeta=true], RecipeInput [input=1xitem.ingotIron@0, useMeta=true], RecipeInput [input=1xitem.tf2item@1, useMeta=true]], output=[crazypants.enderio.base.recipe.RecipeOutput@7a2d708], energyRequired=10000]] for Alloy Smelter may be a duplicate to: BasicManyToOneRecipe [output=3xitem.item_alloy_ingot@9, recipe=Recipe [input=[RecipeInput [input=1xitem.tf2item@1, useMeta=true], RecipeInput [input=1xitem.ingotIron@0, useMeta=true], RecipeInput [input=1xitem.tf2item@0, useMeta=true]], output=[crazypants.enderio.base.recipe.RecipeOutput@7a2d708], energyRequired=10000]]
[18:55:35] [Server thread/WARN] [enderio]: The supplied recipe BasicManyToOneRecipe [output=3xitem.item_alloy_ingot@9, recipe=Recipe [input=[RecipeInput [input=1xitem.bewitchment.silver_ingot@0, useMeta=true], RecipeInput [input=1xitem.ingotIron@0, useMeta=true], RecipeInput [input=1xitem.tf2item@1, useMeta=true]], output=[crazypants.enderio.base.recipe.RecipeOutput@7a2d708], energyRequired=10000]] for Alloy Smelter may be a duplicate to: BasicManyToOneRecipe [output=3xitem.item_alloy_ingot@9, recipe=Recipe [input=[RecipeInput [input=1xitem.tf2item@1, useMeta=true], RecipeInput [input=1xitem.ingotIron@0, useMeta=true], RecipeInput [input=1xitem.bewitchment.silver_ingot@0, useMeta=true]], output=[crazypants.enderio.base.recipe.RecipeOutput@7a2d708], energyRequired=10000]]
[18:55:35] [Server thread/WARN] [enderio]: The supplied recipe BasicManyToOneRecipe [output=3xitem.item_alloy_ingot@9, recipe=Recipe [input=[RecipeInput [input=1xitem.bewitchment.silver_ingot@0, useMeta=true], RecipeInput [input=1xitem.ingotIron@0, useMeta=true], RecipeInput [input=1xitem.tf2item@0, useMeta=true]], output=[crazypants.enderio.base.recipe.RecipeOutput@7a2d708], energyRequired=10000]] for Alloy Smelter may be a duplicate to: BasicManyToOneRecipe [output=3xitem.item_alloy_ingot@9, recipe=Recipe [input=[RecipeInput [input=1xitem.tf2item@0, useMeta=true], RecipeInput [input=1xitem.ingotIron@0, useMeta=true], RecipeInput [input=1xitem.bewitchment.silver_ingot@0, useMeta=true]], output=[crazypants.enderio.base.recipe.RecipeOutput@7a2d708], energyRequired=10000]]
[18:55:35] [Server thread/WARN] [enderio]: The supplied recipe BasicManyToOneRecipe [output=3xitem.item_alloy_ingot@9, recipe=Recipe [input=[RecipeInput [input=1xitem.tconstruct.ingots@1, useMeta=true], RecipeInput [input=1xitem.ingotIron@0, useMeta=true], RecipeInput [input=1xitem.tf2item@1, useMeta=true]], output=[crazypants.enderio.base.recipe.RecipeOutput@7a2d708], energyRequired=10000]] for Alloy Smelter may be a duplicate to: BasicManyToOneRecipe [output=3xitem.item_alloy_ingot@9, recipe=Recipe [input=[RecipeInput [input=1xitem.tf2item@1, useMeta=true], RecipeInput [input=1xitem.ingotIron@0, useMeta=true], RecipeInput [input=1xitem.tconstruct.ingots@1, useMeta=true]], output=[crazypants.enderio.base.recipe.RecipeOutput@7a2d708], energyRequired=10000]]
[18:55:35] [Server thread/WARN] [enderio]: The supplied recipe BasicManyToOneRecipe [output=3xitem.item_alloy_ingot@9, recipe=Recipe [input=[RecipeInput [input=1xitem.tconstruct.ingots@1, useMeta=true], RecipeInput [input=1xitem.ingotIron@0, useMeta=true], RecipeInput [input=1xitem.tf2item@0, useMeta=true]], output=[crazypants.enderio.base.recipe.RecipeOutput@7a2d708], energyRequired=10000]] for Alloy Smelter may be a duplicate to: BasicManyToOneRecipe [output=3xitem.item_alloy_ingot@9, recipe=Recipe [input=[RecipeInput [input=1xitem.tf2item@0, useMeta=true], RecipeInput [input=1xitem.ingotIron@0, useMeta=true], RecipeInput [input=1xitem.tconstruct.ingots@1, useMeta=true]], output=[crazypants.enderio.base.recipe.RecipeOutput@7a2d708], energyRequired=10000]]
[18:55:35] [Server thread/WARN] [enderio]: The supplied recipe BasicManyToOneRecipe [output=3xitem.item_alloy_ingot@9, recipe=Recipe [input=[RecipeInput [input=1xitem.tconstruct.ingots@1, useMeta=true], RecipeInput [input=1xitem.ingotIron@0, useMeta=true], RecipeInput [input=1xitem.bewitchment.silver_ingot@0, useMeta=true]], output=[crazypants.enderio.base.recipe.RecipeOutput@7a2d708], energyRequired=10000]] for Alloy Smelter may be a duplicate to: BasicManyToOneRecipe [output=3xitem.item_alloy_ingot@9, recipe=Recipe [input=[RecipeInput [input=1xitem.bewitchment.silver_ingot@0, useMeta=true], RecipeInput [input=1xitem.ingotIron@0, useMeta=true], RecipeInput [input=1xitem.tconstruct.ingots@1, useMeta=true]], output=[crazypants.enderio.base.recipe.RecipeOutput@7a2d708], energyRequired=10000]]
[18:55:35] [Server thread/WARN] [enderio]: The supplied recipe BasicManyToOneRecipe [output=3xitem.item_alloy_ingot@9, recipe=Recipe [input=[RecipeInput [input=1xitem.tconstruct.ingots@0, useMeta=true], RecipeInput [input=1xitem.ingotIron@0, useMeta=true], RecipeInput [input=1xitem.tf2item@1, useMeta=true]], output=[crazypants.enderio.base.recipe.RecipeOutput@7a2d708], energyRequired=10000]] for Alloy Smelter may be a duplicate to: BasicManyToOneRecipe [output=3xitem.item_alloy_ingot@9, recipe=Recipe [input=[RecipeInput [input=1xitem.tf2item@1, useMeta=true], RecipeInput [input=1xitem.ingotIron@0, useMeta=true], RecipeInput [input=1xitem.tconstruct.ingots@0, useMeta=true]], output=[crazypants.enderio.base.recipe.RecipeOutput@7a2d708], energyRequired=10000]]
[18:55:35] [Server thread/WARN] [enderio]: The supplied recipe BasicManyToOneRecipe [output=3xitem.item_alloy_ingot@9, recipe=Recipe [input=[RecipeInput [input=1xitem.tconstruct.ingots@0, useMeta=true], RecipeInput [input=1xitem.ingotIron@0, useMeta=true], RecipeInput [input=1xitem.tf2item@0, useMeta=true]], output=[crazypants.enderio.base.recipe.RecipeOutput@7a2d708], energyRequired=10000]] for Alloy Smelter may be a duplicate to: BasicManyToOneRecipe [output=3xitem.item_alloy_ingot@9, recipe=Recipe [input=[RecipeInput [input=1xitem.tf2item@0, useMeta=true], RecipeInput [input=1xitem.ingotIron@0, useMeta=true], RecipeInput [input=1xitem.tconstruct.ingots@0, useMeta=true]], output=[crazypants.enderio.base.recipe.RecipeOutput@7a2d708], energyRequired=10000]]
