cheap & silent advice
Go to solution Solved by ITS,
1 hour ago, MiniMike DK said:
From my experience, an AIO pump would be sufficient, but be aware that the pumps flowrate is far lower than a normal pump.
As I wrote, my AIO has the 6th gen. pump, which form the looks of the pump design helps.
The worst part was getting all the air out of the system.
thanks for the info
not sure if this is the best place to ask...but cant think of a better group to ask advice from
long story short: i need to cool down 3 nema17 stepper; but I have no idea what pump to use; i am hoping to drop the temp down by ~10-20 degrees...guessing any basic pump should do but i want one that is silent (~20db), as its in my home office.
what would you guys recommend ?
TIA
https://linustechtips.com/topic/1072897-cheap-silent-advice/
"Cheap" and "watercooling" doesn't go well together :D I'd just get some regular stepper heatsinks (http://3dmodularsystems.com/en/electronic/139-heatsink-for-nema-17-stepper-motor.html) and quiet fans for air cooling. This will be cheaper and propably quieter than watercooling, because you'd need fans anyway. But if you already have radiators and some waterblocks for the steppers, you'll be good with pretty much any DDC or D5. DDCs are less expensive, D5s are slightly quieter.
PC: Screw day theme users, I guess ¯\_(ツ)_/¯
CPU: R9 3900X @ 4.375GHz All Core MoBo: ASRock X470 Taichi RAM: 2x16GB Mushkin Redline @ 3200MHz 16-18-18-36 GPU: GTX 1080TI FE @ 2088MHz Cooling: Single 60x360mm rad w/ Scythe Kaze Flex, dual 45x540mm external rads passive, Nickel Plexi EKWB blocks, Alphacool VPP755V3 + Watercool Heatkiller Tube 250, Aquacomputer Quadro Case: Inter-Tech 4U 4129-N PSU: Corsair RM1000x Storage: 1TB Samsung 980 M2 SSD, 1TB Seagate Barracuda  Q1 SSD Network: Mellanox ConnectX-3 10G
NAS & Proxmox:
CPU:  Epyc 7302 MoBo: Supermicro H11SSL-i RAM:  8x32GB @ 2666MHz Samsung Registered ECC  Cooling: Enermax Liqtech TR4 II 360 w/ Corsair ML120 Case: InterTech 4F28 PSU: Seasonic Focus PX-650 Storage: 8x6TB HGST + 2x1TB WD Blue SN570 + 2x16GB Intel Optane SSDs Network: Mellanox ConnectX-3 10G
ML-Compute Server:
CPU:  i5 10600K MoBo: MSI MPG Z490 Gaming Plus RAM: 4x8GB HyperX Fury @ 2133MHz8 GPU: Gainward GTX 1080TI Golden Sample Cooling: Single 30 Case: RackMax 2U 8-Bay Storage Case Storage: 512GB Patriot P300 + 4x2TB Seagate Ironwolf NAS Network: Intel Quad 1G
Laptop: Acer Travelmate B117 (absolutely low power, but 12h battery life :D)
Phone: Oneplus Nord
Peripherals:
Monitor: LG 34UC79G + 27GL63T Keyboard: KBDFans 65Rev2 Mouse: Logitech G603 Mousepad: Cheap-ass GMB Mouspad Headphones: AKG K7XX  Other stuff: Novation Launchpad MK2, Aune T1 USB DAC/Amp, Behringer UMC202HD + Audio Technica AT2020 Condenser Mic
Cameras:
DSLR: Canon EOS 600D (Magic Lantern OS) Action Cam: GoPro Hero 3 Silver
Mountainbike:
Frame: Banshee Legend MKIII Fork: Marzocchi 380 C2R2 Titanium Rear shock: Rock Shox Vivid Air/Coil (switched depending on how I feel) Wheels: Spank Spike Race 33 Tires: Maxxis Minion DHR2/DHF Brakes: Magura MT5 Calipers with Shimano XT Levers Deraileur: Shimano Zee, Casette reduced to 6 Speed Crankset: Truvativ Descendant + 38T FSA Chainring Wheight: 16.4kg w/o pedals
https://linustechtips.com/topic/1072897-cheap-silent-advice/#findComment-12646903
the nema are in an enclosure to print ABS... not sure heat sinks will do much
https://linustechtips.com/topic/1072897-cheap-silent-advice/#findComment-12647566
There are some pretty cheap generic aluminum waterblocks on amazon and aliexpress. They usually come in 10mm increments. So for a Nema 17 you can get some 40x40mm blocks and for mounting brackets: you have a 3D printer, CAD some up and make them :D. Together with a cheap aluminum radiator (a slim 120 will propably be enough, but to be on the safe side I'd get a 240mm). Together with a good pump and some quiet PC fans you'd have to spend about 150$, with the fans and pump being the majority of the cost.
NAS & Proxmox:
ML-Compute Server:
Phone: Oneplus Nord
Peripherals:
Cameras:
Mountainbike:
https://linustechtips.com/topic/1072897-cheap-silent-advice/#findComment-12647597
i already have STL's for the water block ? was looking this AIO https://www.amazon.ca/gp/product/B07CNXHYJ2/ref=ox_sc_act_title_1?smid=A3DWYIK6Y9EEQB&psc=1, thinking of just pulling out the water lines to add some 40mm block in between and use the pump in the CPU block.,..i should be able to just splice the power cables
https://linustechtips.com/topic/1072897-cheap-silent-advice/#findComment-12647696
Yeah, that would work too. Yesterday @MiniMike DKposted his modded AIO to include a GPU waterblock and a reservoir in this thread, he might be able to give you some advice:
NAS & Proxmox:
ML-Compute Server:
Phone: Oneplus Nord
Peripherals:
Cameras:
Mountainbike:
https://linustechtips.com/topic/1072897-cheap-silent-advice/#findComment-12647830
https://linustechtips.com/topic/1072897-cheap-silent-advice/#findComment-12648072
thanks for the info
https://linustechtips.com/topic/1072897-cheap-silent-advice/#findComment-12648202
