Hello guys,
Need a help.
I have cameras installed, I have access from WAN:port  to cameras and  LAN:port when I am on lan.
I want to access cameras from LAN but with WAN ip and port.
[admin@MikroTik] > /ip firewall nat print
Flags: X - disabled, I - invalid, D - dynamic
 0    ;;; defconf: masquerade
      chain=srcnat action=masquerade out-interface-list=WAN ipsec-policy=out,none
 2    ;;; DAHUA
      chain=dstnat action=dst-nat to-addresses=192.168.100.222 to-ports=XXXX protocol=tcp in-interface=all-ethernet dst-port=XXXX log=no log-prefix=""
 3    ;;; PELCO
      chain=dstnat action=dst-nat to-addresses=192.168.100.223 to-ports=XXXX protocol=tcp in-interface=ether1 dst-port=XXXX log=no log-prefix=""
[admin@MikroTik] >
These both are cameras. Two different systems.
P.S.  I have done Hairpin NAT but it doesn't work. Mikrotik router
---___--- HP Probook 450 G0 ---___---
I5-3230M 2.60Ghz ( 4 CPUs ) ~ 2.6Ghz
8192Mb RAM
AMD Radeon HD 8600/8700M
120 GB SSD + 1TB HDD
https://linustechtips.com/topic/1069689-connect-to-cameras-from-lan/
Question, your local IP is set as the same network?
Did you try Class B subnet mask config?
Do you receive any pings when pinging your cameras from your LAN?
Security Analyst & Tech Enthusiast
Ask me anything.
Yes, I want to connect from 192.168.100.0/24 to 100.222 (NVR)
I m trying to connect via WAN IP of my office.
I can ping it in LAN
8192Mb RAM