[18:55:35] [Server thread/WARN] [enderio]: The supplied recipe BasicManyToOneRecipe [output=3xitem.item_alloy_ingot@9, recipe=Recipe [input=[RecipeInput [input=1xitem.tconstruct.ingots@0, useMeta=true], RecipeInput [input=1xitem.ingotIron@0, useMeta=true], RecipeInput [input=1xitem.bewitchment.silver_ingot@0, useMeta=true]], output=[crazypants.enderio.base.recipe.RecipeOutput@7a2d708], energyRequired=10000]] for Alloy Smelter may be a duplicate to: BasicManyToOneRecipe [output=3xitem.item_alloy_ingot@9, recipe=Recipe [input=[RecipeInput [input=1xitem.bewitchment.silver_ingot@0, useMeta=true], RecipeInput [input=1xitem.ingotIron@0, useMeta=true], RecipeInput [input=1xitem.tconstruct.ingots@0, useMeta=true]], output=[crazypants.enderio.base.recipe.RecipeOutput@7a2d708], energyRequired=10000]]
[18:55:35] [Server thread/WARN] [enderio]: The supplied recipe BasicManyToOneRecipe [output=3xitem.item_alloy_ingot@9, recipe=Recipe [input=[RecipeInput [input=1xitem.tconstruct.ingots@0, useMeta=true], RecipeInput [input=1xitem.ingotIron@0, useMeta=true], RecipeInput [input=1xitem.tconstruct.ingots@1, useMeta=true]], output=[crazypants.enderio.base.recipe.RecipeOutput@7a2d708], energyRequired=10000]] for Alloy Smelter may be a duplicate to: BasicManyToOneRecipe [output=3xitem.item_alloy_ingot@9, recipe=Recipe [input=[RecipeInput [input=1xitem.tconstruct.ingots@1, useMeta=true], RecipeInput [input=1xitem.ingotIron@0, useMeta=true], RecipeInput [input=1xitem.tconstruct.ingots@0, useMeta=true]], output=[crazypants.enderio.base.recipe.RecipeOutput@7a2d708], energyRequired=10000]]
[18:55:35] [Server thread/INFO] [enderio]: Created 6 synthetic recipes for 3xitem.item_material@38 => 1xitem.item_material@3
[18:55:35] [Server thread/INFO] [enderio]: Created 6 synthetic recipes for 4xitem.netherquartz@0 => 1xtile.block_fused_quartz@0
[18:55:35] [Server thread/INFO] [enderio]: Created 6 synthetic recipes for 1xtile.quartzBlock@0 => 1xtile.block_fused_quartz@0
[18:55:35] [Server thread/INFO] [enderio]: Created 6 synthetic recipes for 1xtile.glass@0 => 1xtile.block_fused_glass@0
[18:55:35] [Server thread/INFO] [enderio]: Created 6 synthetic recipes for 1xtile.sapling@0 => 1xtile.deadbush@0
[18:55:35] [Server thread/INFO] [enderio]: Created 6 synthetic recipes for 9xitem.item_material@28 => 1xitem.enderPearl@0
[18:55:35] [Server thread/INFO] [FML]: Injecting itemstacks
[18:55:35] [Server thread/INFO] [FML]: Itemstack injection complete
[18:55:35] [Server thread/INFO] [Bewitchment]: No extra alchemy found, freezing potion will default to its potion object!
[18:55:35] [Server thread/INFO] [Bewitchment]: No extra alchemy found, sinking potion will default to its potion object!
[18:55:37] [Server thread/INFO] [THAUMCRAFT]: Loaded 22 research entries from thaumcraft:research/alchemy
[18:55:37] [Server thread/INFO] [THAUMCRAFT]: Loaded 5 research entries from thaumcraft:research/eldritch
[18:55:37] [Server thread/INFO] [THAUMCRAFT]: Loaded 20 research entries from thaumcraft:research/basics
[18:55:37] [Server thread/INFO] [THAUMCRAFT]: Loaded 23 research entries from thaumcraft:research/auromancy
[18:55:37] [Server thread/INFO] [THAUMCRAFT]: Loaded 12 research entries from thaumcraft:research/scans
[18:55:37] [Server thread/INFO] [THAUMCRAFT]: Loaded 20 research entries from thaumcraft:research/artifice
[18:55:37] [Server thread/INFO] [THAUMCRAFT]: Loaded 17 research entries from thaumcraft:research/infusion
[18:55:37] [Server thread/INFO] [THAUMCRAFT]: Loaded 29 research entries from thaumcraft:research/golemancy
[18:55:37] [Server thread/INFO] [botania]: The Lexica Botania has 26879 words.
[18:55:38] [Server thread/INFO] [chancecubes]: Adding minecraft:bedrock:0 to NRB array.
[18:55:38] [Server thread/INFO] [chancecubes]: Death and destruction prepared! (And Cookies. Cookies were also prepared.)
[18:55:38] [Server thread/INFO] [STDOUT]: [jaredbgreat.dldungeons.themes.ThemeReader:readNBT:229]: [DLDUNGEONS] Loading custom NBT tags (nbt.cfg)
[18:55:38] [Server thread/INFO] [STDOUT]: [jaredbgreat.dldungeons.themes.ThemeReader:readLoot:276]: [DLDUNGEONS] Loading chest loot file (chests.cfg)
[18:55:38] [Server thread/INFO] [STDOUT]: [jaredbgreat.dldungeons.themes.ThemeReader:readThemes:191]: [DLDUNGEONS] Found 0 special chest configs.
[18:55:38] [Server thread/INFO] [STDOUT]: [jaredbgreat.dldungeons.themes.ThemeReader:readThemes:196]: [DLDUNGEONS] Found 12 themes.
[18:55:39] [Server thread/WARN] [enderio]: Could not find Build Craft Wrench definition. Wrench integration with other mods may fail
[18:55:39] [Server thread/INFO] [enderio]: Thaumcraft integration: Adding aspects...
[18:55:39] [Server thread/INFO] [enderio]: Thaumcraft integration: Added aspects for 11 items and 10 ore dictionary entrties
[18:55:39] [Server thread/INFO] [tconstruct-TinkerSmeltery]: Started adding oredict melting recipes
[18:55:40] [Server thread/INFO] [tconstruct-TinkerSmeltery]: Oredict melting recipes finished in 857.283487 ms
[18:55:40] [Server thread/WARN] [enderio]: Item used in cast recipe 'Things [things=[OreThing [name=nuggetSignalum, ores=[]]], size=1, ] ([])' doesn't smelt into a fluid
[18:55:40] [Server thread/WARN] [enderio]: Item used in cast recipe 'Things [things=[OreThing [name=nuggetEnderium, ores=[]]], size=1, ] ([])' doesn't smelt into a fluid
[18:55:40] [Server thread/WARN] [enderio]: Item used in cast recipe 'Things [things=[OreThing [name=nuggetLumium, ores=[]]], size=1, ] ([])' doesn't smelt into a fluid
[18:55:40] [Server thread/INFO] [iChunUtil]: =============================================================
[18:55:40] [Server thread/INFO] [iChunUtil]: By using iChunUtil you therefore agree to the EULA of the mod. It may be found in the jar file of the mod. The latest version will be available on iChun's website or on GitHub.
