Whenever I go to a different page, this pops up almost every time.
The connection was reset
The connection to the server was reset while the page was loading.
    The site could be temporarily unavailable or too busy. Try again in a few moments.
    If you are unable to load any pages, check your computer's network connection.
    If your computer or network is protected by a firewall or proxy, make sure that Firefox is permitted to access the Web.
This didn't happen until my brothers started using their mobiles on the wifi, do you think it's my router?
How do I fix this problem?
It's not my PC's fault, all drivers updated and I bought a new WLAN card.
https://linustechtips.com/topic/108351-the-connection-was-reset/
you might be right with the router.  they need turned on and off every now and then.  what is it?
When you are getting this message does you  computer have connection.  by that i mean is the computer saying limited connectivity under network connections.
I asume you are also on wifi.  what type b,g,N AC 2.4gbz or 5ghz the older ones have interference issues where the network will default to the speed of the slowest connected device.
https://linustechtips.com/topic/108351-the-connection-was-reset/#findComment-1449171