[18:55:40] [Server thread/INFO] [iChunUtil]: You can disable this console message by going to the iChunUtil config and setting the "eulaAcknowledged" config to "true" (no quotes).
[18:55:40] [Server thread/INFO] [fluidcows]: [FluidCows] Added 0 breeding variants!
[18:55:40] [Server thread/INFO] [fluidcows]: [FluidCows] This is info! Support 57 fluids. Can spawn 57 cows.
[18:55:40] [Server thread/INFO] [FML]: Forge Mod Loader has successfully loaded 47 mods
[18:55:40] [Server thread/INFO] [net.minecraft.server.dedicated.DedicatedServer]: Preparing level "world"
[18:55:40] [Server thread/INFO] [FML]: Injecting existing registry data into this server instance
[18:55:41] [Server thread/INFO] [FML]: Applying holder lookups
[18:55:41] [Server thread/INFO] [FML]: Holder lookups applied
[18:55:41] [Server thread/INFO] [FML]: Loading dimension 0 (world) (net.minecraft.server.dedicated.DedicatedServer@78dfb235)
[18:55:42] [Server thread/ERROR] [FML]: Parsing error loading built-in advancement bewitchment:recipes/ritual_chalk
com.google.gson.JsonSyntaxException: Unknown recipe 'bewitchment:ritual_chalk'
    at net.minecraft.advancements.AdvancementRewards$Deserializer.deserialize(AdvancementRewards.java:171) ~[l$a.class:?]
    at net.minecraft.advancements.AdvancementRewards$Deserializer.deserialize(AdvancementRewards.java:147) ~[l$a.class:?]
    at com.google.gson.internal.bind.TreeTypeAdapter.read(TreeTypeAdapter.java:69) ~[TreeTypeAdapter.class:?]
    at com.google.gson.Gson.fromJson(Gson.java:887) ~[Gson.class:?]
    at com.google.gson.Gson.fromJson(Gson.java:952) ~[Gson.class:?]
    at com.google.gson.internal.bind.TreeTypeAdapter$GsonContextImpl.deserialize(TreeTypeAdapter.java:162) ~[TreeTypeAdapter$GsonContextImpl.class:?]
    at net.minecraft.util.JsonUtils.func_188179_a(SourceFile:439) ~[rc.class:?]
    at net.minecraft.util.JsonUtils.func_188177_a(SourceFile:455) ~[rc.class:?]
    at net.minecraft.advancements.Advancement$Builder.func_192059_a(SourceFile:203) ~[i$a.class:?]
    at net.minecraft.advancements.AdvancementManager$1.deserialize(AdvancementManager.java:50) ~[ns$1.class:?]
    at net.minecraft.advancements.AdvancementManager$1.deserialize(AdvancementManager.java:46) ~[ns$1.class:?]
    at net.minecraft.util.JsonUtils.func_188173_a(SourceFile:492) ~[rc.class:?]
    at net.minecraft.util.JsonUtils.func_193839_a(SourceFile:532) ~[rc.class:?]
    at net.minecraftforge.common.ForgeHooks.lambda$loadAdvancements$0(ForgeHooks.java:1369) ~[ForgeHooks.class:?]
    at net.minecraftforge.common.crafting.CraftingHelper.findFiles(CraftingHelper.java:821) [CraftingHelper.class:?]
    at net.minecraftforge.common.ForgeHooks.loadAdvancements(ForgeHooks.java:1351) [ForgeHooks.class:?]
    at net.minecraftforge.common.ForgeHooks.loadAdvancements(ForgeHooks.java:1325) [ForgeHooks.class:?]
    at net.minecraft.advancements.AdvancementManager.func_192779_a(AdvancementManager.java:69) [ns.class:?]
    at net.minecraft.advancements.AdvancementManager.<init>(AdvancementManager.java:60) [ns.class:?]
    at net.minecraft.world.WorldServer.func_175643_b(WorldServer.java:156) [oo.class:?]
    at net.minecraft.server.MinecraftServer.func_71247_a(MinecraftServer.java:298) [MinecraftServer.class:?]
    at net.minecraft.server.dedicated.DedicatedServer.func_71197_b(DedicatedServer.java:270) [nz.class:?]
    at net.minecraft.server.MinecraftServer.run(MinecraftServer.java:486) [MinecraftServer.class:?]
    at java.lang.Thread.run(Unknown Source) [?:1.8.0_211]
[18:55:42] [Server thread/INFO] [net.minecraft.advancements.AdvancementList]: Loaded 773 advancements
[18:55:42] [Server thread/INFO] [THAUMCRAFT]: Creating aura cache for world 0
[18:55:42] [Server thread/INFO] [FML]: Loading dimension -1 (world) (net.minecraft.server.dedicated.DedicatedServer@78dfb235)
[18:55:42] [Server thread/INFO] [THAUMCRAFT]: Creating aura cache for world -1
[18:55:42] [Server thread/INFO] [FML]: Loading dimension 1 (world) (net.minecraft.server.dedicated.DedicatedServer@78dfb235)
[18:55:42] [Server thread/INFO] [THAUMCRAFT]: Creating aura cache for world 1
[18:55:42] [Server thread/INFO] [net.minecraft.server.MinecraftServer]: Preparing start region for level 0
[18:55:42] [Server thread/INFO] [EnderCore ASM]: Transforming Class [net.minecraft.world.chunk.storage.ExtendedBlockStorage], Method [func_76663_a]
[18:55:42] [Server thread/INFO] [EnderCore ASM]: Transforming net.minecraft.world.chunk.storage.ExtendedBlockStorage Finished.
[18:55:43] [Server thread/INFO] [net.minecraft.server.MinecraftServer]: Preparing spawn area: 10%
[18:55:44] [Server thread/INFO] [net.minecraft.server.MinecraftServer]: Preparing spawn area: 54%
[18:55:45] [Server thread/INFO] [net.minecraft.server.dedicated.DedicatedServer]: Done (4.722s)! For help, type "help" or "?"
[18:55:45] [Server thread/INFO] [projecte]: Starting server-side EMC mapping.
[18:55:45] [Server thread/WARN] [projecte]: Can not get Fluid 'obisidan.molten'
[18:55:45] [Server thread/WARN] [projecte]: Can not get Fluid 'glass.molten'
[18:55:45] [Server thread/WARN] [projecte]: Can not get Fluid 'iron.molten'
[18:55:45] [Server thread/WARN] [projecte]: Can not get Fluid 'gold.molten'
[18:55:45] [Server thread/WARN] [projecte]: Can not get Fluid 'copper.molten'
[18:55:45] [Server thread/WARN] [projecte]: Can not get Fluid 'tin.molten'
[18:55:45] [Server thread/WARN] [projecte]: Can not get Fluid 'silver.molten'
[18:55:45] [Server thread/WARN] [projecte]: Can not get Fluid 'lead.molten'
[18:55:45] [Server thread/WARN] [projecte]: Can not get Fluid 'nickel.molten'
[18:55:45] [Server thread/WARN] [projecte]: Can not get Fluid 'aluminum.molten'
[18:55:45] [Server thread/WARN] [projecte]: Can not get Fluid 'ardite.molten'
[18:55:45] [Server thread/WARN] [projecte]: Can not get Fluid 'cobalt.molten'
[18:55:45] [Server thread/WARN] [projecte]: Can not get Fluid 'platinum.molten'
[18:55:45] [Server thread/WARN] [projecte]: Can not get Fluid 'obsidian.molten'
[18:55:45] [Server thread/WARN] [projecte]: Can not get Fluid 'electrum.molten'
[18:55:45] [Server thread/WARN] [projecte]: Can not get Fluid 'invar.molten'
[18:55:45] [Server thread/WARN] [projecte]: Can not get Fluid 'signalum.molten'
[18:55:45] [Server thread/WARN] [projecte]: Can not get Fluid 'lumium.molten'
[18:55:45] [Server thread/WARN] [projecte]: Can not get Fluid 'enderium.molten'
[18:55:45] [Server thread/WARN] [projecte]: Can not get Fluid 'mithril.molten'
[18:55:45] [Server thread/WARN] [projecte]: Can not get Fluid 'bronze.molten'
[18:55:45] [Server thread/WARN] [projecte]: Can not get Fluid 'aluminumbrass.molten'
[18:55:45] [Server thread/WARN] [projecte]: Can not get Fluid 'manyullyn.molten'
[18:55:45] [Server thread/WARN] [projecte]: Can not get Fluid 'alumite.molten'
[18:55:45] [Server thread/WARN] [projecte]: Can not get Fluid 'emerald.liquid'
[18:55:45] [Server thread/WARN] [projecte]: Can not get Fluid 'cryotheum'
[18:55:45] [Server thread/WARN] [projecte]: Can not get Fluid 'pryotheum'
[18:55:46] [Server thread/WARN] [projecte]: EMC Exploit: ingredients (0 + 9*minecraft:iron_nugget:0 => 1*minecraft:iron_ingot:0) cost 252 but output value is 256
[18:55:46] [Server thread/WARN] [projecte]: EMC Exploit: "0 + 9*minecraft:gold_nugget:0 => 1*minecraft:gold_ingot:0" ingredient cost: 2043 value of result: 2048 setValueFromConversion: 0 + 8*OD: ingotIron => 1*minecraft:gold_ingot:0
[18:55:46] [Server thread/WARN] [projecte]: EMC Exploit: ingredients (0 + 9*thaumcraft:nugget:6 => 1*thaumcraft:ingot:0) cost 2043 but output value is 2048
[18:55:46] [Server thread/WARN] [projecte]: EMC Exploit: "0 + 9*thaumcraft:nugget:4 => 1*rafradek_tf2_weapons:itemtf2:1" ingredient cost: 504 value of result: 512 setValueFromConversion: 0 + 2*OD: ingotIron => 1*rafradek_tf2_weapons:itemtf2:1
[18:55:46] [Server thread/WARN] [projecte]: EMC Exploit: "0 + 9*thaumcraft:nugget:1 => 1*rafradek_tf2_weapons:itemtf2:0" ingredient cost: 126 value of result: 128 setValueFromConversion: 0 + 1*OD: ingotIron => 2*rafradek_tf2_weapons:itemtf2:0
[18:55:46] [Server thread/WARN] [projecte]: EMC Exploit: ingredients (0 + 1*NSSFAKE:/[1xtile.stone@3, 1xtile.chisel.diorite@0, 1xtile.chisel.diorite@1, 1xtile.chisel.diorite@2, 1xtile.chisel.diorite@3, 1xtile.chisel.diorite@4, 1xtile.chisel.diorite@5, 1xtile.chisel.diorite@6, 1xtile.chisel.diorite@7, 1xtile.chisel.diorite@8, 1xtile.chisel.diorite@9, 1xtile.chisel.diorite@10, 1xtile.chisel.diorite@11, 1xtile.chisel.diorite@12, 1xtile.chisel.diorite@13, 1xtile.chisel.diorite@14, 1xtile.chisel.diorite@15, 1xtile.chisel.diorite@0, 1xtile.chisel.diorite@1, 1xtile.chisel.diorite@2, 1xtile.chisel.diorite@3, 1xtile.chisel.diorite@4, 1xtile.chisel.diorite@5, 1xtile.chisel.diorite@6, 1xtile.chisel.diorite@7, 1xtile.chisel.diorite@8, 1xtile.chisel.diorite@9, 1xtile.chisel.diorite@10, 1xtile.chisel.diorite@11, 1xtile.chisel.diorite@12, 1xtile.chisel.diorite@13, 1xtile.chisel.diorite@14, 1xtile.chisel.diorite@15, 1xtile.chisel.diorite@0] + 1*NSSFAKE:/[1xtile.stonebrick@0, 1xtile.chisel.cobblestone@0, 1xtile.chisel.cobblestone@1, 1xtile.chisel.cobblestone@2, 1xtile.chisel.cobblestone@3, 1xtile.chisel.cobblestone@4, 1xtile.chisel.cobblestone@5, 1xtile.chisel.cobblestone@6, 1xtile.chisel.cobblestone@7, 1xtile.chisel.cobblestone@8, 1xtile.chisel.cobblestone@9, 1xtile.chisel.cobblestone@10, 1xtile.chisel.cobblestone@11, 1xtile.chisel.cobblestone@12, 1xtile.chisel.cobblestone@13, 1xtile.chisel.cobblestone@14, 1xtile.chisel.cobblestone@15, 1xtile.chisel.cobblestone@0, 1xtile.chisel.cobblestone@1, 1xtile.chisel.cobblestone@2, 1xtile.chisel.cobblestone@3, 1xtile.chisel.cobblestone@4, 1xtile.chisel.cobblestone@5, 1xtile.chisel.cobblestone@6, 1xtile.chisel.cobblestone@7, 1xtile.chisel.cobblestone@8, 1xtile.chisel.cobblestone@9, 1xtile.chisel.cobblestone@0, 1xtile.chisel.cobblestone@1, 1xtile.chisel.cobblestone@2, 1xtile.chisel.cobblestone@3, 1xtile.chisel.cobblestone@4, 1xtile.chisel.cobblestone@5, 1xtile.chisel.cobblestone@6, 1xtile.chisel.cobblestone@7, 1xtile.chisel.cobblestone@8, 1xtile.chisel.cobblestone@9] => 2*minecraft:stone:5) cost 17 but output value is 16
[18:55:46] [Server thread/WARN] [projecte]: EMC Exploit: "0 + 9*tconstruct:nuggets:2 => 1*tconstruct:ingots:2" ingredient cost: 2043 value of result: 2048 setValueFromConversion: 0 + 1*OD: ingotCobalt + 1*OD: ingotArdite => 1*tconstruct:ingots:2
[18:55:46] [Server thread/WARN] [projecte]: EMC Exploit: "0 + 9*tconstruct:nuggets:1 => 1*tconstruct:ingots:1" ingredient cost: 1017 value of result: 1024 setValueFromConversion: 0 + 4*OD: ingotIron => 1*tconstruct:ingots:1
[18:55:46] [Server thread/WARN] [projecte]: EMC Exploit: "0 + 9*tconstruct:nuggets:0 => 1*tconstruct:ingots:0" ingredient cost: 1017 value of result: 1024 setValueFromConversion: 0 + 4*OD: ingotIron => 1*tconstruct:ingots:0
[18:55:46] [Server thread/WARN] [projecte]: EMC Exploit: "0 + 9*enderio:item_alloy_nugget:2 => 1*enderio:item_alloy_ingot:2" ingredient cost: 3519 value of result: 3520 setValueFromConversion: 0 + 1*minecraft:ender_pearl:0 + 1*OD: ingotEnergeticAlloy => 1*enderio:item_alloy_ingot:2
[18:55:46] [Server thread/WARN] [projecte]: EMC Exploit: "0 + 9*enderio:item_alloy_nugget:3 => 1*enderio:item_alloy_ingot:3" ingredient cost: 90 value of result: 96 setValueFromConversion: 0 + 1*OD: itemSilicon + 1*OD: dustRedstone => 1*enderio:item_alloy_ingot:3
[18:55:46] [Server thread/WARN] [projecte]: EMC Exploit: "0 + 9*enderio:item_alloy_nugget:0 => 1*enderio:item_alloy_ingot:0" ingredient cost: 315 value of result: 320 setValueFromConversion: 0 + 1*OD: itemSilicon + 1*minecraft:coal:1 + 1*OD: ingotIron => 1*enderio:item_alloy_ingot:0
[18:55:46] [Server thread/WARN] [projecte]: EMC Exploit: "0 + 9*enderio:item_alloy_nugget:1 => 1*enderio:item_alloy_ingot:1" ingredient cost: 2493 value of result: 2496 setValueFromConversion: 0 + 1*OD: ingotGold + 1*OD: dustRedstone + 1*OD: dustGlowstone => 1*enderio:item_alloy_ingot:1
[18:55:46] [Server thread/WARN] [projecte]: EMC Exploit: "0 + 9*enderio:item_alloy_nugget:6 => 1*enderio:item_alloy_ingot:6" ingredient cost: 351 value of result: 352 setValueFromConversion: 0 + 1*minecraft:coal:1 + 1*OD: ingotIron + 1*minecraft:obsidian:0 => 1*enderio:item_alloy_ingot:6
[18:55:46] [Server thread/WARN] [projecte]: EMC Exploit: "0 + 9*enderio:item_alloy_nugget:4 => 1*enderio:item_alloy_ingot:4" ingredient cost: 315 value of result: 320 setValueFromConversion: 0 + 1*OD: dustRedstone + 1*OD: ingotIron => 1*enderio:item_alloy_ingot:4
[18:55:46] [Server thread/WARN] [projecte]: EMC Exploit: "0 + 9*enderio:item_alloy_nugget:5 => 1*enderio:item_alloy_ingot:5" ingredient cost: 1278 value of result: 1280 setValueFromConversion: 0 + 1*minecraft:ender_pearl:0 + 1*OD: ingotIron => 1*enderio:item_alloy_ingot:5
[18:55:46] [Server thread/WARN] [projecte]: EMC Exploit: "0 + 9*NSSFAKE:/[1xitem.nugget@3, 1xitem.bewitchment.silver_nugget@0] => 1*bewitchment:silver_ingot:0" ingredient cost: 504 value of result: 512 setValueFromConversion: 0 + 2*OD: ingotIron => 1*bewitchment:silver_ingot:0
[18:55:46] [Server thread/INFO] [projecte]: Registered 1479 EMC values. (took 711 ms)
[18:55:47] [Thread-10/INFO] [THAUMCRAFT]: Starting aura thread for dim 0
[18:55:47] [Thread-11/INFO] [THAUMCRAFT]: Starting aura thread for dim -1
[18:55:47] [Thread-12/INFO] [THAUMCRAFT]: Starting aura thread for dim 1
[18:55:47] [Server thread/INFO] [THAUMCRAFT]: Removing aura cache for world -1
[18:55:47] [Server thread/INFO] [FML]: Unloading dimension -1
[18:55:47] [Server thread/INFO] [THAUMCRAFT]: Removing aura cache for world 1
[18:55:48] [Server thread/INFO] [FML]: Unloading dimension 1
[18:55:49] [Thread-11/INFO] [THAUMCRAFT]: Stopping aura thread for dim -1
[18:55:49] [Thread-12/INFO] [THAUMCRAFT]: Stopping aura thread for dim 1
[18:56:00] [Netty Server IO #1/INFO] [FML]: Client protocol version 2
[18:56:00] [Netty Server IO #1/INFO] [FML]: Client attempting to join with 48 mods : minecraft@1.12.2,tconstruct@1.12.2-2.12.0.157,grapplemod@1.12.2-v11.1,mclib@1.0.2,dldungeonsjbg@1.12.5,enderiointegrationforestry@5.0.46,enderiomachines@5.0.46,morefurnaces@1.10.5,hats@7.0.0,baubles@1.5.2,cxlibrary@1.6.1,mca@1.12.2-5.3.1,fluidcows@1.1.20,jei@4.15.0.268,veinminermodsupport@0.38.2,botania@r1.10-361,enderiopowertools@5.0.46,rafradek_tf2_weapons@1.5.12,radixcore@1.12.x-2.2.1,enderio@5.0.46,projecte@1.12.2-PE1.4.1,roguelike@1.8.0,patchouli@1.0-20,endercore@1.12.2-0.5.59,mantle@1.12-1.3.3.55,mcp@9.42,ctm@MC1.12.2-0.3.3.22,journeymap@1.12.2-5.5.5b9,veinminer@0.38.2,enderiointegrationticlate@5.0.46,bewitchment@@VERSION@,FML@8.0.99.99,enderiobase@5.0.46,llibrary@1.7.19,chancecubes@1.12.2-4.0.0.271,enderiointegrationtic@5.0.46,enderioconduitsappliedenergistics@5.0.46,chisel@MC1.12.2-0.2.1.35,enderioconduitsopencomputers@5.0.46,waila@1.8.26,enderioconduitsrefinedstorage@5.0.46,ichunutil@7.2.1,enderstorage@2.4.5.135,thaumcraft@6.1.BETA26,forge@14.23.5.2838,ruins@17.2,codechickenlib@3.2.1.351,enderioconduits@5.0.46
[18:56:00] [Netty Server IO #1/INFO] [journeymap]: CLIENT
[18:56:00] [Netty Server IO #1/INFO] [CodeChickenLib-ConfigSync]: Skipping config sync, No mods have registered a syncable config.
[18:56:02] [Server thread/INFO] [FML]: [Server thread] Server side modded connection established
[18:56:02] [Server thread/WARN] [net.minecraft.entity.EntityList]: Skipping Entity with id minecraft:
[18:56:02] [Server thread/INFO] [net.minecraft.server.management.PlayerList]: Avvic[/25.17.37.187:50528] logged in with entity id 254 at (1890.052164986642, 50.0, 521.4557350860293)
[18:56:02] [Server thread/INFO] [net.minecraft.server.dedicated.DedicatedServer]: Avvic joined the game
[18:56:06] [Server thread/INFO] [EnderCore]: Sending server configs to client for com.enderio.core.common.config.ConfigHandler
[18:56:06] [Thread-18/INFO] [chancecubes]: No custom rewards detected for the current user!
[18:56:08] [Server thread/WARN] [net.minecraft.server.MinecraftServer]: Can't keep up! Did the system time change, or is the server overloaded? Running 6285ms behind, skipping 125 tick(s)
[18:56:15] [Netty Server IO #2/INFO] [FML]: Client protocol version 2
[18:56:15] [Netty Server IO #2/INFO] [FML]: Client attempting to join with 48 mods : minecraft@1.12.2,tconstruct@1.12.2-2.12.0.157,grapplemod@1.12.2-v11.1,mclib@1.0.2,dldungeonsjbg@1.12.5,enderiointegrationforestry@5.0.46,enderiomachines@5.0.46,morefurnaces@1.10.5,hats@7.0.0,baubles@1.5.2,cxlibrary@1.6.1,mca@1.12.2-5.3.1,fluidcows@1.1.20,jei@4.15.0.268,veinminermodsupport@0.38.2,botania@r1.10-361,enderiopowertools@5.0.46,rafradek_tf2_weapons@1.5.12,radixcore@1.12.x-2.2.1,enderio@5.0.46,projecte@1.12.2-PE1.4.1,roguelike@1.8.0,patchouli@1.0-20,endercore@1.12.2-0.5.59,mantle@1.12-1.3.3.55,mcp@9.42,ctm@MC1.12.2-0.3.3.22,journeymap@1.12.2-5.5.5b9,veinminer@0.38.2,enderiointegrationticlate@5.0.46,bewitchment@@VERSION@,FML@8.0.99.99,enderiobase@5.0.46,llibrary@1.7.19,chancecubes@1.12.2-4.0.0.271,enderiointegrationtic@5.0.46,enderioconduitsappliedenergistics@5.0.46,chisel@MC1.12.2-0.2.1.35,enderioconduitsopencomputers@5.0.46,waila@1.8.26,enderioconduitsrefinedstorage@5.0.46,ichunutil@7.2.1,enderstorage@2.4.5.135,thaumcraft@6.1.BETA26,forge@14.23.5.2838,ruins@17.2,codechickenlib@3.2.1.351,enderioconduits@5.0.46
[18:56:15] [Netty Server IO #2/INFO] [journeymap]: CLIENT
[18:56:15] [Netty Server IO #2/INFO] [CodeChickenLib-ConfigSync]: Skipping config sync, No mods have registered a syncable config.
[18:56:19] [Server thread/INFO] [STDOUT]: [atomicstryker.ruins.common.ChunkLoggerData:func_76184_a:24]: Ruins chunks logged: 4732
[18:56:35] [Netty Server IO #2/ERROR] [FML]: NetworkDispatcher exception
java.io.IOException: An existing connection was forcibly closed by the remote host
    at sun.nio.ch.SocketDispatcher.writev0(Native Method) ~[?:1.8.0_211]
    at sun.nio.ch.SocketDispatcher.writev(Unknown Source) ~[?:1.8.0_211]
    at sun.nio.ch.IOUtil.write(Unknown Source) ~[?:1.8.0_211]
    at sun.nio.ch.SocketChannelImpl.write(Unknown Source) ~[?:1.8.0_211]
    at io.netty.channel.socket.nio.NioSocketChannel.doWrite(NioSocketChannel.java:432) ~[NioSocketChannel.class:?]
    at io.netty.channel.AbstractChannel$AbstractUnsafe.flush0(AbstractChannel.java:856) [AbstractChannel$AbstractUnsafe.class:?]
    at io.netty.channel.nio.AbstractNioChannel$AbstractNioUnsafe.forceFlush(AbstractNioChannel.java:368) [AbstractNioChannel$AbstractNioUnsafe.class:?]
    at io.netty.channel.nio.NioEventLoop.processSelectedKey(NioEventLoop.java:618) [NioEventLoop.class:?]
    at io.netty.channel.nio.NioEventLoop.processSelectedKeysOptimized(NioEventLoop.java:559) [NioEventLoop.class:?]
    at io.netty.channel.nio.NioEventLoop.processSelectedKeys(NioEventLoop.java:476) [NioEventLoop.class:?]
    at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:438) [NioEventLoop.class:?]
    at io.netty.util.concurrent.SingleThreadEventExecutor$5.run(SingleThreadEventExecutor.java:858) [SingleThreadEventExecutor$5.class:?]
[18:56:35] [Server thread/INFO] [net.minecraft.network.NetHandlerPlayServer]: Albert_Minestine lost connection: Disconnected
[18:56:35] [Server thread/INFO] [net.minecraft.server.dedicated.DedicatedServer]: Albert_Minestine left the game
[18:57:00] [Netty Server IO #3/INFO] [FML]: Client protocol version 2
[18:57:00] [Netty Server IO #3/INFO] [FML]: Client attempting to join with 48 mods : minecraft@1.12.2,tconstruct@1.12.2-2.12.0.157,grapplemod@1.12.2-v11.1,mclib@1.0.2,dldungeonsjbg@1.12.5,enderiointegrationforestry@5.0.46,enderiomachines@5.0.46,morefurnaces@1.10.5,hats@7.0.0,baubles@1.5.2,cxlibrary@1.6.1,mca@1.12.2-5.3.1,fluidcows@1.1.20,jei@4.15.0.268,veinminermodsupport@0.38.2,botania@r1.10-361,enderiopowertools@5.0.46,rafradek_tf2_weapons@1.5.12,radixcore@1.12.x-2.2.1,enderio@5.0.46,projecte@1.12.2-PE1.4.1,roguelike@1.8.0,patchouli@1.0-20,endercore@1.12.2-0.5.59,mantle@1.12-1.3.3.55,mcp@9.42,ctm@MC1.12.2-0.3.3.22,journeymap@1.12.2-5.5.5b9,veinminer@0.38.2,enderiointegrationticlate@5.0.46,bewitchment@@VERSION@,FML@8.0.99.99,enderiobase@5.0.46,llibrary@1.7.19,chancecubes@1.12.2-4.0.0.271,enderiointegrationtic@5.0.46,enderioconduitsappliedenergistics@5.0.46,chisel@MC1.12.2-0.2.1.35,enderioconduitsopencomputers@5.0.46,waila@1.8.26,enderioconduitsrefinedstorage@5.0.46,ichunutil@7.2.1,enderstorage@2.4.5.135,thaumcraft@6.1.BETA26,forge@14.23.5.2838,ruins@17.2,codechickenlib@3.2.1.351,enderioconduits@5.0.46
[18:57:00] [Netty Server IO #3/INFO] [journeymap]: CLIENT
[18:57:00] [Netty Server IO #3/INFO] [CodeChickenLib-ConfigSync]: Skipping config sync, No mods have registered a syncable config.
[18:57:19] [Netty Server IO #3/ERROR] [FML]: NetworkDispatcher exception
[18:57:19] [Server thread/INFO] [net.minecraft.network.NetHandlerPlayServer]: Albert_Minestine lost connection: Disconnected
[18:57:19] [Server thread/INFO] [net.minecraft.server.dedicated.DedicatedServer]: Albert_Minestine left the game
[18:59:14] [Netty Server IO #4/INFO] [FML]: Client protocol version 2
[18:59:14] [Netty Server IO #4/INFO] [FML]: Client attempting to join with 48 mods : minecraft@1.12.2,tconstruct@1.12.2-2.12.0.157,grapplemod@1.12.2-v11.1,mclib@1.0.2,dldungeonsjbg@1.12.5,enderiointegrationforestry@5.0.46,enderiomachines@5.0.46,morefurnaces@1.10.5,hats@7.0.0,baubles@1.5.2,cxlibrary@1.6.1,mca@1.12.2-5.3.1,fluidcows@1.1.20,jei@4.15.0.268,veinminermodsupport@0.38.2,botania@r1.10-361,enderiopowertools@5.0.46,rafradek_tf2_weapons@1.5.12,radixcore@1.12.x-2.2.1,enderio@5.0.46,projecte@1.12.2-PE1.4.1,roguelike@1.8.0,patchouli@1.0-20,endercore@1.12.2-0.5.59,mantle@1.12-1.3.3.55,mcp@9.42,ctm@MC1.12.2-0.3.3.22,journeymap@1.12.2-5.5.5b9,veinminer@0.38.2,enderiointegrationticlate@5.0.46,bewitchment@@VERSION@,FML@8.0.99.99,enderiobase@5.0.46,llibrary@1.7.19,chancecubes@1.12.2-4.0.0.271,enderiointegrationtic@5.0.46,enderioconduitsappliedenergistics@5.0.46,chisel@MC1.12.2-0.2.1.35,enderioconduitsopencomputers@5.0.46,waila@1.8.26,enderioconduitsrefinedstorage@5.0.46,ichunutil@7.2.1,enderstorage@2.4.5.135,thaumcraft@6.1.BETA26,forge@14.23.5.2838,ruins@17.2,codechickenlib@3.2.1.351,enderioconduits@5.0.46
[18:59:14] [Netty Server IO #4/INFO] [journeymap]: CLIENT
[18:59:14] [Netty Server IO #4/INFO] [CodeChickenLib-ConfigSync]: Skipping config sync, No mods have registered a syncable config.
[18:59:33] [Netty Server IO #4/ERROR] [FML]: NetworkDispatcher exception
[18:59:33] [Server thread/INFO] [net.minecraft.network.NetHandlerPlayServer]: Albert_Minestine lost connection: Disconnected
[18:59:33] [Server thread/INFO] [net.minecraft.server.dedicated.DedicatedServer]: Albert_Minestine left the game
[19:10:36] [Netty Server IO #5/INFO] [FML]: Client protocol version 2
[19:10:36] [Netty Server IO #5/INFO] [FML]: Client attempting to join with 48 mods : minecraft@1.12.2,tconstruct@1.12.2-2.12.0.157,grapplemod@1.12.2-v11.1,mclib@1.0.2,dldungeonsjbg@1.12.5,enderiointegrationforestry@5.0.46,enderiomachines@5.0.46,morefurnaces@1.10.5,hats@7.0.0,baubles@1.5.2,cxlibrary@1.6.1,mca@1.12.2-5.3.1,fluidcows@1.1.20,jei@4.15.0.268,veinminermodsupport@0.38.2,botania@r1.10-361,enderiopowertools@5.0.46,rafradek_tf2_weapons@1.5.12,radixcore@1.12.x-2.2.1,enderio@5.0.46,projecte@1.12.2-PE1.4.1,roguelike@1.8.0,patchouli@1.0-20,endercore@1.12.2-0.5.59,mantle@1.12-1.3.3.55,mcp@9.42,ctm@MC1.12.2-0.3.3.22,journeymap@1.12.2-5.5.5b9,veinminer@0.38.2,enderiointegrationticlate@5.0.46,bewitchment@@VERSION@,FML@8.0.99.99,enderiobase@5.0.46,llibrary@1.7.19,chancecubes@1.12.2-4.0.0.271,enderiointegrationtic@5.0.46,enderioconduitsappliedenergistics@5.0.46,chisel@MC1.12.2-0.2.1.35,enderioconduitsopencomputers@5.0.46,waila@1.8.26,enderioconduitsrefinedstorage@5.0.46,ichunutil@7.2.1,enderstorage@2.4.5.135,thaumcraft@6.1.BETA26,forge@14.23.5.2838,ruins@17.2,codechickenlib@3.2.1.351,enderioconduits@5.0.46
[19:10:36] [Netty Server IO #5/INFO] [journeymap]: CLIENT
[19:10:36] [Netty Server IO #5/INFO] [CodeChickenLib-ConfigSync]: Skipping config sync, No mods have registered a syncable config.
[19:10:55] [Netty Server IO #5/ERROR] [FML]: NetworkDispatcher exception
[19:10:55] [Server thread/INFO] [net.minecraft.network.NetHandlerPlayServer]: Albert_Minestine lost connection: Disconnected
[19:10:55] [Server thread/INFO] [net.minecraft.server.dedicated.DedicatedServer]: Albert_Minestine left the game
[19:13:59] [Server thread/WARN] [FML]: Thaumcraft loaded a new chunk [137, 2] in dimension 0 (overworld) while populating chunk [137, 3], causing cascading worldgen lag.
[19:13:59] [Server thread/WARN] [FML]: Please report this to the mod's issue tracker. This log can be disabled in the Forge config.
[19:14:11] [Server thread/WARN] [FML]: Ruins Mod loaded a new chunk [135, 0] in dimension 0 (overworld) while populating chunk [136, 1], causing cascading worldgen lag.
[19:14:11] [Server thread/WARN] [FML]: Please report this to the mod's issue tracker. This log can be disabled in the Forge config.
[19:14:11] [Server thread/WARN] [FML]: Ruins Mod loaded a new chunk [135, -1] in dimension 0 (overworld) while populating chunk [136, 1], causing cascading worldgen lag.
[19:14:11] [Server thread/WARN] [FML]: Ruins Mod loaded a new chunk [136, 0] in dimension 0 (overworld) while populating chunk [136, 1], causing cascading worldgen lag.
[19:14:11] [Server thread/WARN] [FML]: Ruins Mod loaded a new chunk [136, -1] in dimension 0 (overworld) while populating chunk [136, 1], causing cascading worldgen lag.
[19:14:20] [Server thread/WARN] [FML]: Thaumcraft loaded a new chunk [143, 8] in dimension 0 (overworld) while populating chunk [143, 9], causing cascading worldgen lag.
[19:14:20] [Server thread/WARN] [FML]: Please report this to the mod's issue tracker. This log can be disabled in the Forge config.
[19:16:02] [Server thread/WARN] [FML]: Thaumcraft loaded a new chunk [146, -1] in dimension 0 (overworld) while populating chunk [147, 0], causing cascading worldgen lag.
[19:16:02] [Server thread/WARN] [FML]: Please report this to the mod's issue tracker. This log can be disabled in the Forge config.
[19:16:02] [Server thread/WARN] [FML]: Thaumcraft loaded a new chunk [147, -1] in dimension 0 (overworld) while populating chunk [147, 0], causing cascading worldgen lag.
[19:16:10] [Server thread/WARN] [net.minecraft.world.storage.loot.LootTable]: Tried to over-fill a container
[19:16:22] [Server thread/WARN] [FML]: Ruins Mod loaded a new chunk [153, -4] in dimension 0 (overworld) while populating chunk [153, -3], causing cascading worldgen lag.
[19:16:22] [Server thread/WARN] [FML]: Please report this to the mod's issue tracker. This log can be disabled in the Forge config.
[19:16:33] [Server thread/WARN] [FML]: Ruins Mod loaded a new chunk [141, -4] in dimension 0 (overworld) while populating chunk [142, -4], causing cascading worldgen lag.
[19:16:33] [Server thread/WARN] [FML]: Please report this to the mod's issue tracker. This log can be disabled in the Forge config.
[19:16:33] [Server thread/WARN] [FML]: Ruins Mod loaded a new chunk [141, -5] in dimension 0 (overworld) while populating chunk [142, -4], causing cascading worldgen lag.
[19:16:39] [Server thread/WARN] [FML]: Ruins Mod loaded a new chunk [146, -7] in dimension 0 (overworld) while populating chunk [147, -7], causing cascading worldgen lag.
[19:16:39] [Server thread/WARN] [FML]: Please report this to the mod's issue tracker. This log can be disabled in the Forge config.
[19:17:00] [Server thread/INFO] [chancecubes]: Triggered the reward with the name of: chancecubes:Hot_Tub
[19:17:16] [Server thread/WARN] [FML]: Ruins Mod loaded a new chunk [133, -8] in dimension 0 (overworld) while populating chunk [134, -7], causing cascading worldgen lag.
[19:17:16] [Server thread/WARN] [FML]: Please report this to the mod's issue tracker. This log can be disabled in the Forge config.
[19:17:18] [Server thread/WARN] [FML]: Thaumcraft loaded a new chunk [133, -2] in dimension 0 (overworld) while populating chunk [133, -1], causing cascading worldgen lag.
[19:17:18] [Server thread/WARN] [FML]: Please report this to the mod's issue tracker. This log can be disabled in the Forge config.
[19:17:32] [Server thread/WARN] [FML]: Thaumcraft loaded a new chunk [130, -3] in dimension 0 (overworld) while populating chunk [130, -2], causing cascading worldgen lag.
[19:17:32] [Server thread/WARN] [FML]: Please report this to the mod's issue tracker. This log can be disabled in the Forge config.
[19:17:32] [Server thread/WARN] [FML]: Thaumcraft loaded a new chunk [129, -3] in dimension 0 (overworld) while populating chunk [130, -2], causing cascading worldgen lag.
[19:17:32] [Server thread/WARN] [FML]: Thaumcraft loaded a new chunk [130, -6] in dimension 0 (overworld) while populating chunk [130, -5], causing cascading worldgen lag.
[19:17:41] [Server thread/WARN] [FML]: Ruins Mod loaded a new chunk [128, -9] in dimension 0 (overworld) while populating chunk [129, -8], causing cascading worldgen lag.
[19:17:41] [Server thread/WARN] [FML]: Please report this to the mod's issue tracker. This log can be disabled in the Forge config.
[19:18:00] [Server thread/WARN] [FML]: Bewitchment loaded a new chunk [125, -9] in dimension 0 (overworld) while populating chunk [126, -8], causing cascading worldgen lag.
[19:18:00] [Server thread/WARN] [FML]: Please report this to the mod's issue tracker. This log can be disabled in the Forge config.
[19:21:31] [Netty Server IO #6/INFO] [FML]: Client protocol version 2
[19:21:31] [Netty Server IO #6/INFO] [FML]: Client attempting to join with 48 mods : minecraft@1.12.2,tconstruct@1.12.2-2.12.0.157,grapplemod@1.12.2-v11.1,mclib@1.0.2,dldungeonsjbg@1.12.5,enderiointegrationforestry@5.0.46,enderiomachines@5.0.46,morefurnaces@1.10.5,hats@7.0.0,baubles@1.5.2,cxlibrary@1.6.1,mca@1.12.2-5.3.1,fluidcows@1.1.20,jei@4.15.0.268,veinminermodsupport@0.38.2,botania@r1.10-361,enderiopowertools@5.0.46,rafradek_tf2_weapons@1.5.12,radixcore@1.12.x-2.2.1,enderio@5.0.46,projecte@1.12.2-PE1.4.1,roguelike@1.8.0,patchouli@1.0-20,endercore@1.12.2-0.5.59,mantle@1.12-1.3.3.55,mcp@9.42,ctm@MC1.12.2-0.3.3.22,journeymap@1.12.2-5.5.5b9,veinminer@0.38.2,enderiointegrationticlate@5.0.46,bewitchment@@VERSION@,FML@8.0.99.99,enderiobase@5.0.46,llibrary@1.7.19,chancecubes@1.12.2-4.0.0.271,enderiointegrationtic@5.0.46,enderioconduitsappliedenergistics@5.0.46,chisel@MC1.12.2-0.2.1.35,enderioconduitsopencomputers@5.0.46,waila@1.8.26,enderioconduitsrefinedstorage@5.0.46,ichunutil@7.2.1,enderstorage@2.4.5.135,thaumcraft@6.1.BETA26,forge@14.23.5.2838,ruins@17.2,codechickenlib@3.2.1.351,enderioconduits@5.0.46
[19:21:31] [Netty Server IO #6/INFO] [journeymap]: CLIENT
[19:21:31] [Netty Server IO #6/INFO] [CodeChickenLib-ConfigSync]: Skipping config sync, No mods have registered a syncable config.
[19:21:50] [Netty Server IO #6/ERROR] [FML]: NetworkDispatcher exception
[19:21:50] [Server thread/INFO] [net.minecraft.network.NetHandlerPlayServer]: Albert_Minestine lost connection: Disconnected
[19:21:50] [Server thread/INFO] [net.minecraft.server.dedicated.DedicatedServer]: Albert_Minestine left the game
[19:21:51] [Netty Server IO #6/ERROR] [FML]: NetworkDispatcher exception
[19:22:06] [Server thread/INFO] [net.minecraft.server.dedicated.DedicatedServer]: Stopping the server
[19:22:07] [Server thread/INFO] [net.minecraft.server.MinecraftServer]: Stopping server
[19:22:07] [Server thread/INFO] [net.minecraft.server.MinecraftServer]: Saving players
[19:22:07] [Server thread/INFO] [net.minecraft.server.MinecraftServer]: Saving worlds
[19:22:07] [Server thread/INFO] [net.minecraft.server.MinecraftServer]: Saving chunks for level 'world'/overworld
[19:22:07] [Server thread/INFO] [THAUMCRAFT]: Removing aura cache for world 0
[19:22:08] [Thread-10/WARN] [THAUMCRAFT]: No auras found!
[19:22:08] [Thread-10/INFO] [THAUMCRAFT]: Stopping aura thread for dim 0
[19:22:08] [Server thread/INFO] [FML]: Unloading dimension 0
[19:22:08] [Server Shutdown Thread/INFO] [net.minecraft.server.MinecraftServer]: Stopping server
[19:22:08] [Server Shutdown Thread/INFO] [net.minecraft.server.MinecraftServer]: Saving players
[19:22:08] [Server Shutdown Thread/INFO] [net.minecraft.network.NetHandlerPlayServer]: Avvic lost connection: Server closed
[19:22:08] [Server Shutdown Thread/INFO] [net.minecraft.server.dedicated.DedicatedServer]: Avvic left the game
[19:22:08] [Server Shutdown Thread/INFO] [net.minecraft.server.MinecraftServer]: Saving worlds
Current mod list:
Baubles
BetterFPS
Bewitchment
Botania
Chancecubes
CodeChickenLib
Chisel
Connected Textures Mod
cxlibrary
DoomlikeDungeons
EnderCore
EnderIO
EnderStorage
Fluidcows
grapplemod
Hats
Hwyla
iChunUtil
Just Enough Items
Journeymap
llibrary
Mantle
Minecraft Comes Alive
mclib
MoreFurnaces
Optifine Ultra (E3)
Patchouli
ProjectE
RadixCore
rafradek_TF2_weapons
RoguelikeDeungeons
Ruins
TConstruct
Thaumcraft
Veinminer
latest (1).log
https://linustechtips.com/topic/1084581-minecraft-forge-error-when-trying-to-join/
